Results 1 to 6 of 6
    May 2013
    2013 Diamondback Overdrive Comp 29er
    REI has a sale for $850 going on right now down from $1,000. Component wise it can't be beat by other big brands. Would this bike be good on trails? What make a bike trail worthy? Is it mainly the fork? With the money I'm saving up front I can always upgrade the fork later if it doesn't suit my needs. I am 210lbs and will probably go down under 200lbs once I start riding. Will that fork suit me? Any other opinions on the bike?
    Closest bike to this is a '13 Giant Talon 29er 1 at $900. Looks like the fork and components are a notch better on the DB. It almost compares to Talon 0 component wise. Same fork too.
    Frame Overdrive 29" Butted 6061-T6 Aluminum w/ Formed Top / Down Tube, 1.5" Tapered machined headtube, forged drop outs w/replaceable hanger, disc only
    Fork Rock Shox XC 30, TK-29" w/turn key lockout, 100mm travel, ext. rebound, compression adj.
    Rear Shock N/A
    Cranks SRAM S800 for 10spd, w/ replaceable rings, 44/32/22t
    Bottom Bracket Sealed Cartridge
    F. Derailleur SRAM X-5 for 10spd, Low clamp, dual pull, 34.9
    R. Derailleur SRAM X-5 for 10spd
    Shifter SRAM X-5 10spd trigger
    Brake Levers Avid Elixir-1 Hydrualic
    Brakes Avid Elixir-1 Hydrualic Disc w/180mm frt / 160mm rear G2CS Rotors
    Cassette SRAM PG-1030 10spd Cassette (11-36t)
    Rims 32h Weinmann SL-7 Doublewall
    Tires WTB Wolverine Comp 29x2.2
    Pedals Wellgo Alloy forged, CNC MTB
    Handlebar DB Lazer Series 31.8mm low rise
    Stem DB 3D Forged 7° 31.8mm
    Seatpost DB Lazer Series Micro Adjust 30.9mm
    Seat DB Race saddle
    Headset FSA No.42 , Sealed ACB for Taper Headtube
    Colors Matte Green
    Chain Sram PC-1031 10spd
    Hubset (F) 32h SL-7 Alloy w/ CNC Disc Mount (R) 32h SL-7 Alloy Cassette w/ CNC Disc mount
    Spokes Black 14g Stainless Steel
    Grips DB4L 135mm Kraton
    Extras Owner’s manual, Chainstay Protector, Clear Coat, H20 bottle mounts
    Rogue Exterminator
    Reputation: kjlued's Avatar
    The components on that bike are not any better than any of the other bikes in that price range sold through REI. I had a DB Overdrive and always thought the frame felt cheap.
    Low speed accident proved it resulting in a bent frame.
    Replaced it with a Marin Bolinas Ridge and have been much happier.
    In that exact Price point at REI
    Marin Bobcat Trail, Raleigh Talus and Novara Ponderosa all have better components and I would venture to say a better frame. The Novara has the best components of all but the Marin would probably be my choice as I have had good luck with mine.
    I would buy all three over the Diamondback.
    Just stick it in granny and start grinding.
    Rogue Exterminator
    Oh yeah, my experience with REI has been top notch and I highly recommend them.
    May 2013
    Thanks for the insight. Being new to MBs I don't know much about frames. All I can do is compare components. I'm going to test ride the other ones.
    Just curious what does the SR Suntour Raidon-LO Air 29 compare to in the RockShoxx lineup?
    Quote Originally Posted by Dom. View Post
    v
    The Raidon is a good low maintenance ari fork at 5lbs. Next best RockShox is Recon Gold air at 1.2lbs. less weight. Currently 240 at Random Bike Parts.
    I had the 2012 DB Comp, it was matte silver with black graphics. It was actually a very impressive bike. I paid $400 for it on black friday, and so I replaced the front fork with a Rockshox TK gold fork for $230. That XC 32 is a crap fork, also heavy, the TK Gold was very impressive, felt just like a REBA. I enjoyed the DB comp, it was a great hard tail. It didn't feel cheap to me. I had a large, and I weigh about 215 without a pack. It held up quite well. Components are decent but for the price I wasn't complaining. I like the bike.
  1. Diamondback Overdrive Expert 29er
    By d1sco in forum 29er Bikes
    Last Post: 06-06-2012, 04:06 PM
  2. Diamondback Overdrive Comp on sale at Mike's Bikes
    By bobonker in forum 29er Bikes
    Last Post: 05-07-2012, 05:03 AM
  3. 1993 Diamondback Overdrive Comp
    By cegrover in forum Vintage, Retro, Classic
    Last Post: 12-30-2011, 06:17 PM
  4. Diamondback Overdrive (29er)
    By SteveoNH in forum 29er Bikes
    Last Post: 07-12-2011, 03:58 PM
  5. Diamondback Overdrive Comp Questions
    By nelsonccc in forum Diamondback
    Last Post: 01-11-2011, 07:52 PM
