Page 2 of 2 FirstFirst 12
Results 101 to 124 of 124
  1. #101
    Reputation: noosa2's Avatar
    Trying to decide how nice I'm feeling today and if I should bother to explain why use the Goatlink for this application since you seem to know it all
    Hey LyNx, I'm interested about the Goatlink and how it helps. I'm building a bike for my 12 year old and plan to use my old dirt jump wheels which have a SS Hope pro 2 hub, my backup (read heavily used but operational) XT shadow plus rear derailleur, and an XT 10 speed cassette. Would the Goatlink help if I'm using the above parts? Why does it help?
  2. #102
    MTB B'dos
    Reputation: LyNx's Avatar
    Well, since you asked so nicely, here it is....
    The Goatlink moves the RD back and away from the cassette, as far away as would be required for a 42 cog. The reason this is good is because the 36t large cog you'll be running on the short/SS freehub is actually in the position the 3rd or 4th cog (26-)28t cog would be on a normal cassette, hence the RD is much too close to the cogs and will most likely be too close and rub. Since it moves the RD away, you don't have to go messing trying to use a longer B-limit screw to move the pulleys away to accommodate the larger than designed for cog in that position, the Goatlink properly moves the entire RD away.
    Quote Originally Posted by noosa2 View Post
    Shimano XT Clutch RD
    Shimano XT Clutch RD with Goatlink
    6 speed cassette on SS hub....Please post your setup-clutch-rd-w-goatlink.jpg
  3. #103
    Goatlink is about to be ordered - thanks.
  4. #104
    Dec 2012
    Noosa2 - thanks for asking nicely.
    LyNx, cheers for the answer. Now it all makes sense.
    And no - I'm not a 'know it all'. Your info posted above just proves it!
  5. #105
    Dec 2013
    Is anyone running the Halo ss rear hub? I just bought one cheap for a mini Velo project, but haven't tried or tested any cogs on it yet... 😼
  6. #106
    Hi LyNx, which combo do you think would be best on Hadley SS hub with 5 8spd cogs:
    GoatLink with 10 speed XT Shadow+ or
    GoatLink 11 with 11 speed XT Shadow+
    My cogs are 34-26-20-15-12
    Many thanks!
    Often wrong but never in doubt.
  7. #107
    Is anyone using an old school thumb shifter?
  8. #108
    Dec 2013
    Not an old school thumbie but gong to try with a Dura-Ace bar end shifter on a Velo Orange handlebar mount... Will see how it goes!
  9. #109
    Nice. Keep me updated, I'm curious about doing the same, looking for a ratcheting type shifter. Didn't know VO made those mounts, only knew of Paul Components Thumbies.
  10. #110
    MTB B'dos
    If you use an 11spd RD, you don't need a Goatlink, it's already built to accommodate the large 42-44t cogs of 11spd cassettes, so should easily handle a 34 cog in that position. If you're going to use 8spd spacing, not sure if either of those RDs will work with an older indexed shifter, but should work with a thumb shifter, no clue on the Hadley hub itself.
    Quote Originally Posted by pureslop View Post
    Many thanks!
  11. #111
    Quote Originally Posted by chrzis View Post
    Well - here are some pics of my unbuild Project 321 SS hub. (Same as the I9 torch SS apparently) 6 gears from a Shimano 10s work.
    Not much help with the Hadley / DT question sorry. But the info may help someone else.
    What size is your smallest cog? I'm looking at a 6 speed setup for my son and was thinking of either a 17T or 19t as the smallest cog.
  12. #112
    Dec 2012
    For the purpose of the photo, I just threw on my first 6 cogs from my 10s cassette. 11t was the smallest in the photo.
    Once I get my wheel built up, I hope to use 2x carriers from a 10s cassette. This will reduce free hub damage. See Shimano-compatible 10-speed Cassettes.
    Maybe a CS-M771? This will give 18, 20, 22, 25, 28, 32. I haven't decided yet.
  13. #113
    MTB B'dos
    If you use the 6 cogs that come on an XT cassette, it's just long enough to reach the end of the freehub and a lockring will hold again the alu carrier, depending on if you machine the back or not, then you can fit 7 cogs on the Hope SS/trials freehub.
  14. #114
    That Sleestak
    Quote Originally Posted by Deerhill View Post
    Why not move this to drivetrain forum so people can find it.
    Take away the challenge of finding it, and dumb down the forum?
    You found it, and now I found it.
    Sub'd
    Quote Originally Posted by Picard
    Is that German or Polish sausage?
