Results 1 to 5 of 5
    Jul 2013
    135mmx10mm thru axle
    hi! newbee here. anyone tried 135mmx10mm thru axle ck hub on standard dropouts? is this better than ck funbolts? cheers!
    trail "cleaner"
    Quote Originally Posted by rider168 View Post
    Yes, just buy the Hadley 10mm bolt on axle in conjunction and you'll get a lighter yet just as snug and stiff as the Funbolts.
    Jul 2013
    135mmx10mm
    Quote Originally Posted by AZmtncycler View Post
    hi! thank you very much for replying. happy riding
    trail "cleaner"
    just make sure you purchase the specific 10mm bolt thru axle and NOT the axle for use with fun bolts. They are different axles.
    Jul 2013
    135mmx10mm
    ill make sure! thank you very much!
  1. Replies: 2
    Last Post: 01-23-2013, 10:20 AM
  2. XPOST XTR pedal M980 axle snapped - axle assembly availability?
    By aussie_yeti in forum XC Racing and Training
    Last Post: 01-22-2013, 10:04 PM
  3. Replies: 34
    Last Post: 03-17-2012, 10:05 AM
  4. Hope Pro 2 rear axle upgrade? install Evo bearings and axle?
    By KrisRayner in forum Wheels and Tires
    Last Post: 02-24-2012, 03:05 PM
  5. XPOST XTR pedal M980 axle snapped - axle assembly availability?
    By aussie_yeti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2011, 09:09 AM
