Results 1 to 17 of 17
    29er sizing confusion
    I'm in the market for a 29er HT, having been out of the sport for a while and focusing on road biking, I'm behind the curve on 29er knowledge and I need guidance on sizing.
    I am 5ft 11 1/2" with a 33 inseam, according to many sizing charts I would be a large, however when I test rode a scott 29er it felt large which I think may be due to the standover height, rather than the top tube length. A sales guys seemed to want me to go for the medium however they did not have one in the store.
    Now I'm looking at the cannondale flash 29er buying on classifieds. The SOH of that is higher than the scott. In fact the scott medium has the same as the cannondale large.
    I ride a 55cm road bike and I would say that I have a shorter torso relative to leg length.
    Does anyone size down for a 29er?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Quinner View Post
    A 29er is still just a bike.
    Go by the reach (TT length), not the stand over. If the stand over is more than you are comfortable with, look at other brands.
    Also note that you may need to lower the bars to match your usual setup.
    mtbtires.com
    EXORCIZE
    Reputation: Ryder1's Avatar
    Riding a slightly smaller 29er is not uncommon, especially if riding tight/messy trails. I'd suggest looking for a long medium or short large by using effective top tube AND seat tube angle to calculate. A L Giant XTC Composite is pretty small for a L, while Niner AIR9 is a long medium (72d vs. 74d seat tube angle). Yet same wheelbase...
    2017 Diamondback Haanjo
    2016 Pivot 429T
    2011 Kona Unit
    Reputation: Shalom's Avatar
    Nov 2008
    Use the ETT length to get the sizing right. SOH should be similar, if not the same, to most 26ers from what I have seen.
    And, as Shiggy said, you will probably have to drop the bar height.
    The SOH is higher vs the 26er for the flash. I am trying not to focus on that but I have to say it felt strange, for the same reason I hate cyclocross bikes which have the high SOH. Reach on the large was fine but i did want it Much lower as the responses suggest. Would you say I was between sizes based on my measurements?
    Dec 1998
    No. I would (and did) say you need to look at other bikes if the stand over is your major concern.
    I never notice stand over height while I am on the bike and riding.
    Should also note that the Flash sizing is different between the 26 and 29 versions.
    mtbtires.com
    Intense rider...
    I was told to use ETT length for sizing as well. I am right between a M and L in several brands. Some brands L have the same ETT length as another brands M. Ride as many as you can and find the ETT that works for you, and shop from that.
    Nov 2008
    Again, as Shiggy said, look around. Do not restrict yourself to one manufacturer.
    Also, a professional bike fit sounds like it might be a good idea.
    May 2005
    A 55cm road frame is the equivalent of a medium mountain bike frame.
    Which is weird because your measurements would indicate a large...
    Dec 1998
    Quote Originally Posted by Thor29 View Post
    Sizing is not that simple.
    My mtbs are usually mediums, maybe a large (old set tube length sizing from 17-20").
    Road frames are 57-60cm.
    mtbtires.com
    Im 6' with a 32 inseam and ride a 58cm roadbike My 26ers are large and my Fisher SF is a 21". I feel more comfortable on a larger frame. That bein said. Check out a couple of bikes and sizes and buy what fits
    You're right I do ride smaller road bike than my height would suggest, due to a relatively shorter torso, however on the large 29er reach wasn't an issue.
    eh!
    road my devinci cameleon for 8 years (26er) ,it's a 19" had alot of pain in my hands while driving for a couple of hours,change the stem (zoom) and better gloves it did help.
    so now i just got a new gf cobia it's a 2010 left over saved$ ,but was fitted to a 17.5" frame ,feels better and change the stem on it also .i am also 6 feet and 290lbs the pain is almost gone.
    ps i have to keep the rock shox lock at all time it's perfect,they don't fully lock,i still don't know it's good to keep them lock on the hard trails cause there only rated to 220lbs was not aware of that at the time of my purchest
    Reputation: funnyjr's Avatar
    Quote Originally Posted by Ryder1 View Post
    This is very true from my experience.
    Reputation: Peter Leo's Avatar
    Here is a frame sizer. Just select the mountain bike, and complete the information. It will provide the frame size and even a suggested crank size!
    Bicycle Frame Size Calculator
    FWIW
    I'm 5'11", 34" leg length. Bianchi 58cm- too big but smaller than suggested in above calculator. Shorter stem would probably do it. That bike is parted out now.
    56cm Cannondale Synapse- feels about right. Maybe a hair too long top tube or stem.
    55cm Track type bike- love the fit of this one.
    Large Monocog 29er- feels a little large, now parted out.
    Med Surly Karate Monkey- feels real good.
    My Brain Hurts!
    Reputation: ProfGumby's Avatar
    I ride a large (20.0) Giant Rincon. If I go by the top tube length 23.3 it appears I'd ride a 15.5 inch frame? Really? I'm 5'11!
    EDIT: I posted this elsewhere, but on Monday I had chance to sit on a Trek Hyper and it was a 19 inch frame. Felt pretty good to me! I also got to ride a firends superfly a bit and it also is a 19 inch frame. Again, felt pretty good.
    The trick for me will be to ride a 17 and a 19 on a trail to really see what feels right. Might need to find a demo day or rent to see...
    Remember when we were kids and our Mom's said we could not play in the mud? I'm making up for it now!!
  1. Bashguard Sizing Confusion
    By Strive215 in forum Beginner's Corner
    Last Post: 08-18-2009, 08:32 AM
  2. Hope Sizing Confusion
    By padrefan1982 in forum Brake Time
    Last Post: 07-15-2008, 03:57 AM
  3. Tire Sizing Confusion
    By theRuss in forum Wheels and Tires
    Last Post: 09-14-2007, 10:01 AM
  4. Bike Sizing Confusion
    By futak in forum Beginner's Corner
    Last Post: 07-01-2007, 02:27 AM
  5. tire sizing confusion 26xN.N vs NN-559
    By FireDog46 in forum Wheels and Tires
    Last Post: 10-08-2006, 11:34 AM