  15. #115
    itunes sucks
    Reputation: Deerhill's Avatar
    Dec 2009
    6 9spd (more fit w/ cut xt)
    Quote Originally Posted by bikeny View Post
    Does anyone have actual measurements of the usable cassette area of various singlespeed hubs? I saw a picture of a Hope showing 24mm length, but I have not been able to find anything else. Seems like the King is on the short side and the Hope is on the long side. Anyone have a hub handy they can measure? I'm especially interested in the Hadley and DT Swiss hubs.
    HadleySS =a touch less than an inch to work with, |xt cassette + 12t lockring| ~24mm
    SDH R29.er
    video=youtube;][/video]...
  16. #116
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by Cornfield View Post
    Sub'd
    yup, this one's getting archived for later...
    Rigid SS 29er
    Hardtail 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
  17. #117
    Hey LyNx, thanks again for this info. I finally had time to setup my son bike with XT derailleur with clutch, XT cogs on a Hope SS hub. The goat link made it super easy.
  18. #118
    MTB B'dos
  19. #119
    Did I catch a niner+?
    I am thinking about doing this on a classic Industry Nine SS hub, but I actually want it for a touring setup. I have most everything that is needed including a XT hub but am curiuos how people have gotten on with a triple with this setup?
    I will be using a XTR (104bcd) crankset with it's triple chainrings and a XT M770 cassette to hopefully get a 7 speed setup but am ok with a 6 speed.
  20. #120
    Oct 2011
    All my life i have been using 3x8 drivetrain. 42-32-20 crankset. With 11-34 eight cogs cassette.
    Then a friend gave me an ss freehub. No brand but i believe it is a Formula.
    The body can accept 3cogs. So i put 12-24-34cogs.
    But then it appears that the derailer cannot serve that combo.
    So i made a compromise.
    Now it is 14-21-28.
    I have now 3x3 drivetrain.
    87 gear inch high to 21 low
  21. #121
    Oct 2011
    Yes. I do. Suntour thumbies. Non-indexed
  22. #122
    Dinner for wolves
    Reputation: buddhak's Avatar
    Late to the party
    Hi all,
    Thanks to everyone who has contributed their experience and pictures to this and other threads describing 5, 6, 7, and even 8 cogs on SS hubs.
    Years ago I had some semi-success with a 5 speed cog on a Hope Trials/SS hub. This winter, using the accumulated wisdom here I set up my SS Coconino hardtail as a 1x7. It has been working beautifully, and it has really opened up some new terrain.
    My set up (for posterity):
    Hub - Hope Trials/SS
    Cogset - SRAM pg990 11-32, used off ebay. Added an aftermarket 13t 1st position cog
    Rear derailleur - Shimano Zee freeride (M640-SSW)
    Shifter - SRAM X5 9-speed (also available as a 10...careful)
    Up front - 175mm cranks with a standard (not narrow-wide) 30t chainring, chainring guard, no other retention device. I have an n-gear jumpstop ready in case, but so far so good without it.
    I had to grind off the lip at the base of the aluminum cog carrier as described by Lynx and others. I accomplished this with a dremel fitted with a 115 cutter. It went well enough. I took the lip down to flush with the rest of carrier, and was left with a chamfer because of the angle of attack. I attempted the same thing with a Shimano CS-M771 ten speed cassette for another bike, but the carrier design made it impossible with the dremel. If you are going with a CS-M771 cassette for a 1x8 on a Hope hub, I highly recommend taking the cogset to person with a lathe. Much better results. This is why I stuck with used cassettes. The dremel + pg990 worked fine, though.
    I needed a thin derailleur washer to get the clearance needed to jump 3 cogs at a time. Aside from that, it was plug and play. Awesome. 6 speed cassette on SS hub....Please post your setup-geared-ultra-coco.jpg
    Attached Thumbnails Attached Thumbnails 6 speed cassette on SS hub....Please post your setup-geared-ultra-coco.jpg
    Responds to gravity
  23. #123
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Ha! Good to know someone's still rocking 1xN the old way.
    I gave up on Hope hub sound long ago. Going with a full 1x9 with a nice, wide asymmetric rim on my most recent geared build. 26" of course, and 135 mm OLD. But considering an Onyx SS/DJ hub with partial cassette if I like the resulting bike!
    26" rigid SS 4130 BB7 nylon-flats ESI latex-tubes non-lubricated-8spd
  24. #124
    Dinner for wolves
    Indeed. I have always been slow to adopt new tech. But I just wanted to toast all of you on this thread, because this 1x7 set up is the bee's knees.
    Responds to gravity
Members who have read this thread: 25
