Results 1 to 3 of 3
    Dec 2011
    Any GT Zaskar Expert Owners? Frame Size?
    Looking for some advise. I recently purchased a GT Zaskar Expert in size large. I'm 5' 11 and wear size 32" long pants. The medium seemed a little tight so I went with the large. Now that I have some riding time in, I now feel it's a bit big. Thanks to some advise, from this board, I ordered a 70mm stem, the stock one is 90mm. I am hoping this will help. My question is, sorry to ramble, is there any other 5'11 riders on the large Zaskars?
    Aug 2010
    i'm 1800 mm long. mine is medium. and i and my friends consider it to be little long for me, i think that large is too long for you.
    GT Zaskar sizing
    I'm 5'11" and have a 32 in inseam as well. I bought a Large 2009 Zaskar Expert (26 in) last February. It originally came with a 100mm stem, causing by lower back to hurt on extended rides because I was too stretched out. I ended up using a combination of low rise bar at a wider width (640 mm) and a 30 degree rise 70 mm stem. Problem solved. It's still aggressive enough to throw around in the corners, but an easy climber as well. Hope this helps!:thumbsup:
    Attached Thumbnails Attached Thumbnails Any GT Zaskar Expert Owners?  Frame Size?-short-stem.jpg
    "Everybody relax, I'm here." - Jack Burton
