Results 1 to 8 of 8
    Reputation: JWT2767's Avatar
    2010 Rockhopper Expert
    There is a Rockhopper Expert for sale locally and I was curious what people's opinions are on this bike and what it might be worth. It seems to be in good condition, just some scratches and stuff. I am rather new and have been wanting to replace my 13 year old Trek. Our trails have moderate hills, rooty, in the south so nothing super crazy.
    I have also been looking at the airborne Guardian and Seeker. I know the seeker specs are great but that is the extreme extreme end of my budget. Please let me know your thoughts and what it might be worth. Thanks
    Here are the specs...
    FRAME Specialized M4 fully manipulated alloy frame, fully butted, Trail 29" geometry, ORE DT, externally relieved HT, 2-piece forged adjustable slider dropouts, disc only
    REAR SHOCK
    FORK RockShox Dart 3 SL for 29" wheel, 80mm, 1 piece magnesium lower, alloy steerer, adj. reb. damping w/ LO and preload adj., size-specific spring rates, spring assisted seal, disc only
    HEADSET 1-1/8" threadless, loose ball
    STEM 3D forged alloy, 7 degree rise, 31.8mm clamp
    HANDLEBARS Butted alloy riserbar, 25mm rise, 660mm wide, 8 degree back sweep, 7 degree up sweep
    GRIPS Specialized Enduro, dual compound Kraton, no flange, 131mm
    FRONT BRAKE Tektro Auriga Comp, hydraulic disc, dual piston w/ 160mm rotor
    REAR BRAKE Tektro Auriga Comp, hydraulic disc, dual piston w/ 160mm rotor
    BRAKE LEVERS Tektro Auriga Comp
    FRONT DERAILLEUR Shimano Deore, 34.9mm clamp, top swing, bottom pull
    REAR DERAILLEUR SRAM X-5, mid cage
    SHIFT LEVERS SRAM X5-R trigger
    CASSETTE Shimano HG50, 9-speed, 11-34t
    CHAIN KMC X9 w/ reuseable Missing Link
    CRANKSET Shimano FC-M442, Octalink Spline
    CHAINRING S44A x 32S x 22S replaceable
    BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
    PEDALS Alloy body and cage, 9/16"
    RIMS Alex RHD 29", pinned, alloy double wall, eyelets, 28h front and 32h rear
    FRONT HUB Forged alloy, hi/low flange, double sealed, ground race, machined disc mount, 32h
    REAR HUB Forged alloy, double sealed, ground race, machined disc mount, cassette, 32h
    SPOKES 2mm (14g) stainless
    FRONT TIRE Specialized Fast Trak LK Sport, 29x2.0", 60TPI, wire bead
    REAR TIRE Specialized Fast Trak LK Sport, 29x2.0", 60TPI, wire bead
    INNER TUBES Schraeder valve
    SADDLE Specialized Rockhopper XC, Body Geometry, 143mm width, front and rear bumpers
    SEATPOST Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
    SEAT BINDER Forged alloy QR, brass washer
    Old Punk
    I'm still riding my '09 which has a much better fork and drivetrain spec(RS Tora solo air, Deore group). But I have replaced the wheels, dropped the big ring for a bash guard and swapped to BB-7 brakes(way better than the tektro aruigia stock). It's a great bike that has held up to lots of hard XC with a 220lb rider.
    But.
    The stock wheels would not stay true, in fact the spokes would get loose enough that I'd hear them rattle after one ride, but I'm a big guy so.... And those tektro brakes just wouldn't stop me like I needed.
    '09 Specialized Rockhopper expert 29
    Born 26" trials
    '07 Specialized Allez
    Oct 2011
    I have an 09 that I still love....same bike as above. I know they switched in recent years from that M4 frame which is a shame. That M4 was the same frame that was on the previous years Stumpjumper so it is a good one.
    Great bike that I have beat the hell out of and it keeps on going.
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    I didn't see the price in your initial post. How much do they want for it?
    Let's make like a Bike and get the Huck outta here...
    Sorry, forgot the price. He is asking $500. And if you're curious...im 6ft 170lbs and the bike is a 19" which sounds like the size I need.
    Bandit 29 FTW!!!
    The Rockhopper is the upgraded frame from the Hard Rock but the components are on the low end. 9spd is a plus. If it's in really good condition I'd say it's a nice first bike. He probably paid closer to $800 out the door when he first bought it.
    I have no idea how accurate this is but this says $445...
    Listing Detail - Bicycle Blue Book
    After looking at some pictures, there is a decent amount of scratches...it is not pristine.
    Old Punk
    I'm 6'3" and the bike pictured is a 21" w/ a 45mm stem, I could ride it around the world. The 19 should fit you perfect.
    If its rough, I'd move on. If you want it, use the blue book $ and go no higher.
    Born 26" trials
  1. Replies: 13
    Last Post: 11-03-2011, 12:15 PM
  2. 2001 Rockhopper Pro vs 2010 Rockhopper Comp 29er?
    By redpointist in forum Beginner's Corner
    Last Post: 10-21-2011, 06:11 PM
  3. 2010 rockhopper expert 29 chain slap
    By vadersi in forum Specialized
    Last Post: 07-14-2011, 06:45 PM
  4. 2010 Specialized Rockhopper Comp vs 2011 Rockhopper
    By FL_rider in forum Beginner's Corner
    Last Post: 06-28-2011, 03:38 PM
  5. 2010 Rockhopper Expert 29
    By prattcm in forum 29er Bikes
    Last Post: 06-13-2011, 09:58 PM
