Results 1 to 10 of 10
    Reputation: blooper's Avatar
    20 Tooth chainring
    I am looking for a 64mm 4 bolt 20or 21 tooth inner chainring. I have found titanium for 52.00 but I was looking for something cheaper. I have looked at ta specialist, Blackspire and Boone with no luck. Can someone help me with this.
    Thanks,
    Brian
    Ride it like you stole it!
    meh....
    Reputation: Monte's Avatar
    Quote Originally Posted by blooper
    Where did you find the Ti 64 mm 20 tooth or 21 tooth ring? Vuelta only goes down to 22 teeth ($17, $14). Aren't the 20 and 21's custom, or semi custom chainrings?
    Tulsa
    Reputation: rojogonzo's Avatar
    rojo,
    I don't see anything other than tianium for 52.00. Am I missing something? As I stated in my earlier post that is more than I wanted to spend.
    Tulsa
    sorry
    No problem.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    check out
    action tec and middleburn.
    I've checked both and the only thing at Action is titanium for 52.00. Middleburn has nothing smaller than 22 tooth. I guess that I am just going to have to buy the titanium sproket.
    Brian
    ballbuster
    Reputation: pimpbot's Avatar
    I got an Action Tec
    Thanks,
    Brian
    ... actually it was JRMs he traded me for something... forgot what.
    Works great, but be prepared to take a file to your spider to let the chain fit around the bolt bosses.
    Reputation: Whitedog's Avatar
    Quote Originally Posted by pimpbot
    Based on the thread linked below, I bought the ActionTec 20T ring. It fit perfectly on my Raceface Deus crankset without filing. You will have to file slightly with Shimano cranks.
    20t on an export bearing crank?
