Results 1 to 19 of 19
Thread: 29er sizing
    29er sizing
    Hi guys,
    Last year I bought my first 29er: A new for 2011 GT Karakoram 1.0 - Large size.
    I'm 182 cm tall and something always felt a little off to me. Yesterday I tried my friend's new GT timberline 1.0 (which are great for the money) - M size, and it fitted me like a glove.
    It made me quite unhappy with my local bike shop who's fitted me with a L size.
    My question is, what should I do to make my bike feel more like the M size? New frame is out of the question, because of financial reasons. I've already moved the saddle a bit forward and there's a change for the better, but I've heard it not so great to compensate for long top tube with moving the saddle because of pedaling efficiency (I don't feel it - maybe because I moved the saddle only a bit forward). Other than that, I was given an advice to change for shorter stem. Currently, I got a 90mm stem. Which size should I get? 80mm\75mm\60mm?
    Thanks for your time. Much appreciated.
    two wheel whore
    Reputation: Shmoo's Avatar
    I've read somewhere on there that LBS's sometimes let you try stems. I'd try the extreme first and go with that 60mm.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by mulic3 View Post
    Hi guys,
    Makes sense at your height of 5'11" and change that you would be on the "short end" of a size L, or the "tall end" of a size M.
    Kark 1.0 TT - 622.54mm
    Timberline 1.0 TT - 605mm
    Top Tube difference of 17.54mm (less than 3/4")
    Head Tube length difference of 10mm (about 1/3")
    Kart 1.0 cost - $1150
    Timberline 1.0 cost - $550
    Without moving your saddle which you should keep set for the best pedal/knee relationship, find out what stem and bar combo your friend's Timberline 1.0 has. Dropping stem length from a 90 to a 75mm won't be exactly the same (bar, stem angle, number of spacers, etc... all come into play), but playing with the cockpit with stem length, angle, spacers, bar width, bar sweep are all ways to adjust your fit/feel if you think the Timberline fit you like a glove. Measure your set up, then measure your friends and see where you could tweak (BB to saddle; nose/rear of saddle to bar/stem; to of head tube to top of stem/bar; etc...).
    BB
    Quote Originally Posted by Shmoo View Post
    Thanks man. I'd rather not visit there again. I'm quite pissed that they just gave me what was in stock instead of what I really need. Thought about buying a stem of ebay and installing it myself. Thanks again.
    Quote Originally Posted by BruceBrown View Post
    BB
    Thanks for taking the time to write such an informative answer, much appreciated.
    Any idea what stem should I use? 80\75\60?
    Is a 60 mm stem a too drastic change?
    Go to a different shop. They will have a parts box with a selection of used pieces. Talk to the techs. It takes only a short time to change one out and test ride it.
    Nov 2012
    60 worked great for me on my size L TBLTc
    Nov 2012
    im 5'11" in shoes. long torso made makes size M feel crowded
    Well, I think I'll try the 60. Thanks.
    Feb 2013
    I agree with what someone said earlier about spacers. Try moving one or two on top of the stem to lower the cockpit a bit if the bike fit still feels too large. Tweaking that in addition with a different stem length could work wonders for you.
    gravity fighter
    Reputation: Mikecito's Avatar
    A short stem on a 29 is usually the preferred way to go, so you might be pleasantly surprised by the fit and handling.
    At 5'11" I don't think your bikeshop did you wrong by putting you on a bike with a 622 TT. A lot of fit is personal preference. I bet 50% of people at your height would go large and 50% would go medium. I understand your disappointment however when you discovered that you prefered the smaller bike. Definatly try a shorter stem like 60 or 70mm as everyone else has already stated a shorter stem can make a big difference. I think at your hieght you can be happy with the large with a short stem. Good luck.
    Thanks guys! I've just ordered a 60mm stem. Will post back with result once I get it. Thanks again for sharing your expertise and time.
    I'm gonna have to kill ya
    Reputation: roybatty666's Avatar
    I have ridden a 16" 26er Scandal for a few years and when I built a new 29er scandal they only had the 18" in stock at 5'8-9" I could fit both but was a bit worried about the size, I dropped the stem from an 80mm to a 60mm to compensate for the longer top tube and flipped the stem to get the same seat to bar drop and it feels even better than my 16" 26er.
    If you are only doing XC / trails then the bigger frame is probably the better call anyway so I am sure you will be happier with the smaller stem.
    Quote Originally Posted by roybatty666 View Post
    Thanks man. Appreciate your output.
    Always Learning
    Quote Originally Posted by Mikecito View Post
    Unless you're 6'4" and above.
    No Probs I have spent loads of time fretting over bike sizes as normally buy online as it is far cheaper but always a bit of a gamble on the size/fit front so know how you feel
    I think I posted these two pics in the On one forum but they show the Difference in the bike sizes and how changes to the cockpit and seat height crated a similar set up. Your weight is going to be slightly further back with a shorter stem but as has been said is normally what the modern frames are designed for.
    And something that didn't initially spring to mind is that bigger frames suit the bigger wheels a bit better aesthetically IMHO
    Beautiful wheels. Thanks again my friend.
  1. Karakoram 1.0 '11 how is it?
    By Flboy in forum GT
    Last Post: 01-23-2012, 06:04 PM
  2. 1989 GT Karakoram
    By GT_guy in forum Vintage, Retro, Classic
    Last Post: 08-22-2011, 08:57 AM
  3. GT Karakoram X
    By Rip9 in forum 29er Bikes
    Last Post: 06-20-2011, 12:56 PM
  4. GT KARAKORAM vs GT Zaskar 29r
    By Fractured pixel in forum 29er Bikes
    Last Post: 05-18-2011, 04:30 PM
  5. 1998 GT Karakoram
    By armenjc in forum GT
    Last Post: 01-17-2011, 07:51 PM
