After making the switch to 29'er, I still can't get the gearing right with the adjustment to the new size. Any suggestions. If I was riding 11-32 with a 46-34-24, what should I be riding on my 29'er.
If I remember correctly, Shiggy has a spreadsheet to calculate gear inches. Do a search for that & then its super easy to figure out once you know the gear ratio.
Let's see - 11-32, 46/34/24, 26er
29er with 11-32, you need 41/30/22 to approximate same gearinches
I'd say that a standard compact crank at 44/32/22 would work fine - but with more top-end range. If you want a lower low, you can run an 11-34.
The wheels are 10% bigger so you need to go 10% lower in ratios to end up in the same place. I'd suggest keeping the same cassette and going to 44-32-22 or 42-32-22. Those are pretty standard combinations these days.
On my old 26ers I ran a 44-32-22 with an 11-34. I pretty much swapped them over to my 29er but I really seemed to bog down between gears. The problem with the wheel being about 10 percent bigger is that the gaps will be about 10 percent bigger too. So I pretty much solved it by running an 11-32. I know I lost a little bit of low end but since I am riding a little more it isn't that big of deal. The gaps bothered me more than losing a little bit of gearing. If I didn't take it out on the road so much I would probably try to tighten it up even more by dumping the 11 tooth high gear.
You have insufficient privileges to reply here.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
