2013 Trance 29er Stem Size
Hi MTBR, I was wondering what short stems are you guys running? I read somewhere that Giant uses a special size thus having to buy only Giant Stems (ie carbon stem) . Is it true? If not what stem are you guys running? The stock one is a bit too long for my taste.
Talk with your Giant dealer. They will be able to hook you up easier than most. The stem uses a 1.25" steerer clamp. There are other brands that make these, it will just take some searching. You didn't say which model you had, the X29er 2 does not use the Overdrive 2 headset/stem so your problem would be moot, if that is the model you own.
Hi Foe, thanks for the quick reply! Yes I own the x29er 2.
SF, do you mind explaining to me what Giant does to put a standard tapered stem into the OD2 headset? Is there a collar, or do they just use a different headset?
Cheers
Different top bearing to the headset. The head tube is the same outside diameter on all the Giant tapered HT bikes.
By Andrewfuzzy in forum Giant
Last Post: 12-18-2012, 04:08 PM
By preludedriven in forum Giant
Last Post: 11-20-2012, 06:21 PM
By tonyride1 in forum 29er Bikes
Last Post: 09-16-2012, 04:08 PM
By haolerider in forum 29er Bikes
Last Post: 10-09-2011, 05:08 PM
By happybrandon in forum Giant
Last Post: 06-29-2011, 05:19 AM
- You may not post replies
- You may not edit your posts
Forum Rules
