Page 1 of 20 1 2 3 4 5 11 ... LastLast
Results 1 to 25 of 485
    29+ tire choices
    I see two 29+ tire choices (Knard and Dirt Wizard) on the Surly site. Are these the only choices at this time?
    Dirt Wizard in 29+ flavor is not available yet, so the Knard is it for now, I suppose you have two choices, 27 or 120 tpi.
    Reputation: vikb's Avatar
    Vee Rubber has a 29+ tire in their marketing info, but I haven't see one on anyone's bike.
    Safe riding,
    Vik
    www.vikapproved.com
    Quote Originally Posted by Coloradoxj13 View Post
    The ETA that folks in the Surly sub-forum are talking about for the 29+ DW is August. I want to believe that's wrong, but it may be bang on. For the moment there's nothing to do, but rock your Knards and wait.
    Safe riding,
    Vik
    www.vikapproved.com
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    real nice clark! i hope they don't release the DW at the end of a riding season. that's just silly marketing
    I agree. Announcing a product in Sept 2013 and delivering in Sept 2014 is a bit [actually a lot] lame.
    Having said that the wet parts of the year are when many riders want to switch out their Knards for something more aggressive so a fall release isn't totally goofy from that perspective.
    I'm not suggesting anyone actually planned things that way.
    Safe riding,
    Vik
    www.vikapproved.com
    true that, but you could also have 'em for the earlier wet season of lets say spring.
    Reputation: TwoNin9r's Avatar
    Jan 2011
    Dumb question. what's the difference between fat tires and 29+
    Reputation: seat_boy's Avatar
    One is slow and one is fast.
    Quote Originally Posted by TwoNin9r View Post
    Jan 2011
    Quote Originally Posted by seat_boy View Post
    thanks! no seriously...
    29+ is made to go on a 29er (622mm bead set diameter, or BSD) rim, and is about 3" wide.
    Fat tires are typically made to go on a 26" (559mm BSD) rim and are in the range of 3.8" ~ 5" wide. Because of the wider tire, the outer diameter is close to that of a 29er.
    They're also slow
    Jan 2011
    haha awesome. rep for you.
    With 4" or 5" tires you can ride some soft terrain like deep snow and sand that would stop a normal MTB. 29+ tires really don't go anywhere a normal 29er couldn't go, but they provide good traction and a bit better ride through say gravel or sandy section on a normal MTB trail. 29+ also gives you great roll through tech sections due to how tall the tire is.
    Safe riding,
    Vik
    www.vikapproved.com
    that and they are at an od greater than 29 which slackens your head a lil bit. a fun tire, so not to be taken seriously
    I actually agree with this statement. 29+ is the next 27.5 once people figure out they are 26" wheels with marginally taller tread. And people will get tired of 15-18 pounds wheels once the novelty wears off or if you need to climb hills.
    Quote Originally Posted by GSJ1973 View Post
    your post is obscure. 29+ is a 29er tire, not a 27.5 or a 26 w/ a taller tread. the tread is 4" taller than a 26. its a 29er high volume tire, thee end. i climb hills with them no problem so i think you might need to HTFU
    I think GSJ was making two points:
    - there's only a small difference between 26" and 27.5", about the same as between 29 and 29+. So similar to all those punters who saw 27.5 as revolutionary, the current crop of 29er riders may see 29+ as the Next Big Thing.
    - or coming at it from the other way, people will realize their fat bikes are too slow and ponderous for everyday riding, so they'll downsize, but still want some simple cush. So... 29+.
    Of course, what's stopping this is the fact that there's currently only one tire and two frames that work with 29+.
    Quote Originally Posted by fishwrinkle View Post
    I posted the info below in another thread. There are quite a few 29+ compatible frames. The tires are the issue.
    There are tons of 29er tires so if you have a fatbike and want a faster dirt ride no need to really worry about 29+ just roll with "normal" 29er rubber.
    Quote Originally Posted by vikb View Post
    29+ stuff....
    29+ Tires
    Surly Knard 29 x 3 [available now]
    Surly Dirt Wizard 29 x 2.75 [summer 2014??]
    Vee Rubber Vee8 29 x 3 [available ???]
    29+ Rims
    Surly Rabbit Hole 29 x 50mm [available now]
    Velocity Dually 29 x 45mm [available now]
    Velocity Blunt 35 29 x 35mm [available now]
    Derby Carbon 29 x 35mm [available now]
    Schlick North Paw 29 x 47mm [available now]
    Stan's 29 x 50mm rim [available ??]
    29+ Bikes
    Surly Krampus
    Surly ECR
    Some fatbikes
    -- Pugsley
    -- Ti Mukluk [pre-2013]
    Carver Gnarvester
    Muru Mungo
    RSD Bikes
    Lenz Sport Fat-Moth
    Travers Bikes Rudy Fat
    38 Frameworks Mastadon
    Singular Rooster
    All the custom frame builders can do a 29+ if they are interested in the format and design challenges.
    Safe riding,
    Vik
    www.vikapproved.com
    Add the REEBdonkadonk to that list of 29+ compatible frames
    Tested: REEB Reebdonkadonk Mountain Flyer Magazine
    SyT
    SyT is offline
    After a few 'attempts' of riding my Krampus in snow, I find that test ride/report a bit questionable. Even misleading, maybe outright deceiving. Comparing it to a fat bike and a normal 29 with skinny aggressive tires, my opinion is the knard is the worst of both worlds. It behaves pretty much as it does in muddy/wet conditions; worthless.
    Reputation: octavius's Avatar
    Another to add to the list.
    Just spotted in twitter, a maxxis chronicle.
    29x3
    i n d u s t r y
    c o t t a g e
    no date though, huh?
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Quote Originally Posted by octavius View Post
    29x3
    Image courtesy of On One's Brant Richards
    Attached Thumbnails Attached Thumbnails 29+ tire choices-maxxis-chronicle-29-.jpg
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    thanks GT, just wish it was a better pic.
    Category Winner
    Reputation: teamdicky's Avatar
    From here:
    Taipei Cycle Show First Look: Maxxis Mammoth and Chronicle Fat Bike and 29+ Tires
    WWW.TEAMDICKY.COM
    I get paid 3 every time I post on MTBR.
  1. Tire Choices for SHEN 100
    By Dadefatsax in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 08-13-2013, 09:59 PM
  2. The One rear tire choices
    By ikarus189 in forum Canfield
    Last Post: 07-01-2013, 06:07 AM
  3. Tire choices
    By Saucyjack in forum Endurance XC Racing
    Last Post: 01-19-2012, 09:39 AM
  4. Geezus there are a lot of tire choices now
    By cleon in forum Wheels and Tires
    Last Post: 10-29-2011, 11:47 PM
  5. Lost in XC tire choices!!!!!
    By Rhezuss in forum Wheels and Tires
    Last Post: 07-27-2011, 01:00 PM
