Results 1 to 35 of 35
    ~Reformed Mechanic~
    Reputation: Ace5high's Avatar
    Jan 2011
    100mm vs 120mm Fork?
    Im posting this in the 29er forum because Im looking for specific advice on 120mm vs 100mm on your 29er's
    I recently upgraded to a Reba SL and have only ran 100mm travel on my Canzo. Im trying to decide if I should set it up for 120mm, but im a little concerned about loosing climbing ability.
    How much travel are you running on your 29er?
    Dec 2009
    Put it on and ride it. Who knows what you like.
    Do you want me to decide what you have for lunch today as well.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by gvs_nz View Post
    Your incredibly helpful.
    bt
    bt is offline
    Nov 2007
    the difference will be roughly 20mm.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by bt View Post
    Having a bad day huh?
    Reputation: Mojo Troll's Avatar
    tinker with it.
    just over 3/4" difference. try both and see which you prefer better. part of the fun of mtn biking is tinkering with them.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Ace5high View Post
    I use zero, 80mm and 100mm travel forks on my 29ers.
    mtbtires.com
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by Mojo Troll View Post
    Yeah It is fun, if I didnt just take the fork apart to go from 80mm to 100mm Id prob just do the change over but it is a messy job that takes time.
    I know there are some guys with Canzo's in here so was hoping to get some feedback about running 120mm on this or something similar.
    Reputation: Shalom's Avatar
    Nov 2008
    I have run 80, 100 and 120 mm forks on my 29er. Not much difference (to me, anyway) between 80 and 100. 120 slackened the angles out a little - much more stable downhill. Was still able to climb easily though.
    Just give the 100 mm a shot, now that you have adjusted it. If you do not like it, change it then.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by Shalom View Post
    Its always been setup for 100mm and its fine, but as many know the Canzo is not exactly a slack HT angle so my thinking is the 120mm might dial in the steering a little nicer However the Canzo was designed for 100mm fork...
    Nov 2008
    Then why not give it a shot? Sure, it is a little messy to do, but not a lot of work. And if you are curious about it, then it is more than likely well worth doing....just my 2c.
    ~Reformed Mechanic~
    Jan 2011
    The real question is:
    Is anyone running 120mm on their 29? and happy with it?
    Nov 2008
    Quote Originally Posted by ace5high View Post
    the real question is:
    Is anyone running 120mm on their 29? And happy with it?
    yes
    Former Bike Wrench
    Looking at the Canzo geometry, it runs a relatively steep (but fairly normal for XC 29er) 72 degree headtube angle with the fork set at 100mm. The geometry table says that it will be .75 degree less with the fork at 120mm. This is still a fairly steep 71.25 degree angle which I think would climb just fine. My Stumpjumper uses a 130mm travel fork with a 69.5 degree headtube angle and I was a little concerned about its climbing ability. But it climbs just fine with those numbers. Of course there are other factors involved here but I wouldn't be afraid to give it a shot assuming your Reba can be set at 120mm (not all can).
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by mtnbiker72 View Post
    Always Very helpful input Mtnbiker, thanks!
    I actually did the quick swap by pulling out the last spacer and got it together just quick enough to get a good ride in on a "climb'y" trail.
    I actually really love it at 120mm! I definitely could tell a large difference, I felt more set back in the saddle kinda like tilting your car seat back
    The down hills felt more controllable and I felt Like I was sitting just far enough back that I had a better chance of rolling down the steeps without the worry of going over the bar.
    There are a few obstacles (down trees) that I normally clip my bash guard on that today I cleared them without contact.
    Now the most surprising part was the climbs did not get harder at all, in fact I cleared them easier because the front end did not feel as twitchy as it normally would going up. The feeling of being back in the saddle more actually felt like it helped me to get some more traction too.
    Im very impressed with how well this worked for a Frame thats designed to run at 100mm and Im definitely leaving like this for a while
    trail rat
    Reputation: slocaus's Avatar
    Changing from 100 to 120 on my 2007 Canzo increased it's fun and ride ability by about 20%, it was great.
    Changing from 100 to 120 on my 2009 Canzo decreased the abilities of the bike by 50%, it sucked, sucked, sucked. Did I mention it sucked? It really, really, really sucked. Sucked bad. Sucked really bad. I did not like it.
