• 11-27-2012
    toddre
    Admit it here...who's shimming?
    Need a new post for my HT and I had been shimming my 27.2 to a 31.6. I figured it was cheaper and more comfortable. Who's doing it? I'll probably go c. fiber for the post again....
    thanks!
  • 11-27-2012
    bde1024
    I've been running a Niner EMD with Race Face Next 27.2 carbon post shimmed out to 31.6 for a while now, with no issues. I think I can feel a little more compliance from the post compared to my old Air 9 frame with an unshimmed 31.6 Thomson, but the effect is less than a few PSI of air pressure in the tires.
  • 11-27-2012
    BigDaddyFlyer
    thanks!
    I'm not a big fan of shims unless they are long enough to pass below the tube juncture on the frame. Most commercially available shims don't take every frame design into account and put more stress than intended on the frame. Will it break? Probably not.......but why take that chance?
  • 11-27-2012
    thasingletrackmastah
    I admit...
    I was, for a while.
    But not for the reasons you had in mind...
    Don't know what happend at Thomson, but someone must 've been sleeping.
    All sorted out now, a brand new Thomson is smiling at me, from my desk.:thumbsup:
  • 11-27-2012
    GTscoob
    Shimmed 27.2 in a 31.6 slot on my Access 29er frame.
    I'd picked up a straight 31.6 post when I built it but it wasnt comfortable so I pulled out an old setback 27.2 post and picked a shim up from the LBS and was good to go. Only gripe is messing with the shim if I slam the post for more aggressive descending.
  • 11-27-2012
    texasnavy05
    Funny, I thought I clicked on the "29er bike" forum.
  • 11-27-2012
    toddre
    :rolleyes: One of those, huh?
  • 11-27-2012
    AZ
    No mistake. I use a 29er specific shim. Don't want to see a perfectly good carpet fibre seat post sit in a parts box.
  • 11-27-2012
    texasnavy05
    "those" being people who think you should post a thread in the correct sub-forum.
    Yes. I am one of "those".:thumbsup:
  • 11-27-2012
    shiggy
    thanks!
    I shim my dropper post. Bought a 27.2 so I can use it with several different frames I have.
    Use the proper diameter for regular posts. My 31.6 posts did not cost me more than $35 each. A couple were $9, less than the shims I have for the dropper.
  • 11-27-2012
    Nickbm3
    Yah! I mean c'mon, the "29er components" forum is just one line lower than this one!
  • 11-27-2012
    FM
    I've seen numerous frames screwed up from running shims and under-size dropper posts. Both aluminum and steel. Something I am looking into repairing on my steel hardtail right now. No fun
    :mad:
  • 11-27-2012
    Wombat
    Some Giant frames in the past came with a seatpost shim as standard. They required a longer insertion length if a seatpost without a shim was used.
    Tim
  • 11-28-2012
    b-kul
    Originally Posted by thasingletrackmastah View Post
    I was, for a while.
    was that on a 29er? you're asking for trouble man, thats a dh/fr shim.
  • 11-28-2012
    grundy
    :mad:
    Really?
    I ran a shim on my old aluminum hard tail (31.6) with a 27.2 GD for the last few years, just switched to a Yelli, also shimmed, with the same 27.2 dropper post.
    What's the screw up? From the shim being too short?
  • 11-28-2012
    FM
    Originally Posted by grundy View Post
    Really?
    Not really sure. My guess is that "under tolerances" stacked up and caused the frame to deform. Or, maybe the shims were too short, creating too much leverage on the top of the seat tube, creating bending or deformation.
    Bike #1 is my curtlo hardtail, 28.6 seat tube with a shim, 27.2 GD classic.
    Bike #2 was a friends diamonback mission, I think those are 30.9, he was also running a shim down for a gravity dropper.
    On both bikes, the effect is the seat tube is crimped or deformed so changing seat height or removing the post involves 10-15 minutes of bike wrestling.
    Gonna take my curtlo into a local frame shop to look into repair, hopefully it's an easy fix (and with steel, good chance it might be)
  • 11-28-2012
    GTscoob
    Well good time to discuss the nicer (longer) shims from the cheaper (shorter) shims?
    I think I've got a Cane Creek in my frame and IIRC it was around 3" long, long enough to get through the top tube/seat tube junction on my frame.
  • 11-28-2012
    Econoline
    Thomson seatposts often run undersized. Thomson did exchange a couple of undersized Elites for me, but I've sort of given up on Thomson and gone to Ritchey.
  • 11-28-2012
    kjlued
    Seriously, 29er shims should only be made out of beer cans and preferably a good quality micro brew.
  • 11-28-2012
    kapusta
    thanks!
    I've been running shims on my dropper post for the nearly 7 years I've owned it on 4 different frames. No issues.
  • 03-04-2015
    noapathy
    Curious. If this brew uses the terms "29" and "epic", which category should it fall into - 29er, AM, FR, enduro? :winker:
  • 03-04-2015
    andyfloyd
    I run a raceface evolve 30mm with a shim for 31.6 in my carbon hardtail. I did this to achieve some compliance back there.
