Results 1 to 14 of 14
    May 2014
    All mountain hardtail 29 build
    So, I'm trying to build an all mountain hardtail 29er with 140mm travel but want to use the wheelset off my 2014 enduro. It has 142+ spacing and I will still be riding it so altering the wheels to the point where they will not work on it would be bad. Anyone know of a slack hardtail that would accept 142+ spacing?
    Reputation: socal_jack's Avatar
    Dec 2008
    Niner ROS9, have one built up 142x12 with Pike at 140mm though its SS, super fun bike
    142 + is a proprietary wheel spacing from specialized and as far as I know won't work with a typical 142 spacing bike.
    May 2014
    Quote Originally Posted by cbrock450 View Post
    So maybe there a new rear hub could work? Could I make a hope pro2 work with both bikes via spacers?
    No Clue Crew
    Apr 2005
    It'll work fine. Put a 2mm spacer (a pair of pedal washers is perfect) between the drive-side hub and the dropout.
    No dice. This is exactly why specialized does this type of spacing. So you can only run their products.
    Oops. sounds like someone might have found an answer for you. Good to know!
    No Clue Crew
    Apr 2005
    I've run Specialized 142+ wheels on several 142x12 frames. Works fine as outlined above.
    May 2014
    Damnit specialized. Oh well. Sounds like a good excuse to get a new hub anyway. Thanks for the help.
    May 2014
    Well, I'm gonna shoot for a 142mm dropout and hope I can make something work. Maybe I'll try it out with the 142+ first and if it doesn't work I'll get a hub.
    No Clue Crew
    Apr 2005
    Did you read above?
    May 2014
    Yeah. I will find a 142x12 frame and try my wheel first.
    Nov 2012
    Hard Eddie?
    Reputation: rollinrob's Avatar
    142 plus works on my Iis ripley with 2 pedal spacers on the drive side. Goes to show that 142 plus is food for more than just specialized bikes
    Feb 2013
    I really dig my Kona Honzo with a 34 140.
    Other candidates: Canfield N9 or EPO or Yelli. All great.
  1. Possible to build a Hardtail for under $900?
    By Aderum in forum Beginner's Corner
    Last Post: 05-10-2015, 11:43 AM
  2. New XC hardtail build
    By turbogrover in forum General Discussion
    Last Post: 07-08-2014, 05:08 PM
  3. 29er hardtail build
    By AngusMTBO in forum 29er Bikes
    Last Post: 05-23-2014, 12:42 PM
  4. Head Set for Ti Hardtail build
    By BacDoc in forum Bike and Frame discussion
    Last Post: 01-10-2012, 12:52 PM
  5. Hardtail Build
    By micky in forum Bike and Frame discussion
    Last Post: 11-08-2011, 12:06 PM
