Results 1 to 6 of 6
    180mm Shimano Disc Brake Adaptor/FSA Afterburner 386
    So I want to put a 180mm rotor on my front wheel (currently sporting a 160mm rotor), and am wondering what sort of Shimano Adaptor I need to buy to make that happen. My current fork is a Manitou Minute 29er that does not need an adaptor for the 160mm rotor. Thanks for the help.
    p.s. Anyone using the FSA Afterburner 386 crank on their 29er? What are your thoughts about gearing?
    Attached Thumbnails Attached Thumbnails 180mm Shimano Disc Brake Adaptor/FSA Afterburner 386-img_0424.jpg
    I used the 386 in the 27/42 combo for the Iceman race this past year- great crank, but after the first 20 or so miles, the hills got to me since I had pushed the 42 on the first part (spun out with the 27). I would have been better off with the 40T, but replacement rings are rare and expensive. You can get 26 and 39 rings for a normal crank and have more flexibility with ring size.
    ...In the meantime.
    Reputation: EvilBkr's Avatar
    Mar 2006
    Adaptor you need is SM-MA-F180P/P
    Perfect, that's exactly what I got, thanks for the help.
    Reputation: Ronnie's Avatar
    Thought you'd like some Pics.
    Ronnie.
    Attached Thumbnails Attached Thumbnails 180mm Shimano Disc Brake Adaptor/FSA Afterburner 386-17301.jpg
    180mm Shimano Disc Brake Adaptor/FSA Afterburner 386-img_2502.jpg
    The trouble with having an open mind is that people will insist on trying to put things in it.
    That's exactly what I needed to see, thanks for the help everyone!
