Results 1 to 20 of 20
    Al hardtail 29er frame options?
    I'm thinking about a new frame and it seems like my niche is a bit short on options. Basically looking for an affordable xc oriented aluminum frame in the vein of the Niner EMD--a standard xc race and general trail frame. I might just get an EMD but I've had one already and something new and different would be nice. I'd prefer to avoid frames with adjustable dropouts. 135 preferred but 142 okay if need be. Fire away...
    4 Niners
    Dec 2008
    EMD's are great and all your old parts will fit. And you can generally get them for around $500.
    Full rigid SS, Hardtail SS, Hardtail Geared, Full Suspension Geared.
    On-One Parkwood Frame $275.
    You can try similar geo in ti for $949.
    Titus Titanium Fireline Evo 29er Frame
    Both are a little more towards trail.
    Jan 2013
    Quote Originally Posted by eb1888 View Post
    +1 for the Fireline Evo. Amazing frame!
    Reputation: racebum's Avatar
    Mar 2013
    jenson has the air 9 for 599, or, if you barter with them you can get the emd under 500. i really like the geometry of the niner emd. the short 16.5" seat tube and longer top tube more commonly found on an 18" frame along with short chainstays make it just a great bike. i also like the 73mm BB and tapered headtube.
    just finished this one a week ago. had all the parts except the fork and headset on my spare parts shelf
    n00b eternal
    Reputation: ezweave's Avatar
    I like the EMD better than the Air. Not a fan of press fit BBs. I have had a few bikes with press fit BBs and they are finicky. Didn't want to get another. I wish my CX bike didn't have one now... the damn thing is fine for 100 miles after servicing it, then you get the clicks.
    4 Niners
    Dec 2008
    I have an Air9 and my son has an EMD9. I also would rather get rid of the press fit. I put an adapter in mine to convert it to BSA.
    I suspect I'll end up with another EMD. I had the older version without the tapered HT, but my current fork is tapered so the newer version will work great. I also prefer threaded BBs. I really had no complaints with my previous EMD and as far as I can tell there is nothing else out there that checks the same boxes at a similar price.
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    EMD is a good frame, and it is a Niner, you can't get any more into the 29" wheel than with a Niner. The frames are also a great price for what you get.
    Mar 2013
    agree with you guys on the press fit. i also have a superfly FS that uses a press fit. had to grease the snot out of it. so far so good but it's just kind of a cheese way to save a few grams. the threaded BB makes so much more sense for long term usage.
    you can actually build an SLX, reba, emd for less than the online vendors want for an x7 with a recon.
    May 2014
    No one suggested this yet so I'll throw it out there. Good option for $250.
    Airborne Bicycles. Goblin Frameset
    I have a goblin on the way from a friend. I rode it a couple of times very briefly but remember liking my emd better. That is why I am already looking into options before I have the goblin in hand. It may turn out to be just fine which would be great as I'd like to save my money for a full suspension bike for next spring. We will see.
    May 2014
    Quote Originally Posted by jmal View Post
    Is it the older green frame or newer black frame?
    It's the newer version (black) with the tapered HT. My friend bought it when they first released the second version. I eventually sold my EMD to him when I moved, and now he is moving overseas and I'm trading him a SS for the Goblin. We have serious bike incest happening.
    This Aluminium question is interesting. I looked for a steel 29er HT, shortlisted about 3 that were all nice and ended up spotting a Ti bargain (which I love). However, I'd like second cheapo frame and I just don't know what the sweet riding Aluminium 29er frames are. There were some nice riding Alu 26ers (like the Whyte 905). I'm wondering if the Kinesis FF29 is one of those Gems.
    Sep 2012
    I have an EMD, but at the time was considering a Santa Cruz Highball as well. Having an Airborne Guardian and Seeker in the house, which are almost the same as the Goblin, I find the EMD to be a bit more agile, the Airbornes, more stable.
    Trek Stache 7
    9:Zero:7 Whiteout
    Ibis Ripley LS
    Santa Cruz Bronson
    That was my impression when comparing the two as well. Also, the front end seems higher on the Airborne.
    May 2014
    The Goblin is more classic to the XC type of 29er, slightly longer chainstays for the stability factor. The EMB, I believe, has 435mm chainstays (?) which is why it would feel more agile or "playful".
    I think the front end of the Airborne feels higher because they keep the steerer tube slightly longer than most other brands to give users more ability to custom fit since they are being purchased "blind" without being able to sit on them first. I thought the same thing with both of my Airbornes until I lowered the stem by removing some of the spacers. If you notice there are probably an extra 10mm worth of spacers on the Airborne than your previous bike. If you haven't done so already play around with the stem height and if you want to get it even lower you can reverse the stem so its at a negative rise.
    Mar 2013
    emd has extremely short chainstays. you're lucky to get a finger between the seat tube and tire and that's with a 2.2 tire. makes the bike easy to maneuver but i noticed the same thing at speed, it can be a bit dicey
  1. need options on long travel hardtail 29er
    By Jkj in forum All Mountain
    Last Post: 04-27-2014, 06:48 AM
  2. New FS 29er alu frame - Need some options!
    By GaryFisherProCaliber in forum 29er Bikes
    Last Post: 01-16-2014, 03:34 AM
  3. 140mm AM Frame or 29er AM Hardtail?
    By NacDirtbag76 in forum All Mountain
    Last Post: 01-15-2014, 01:04 PM
  4. Replies: 6
    Last Post: 08-14-2013, 10:43 PM
  5. 29er Hardtail Frame??
    By mummer43 in forum 29er Bikes
    Last Post: 01-16-2012, 05:48 PM