    The differences in bike geometry, personal body proportions, riding style, personal preference all are considerations. What works for YOU depends on so many factors. Bottom line, YOU have to try and decide for YOURSELF. Good luck on lunch.................
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Reputation: Magilla_Guerrilla's Avatar
    Jun 2010
    120mm canzo
    I run a 95 - 120mm TALAS on my 2011 Canzo.
    I prefer the 120mm setting for everything except steep climbs, when I'll drop it down.
    The 120mm fork makes the Canzo a lot more fun, and it still climbs fine.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by slocaus View Post
    Interesting that the 20mm increase would throw it off so badly, BUT is it possible that you already were not liking the Geo to begin with on the 2009 and the 120mm increase just added to your dissatisfaction on the newer Canzo?
    BTW what was your resolve? Do you still ride the 2009 or did you ever get a smaller size to replace it?
    trail rat
    You got it right, the geo changes on the 2009 did not work for me, and the longer fork made the climbing worse, but it was horrible for my long legs/arms and short torso. Even the 100 is a huge struggle to keep the front on the ground and tracking on steep climbs.
    All those parts are on a hard tail and the Canzo is hanging in the garage. I'm not entirely certain what to do at this point. Maybe a custom tuned shock from Push would resolve it, maybe a medium, maybe a different FS frame, or maybe the hard tail solves it, since I get no rear suspension squat now.
    ~Reformed Mechanic~
    Jan 2011
    Well, coming from a 29" HT and swapping over to the 2011 Canzo, there was no area where I didn't see a huge improvement. Cornering, climbing, descending, comfort, fun everything you can think of. I did notice a tiny bit of petal bob but the RT3 has a pretty good platform setting that takes care of it.
    Sounds to me like the updated Canzo may just not the right frame for you, If it were me Id sell the frame and build one that works better for you... My 2 pennies
    Nov 2007
    Anyone running the Reba at 120mm with the QR drop outs and 1-1/8 straight steerer? My Reba is currently as 100mm. Want to set it up for 120 but seems like I
    Might have issues with flex?
    trail rat
    I just want my 2007 green back. I loved that bike!
    It took me on many great rides.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by pwu_1 View Post
    This is how Im currently setup and I love it, dont feel any flex issues.
    Nov 2008
    No issues either. If you do notice, you could always run a DTSwiss RWS thru bolt.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Just replaced the Radion 100mm fork on my Talon with a 44 @ 120mm, the extra travel is nice but made the front end nervous, to lower the front end put the stem on negative and is all good.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by DiRt DeViL View Post
    Thats strange since it should have had the opposite effect since you would be slacking out the front end, also stem orientation shoulbt have an effect on this...
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    also stem orientation would not have any effect on this.
    Yes it does.
    Nov 2007
    Should have had the opposite effect since you would be slacking out the front end, also stem orientation would not have any effect on this.
    He means nervous climbing not descending. The extra travel raises the handlebars, so reversing the stem would help.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by lyndonchen View Post
    Oh, if we are talking about climbing thats the only time this would make a difference, I misunderstood.
    I meant while climbing, going down is stable and fun.
    ~Reformed Mechanic~
    Jan 2011
    Yup, I did the exact same thing, just flipped the stem to help a bit with climbs.
    AZ
    AZ is offline
    Are you Dremer03?
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by AZ.MTNS View Post
    Are you Dremer03?
    Im not exactly sure what that means...
    AZ
    AZ is offline
    Then you aren't Dremer03, it's just that your posts are uncannily like his. Thanks.
    ~Reformed Mechanic~
    Jan 2011
    Hum... He sounds like a pretty awesome guy
  1. 100mm fork to 120mm
    By skierdood in forum 29er Bikes
    Last Post: 05-18-2011, 09:09 AM
  2. EL REY FORK 120mm vs 100mm
    By randalnelson in forum Ventana
    Last Post: 10-19-2010, 07:47 PM
  3. 100mm vs 120mm fork...what do you use and why?
    By Okie Dokie in forum XC Racing and Training
    Last Post: 05-18-2010, 02:48 PM
  4. ASR-RLC with 120mm or 100mm Fox fork?
    By TrailNut in forum Yeti
    Last Post: 08-30-2007, 09:21 AM
  5. rx 100mm vs 120mm fork
    By srussel in forum Titus
    Last Post: 03-04-2007, 08:30 PM
Members who have read this thread: 13
