Results 1 to 6 of 6
    Bicyclochondriac.
    29" Mountain King tires with Black Chili?
    I am considering the MK 2.2 for a rear tire. I have a 26" MK 2.4 protection on the rear of my 26er, and really love it, and I believe it has a lot to do with the Black Chili compound. Are the 29er versions available with the Black Chili Compound? They are not labeled as Supersonic or Protection, so I am guessing not, but does anyone know for sure?
    aka baycat
    Reputation: Ryan G.'s Avatar
    Orbea USA
    Reputation: TrekFurthur's Avatar
    Feb 2006
    Black chili, or not black chili
    I've ridden both and don't really notice that much difference on the trail; on the road to the trail, however, the 29er doesn't wear down as fast.
    http://www.orbea-usa.com
    Twitter: ORBEAJOSH
    Nov 2006
    don't worry too much. i am sure that most of the black chili story is marketing ...
    Bicyclochondriac.
    Quote Originally Posted by hellocook
    I don't know.... the traction of the one I have on wet rocks and roots is pretty impressive, and I have a hard time believing it is just the tread pattern. It usually has a lot to do with rubber compound. I definitely noticed the difference between Stick-E and non Stick-E Kenda tires.
    Not saying this is a dealbreaker for the 29" MK's, as they still seem to get rave reviews for what I am looking for: a rear tire for east coast winter conditions.
    Nov 2006
    there is no doubt that conti has greatly improved their compounds.
    i am using the 29er MKs (tubeless stan's) as well as 26" MK on 1 bike as protection 2.4 and on another as supersonic 2.2, both with tubes. Before i used up a set of UST MK 2.2. All these tires are great and i have had a lot of luck with them.
    performance is comparable, i would consider wet traction on roots slighlty better with the UST and the 29er. I assume due to the tubeless set up and the bigger 29er foot print. So I guess tubeless and running lower pressures will help more than "black chili". also, the non-black-chilis are definetily on par or very close in performance to the black chili mountain kings.
