Results 1 to 12 of 12
    Feb 2018
    Worth It to Upgrade 2015 Trek Remedy 7?
    I have a 2015 Trek Remedy 7 27.5 that I would like to make lighter by replacing some parts. The bike currently weighs about 32 lbs, including a Rockshox Reverb dropper post. My goal is to drop the overall bike weight down to the high 20s lbs range.
    I am considering swapping out the following parts:
    -Upgrade the stock 2x10 drivetrain to SRAM Eagle X01.
    -Upgrade the stock aluminum handle bar to carbon.
    -Upgrade the stock grip to Red Monkey silicon grip.
    -Change the back tire from 2.35 to 2.2.
    -Maybe swap out the stock wheels to something a bit lighter.
    I don't want to get a new AM bike because I already have two other bikes in the garage and my wife would kill me if she sees me buy another bike. So I'd rather just upgrade an existing bike; this way she won't notice it .
    The bike currently has a blue book value of $1k. I don't mind spending another $2k to drop the bike weight down to the 27-28 lb range.
    I have two Open One+ that I currently ride for XC and trail riding during the week, so this bike would be used for more technical downhill stuff maybe once a week.
    So is it worth it to make these upgrades and shave off a few lbs off the bike? Any suggestions, including additional parts to replace, would be appreciated.
    Bikesexual
    Reputation: jcd46's Avatar
    I say if you are dropping 2k in upgrades, sell the bike and add to the 2k for a new bike.
    The Orange Fleet:
    '16 SC Heckler
    '14 All City MMD
    '12 Kona Unit Rigid
    Oh, So Interesting!
    Reputation: davec113's Avatar
    Sell it, the new bikes are better. I just went from '14 / 27.5" Slash to an '18 and it's much improved in every way.
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by OnePlus View Post
    Good points either way. You didn't mention if your Rem is carbon or not but if $3k(a grand from sale + your $2k budget)gets you a similar spec'd new bike "with" those upgrades you mentioned, then yes go for the new. But I doubt you will find that rig for that much. If not, you may have buyers remorse.
    One trick a buddy uses to fool the wife when he's getting a new bike is to buy one with same/similar color scheme and roll it on a quick trail ride to get it dirty before hanging up in garage!😎👍
    You may be able to find something new in your budget from an online brand like Whyte, YT, Canyon etc.
    Wait whuuut, who did he tell you that!?!?....
    Reputation: RS VR6's Avatar
    I'd just do the 1x upgrade and build up a set of carbon hoops. Those two will probably make up the majority of the weight loss.
    NedwannaB
    Quote Originally Posted by RS VR6 View Post
    Ditto this^^^. Plus maybe the switch of tires(maybe not to a 2.2 in the rr tho...)and tubeless would be a big improvement! Ride it for awhile then see how the rest of your upgradeitus plays out.
    Feb 2018
    Thanks folks for all your inputs.
    JMac47 - The bike frame is aluminum, and it is in sort of a ghastly lime green color; so I don't think I would able to get another one with the same color to fool the wife, haha. Good thought though.
    I looked up the prices for these parts, and figure they'll cost maybe $1,500 max, then figure another few hundred for labor, so I think $2000 max is totally doable. I agree with JMac47 that I don't think I'll find a new rig with similar spec. The frame is in great condition as I've never had a serious crash (knock on wood). I don't need the latest/greatest, and this is not my main rig, so I'll most likely just go with the upgrade path and keep the wife off my back .
    Dec 2014
    RS VR makes sense, this is what I'd do. Prolly buy a 1800ish gram wheelset, you can get that in alloy @ $500 neighborhood depending on hubs. $400 carbon crankset/BB upgrade and you've changed your bike to a different handling new machine. When I put a 750mm carbon bar on (45mm stem) it felt too wide for a while, until I began to enjoy how easy it makes tossing around the bike.
    oops I wasn't clipped in
    Aug 2015
    A $3000 new bike will be a lot better than your $1000 bike with $2000 in upgrades.
    Jun 2017
    Quote Originally Posted by 288GTO View Post
    Agreed with this, everything will be new, the geometry will be updated, and there's a chance that it would have better components.
    Check out the Diamondback Release 4c, you could get a heck of a carbon bike for that price.
    NedwannaB
    Quote Originally Posted by acedeuce802 View Post
    True on that rig! I have my eye on that one too. But it be a little over 30#'s from what the Bike Bible testers said which isn't bad but the op was looking to get down a couple #'s below that.
    Reputation: mrclortho's Avatar
    I just went through this. After the "long walk" home last weekend when the old bike gave up the ghost.
    I needed to seriously frame up build my Scott Scale but for the price of all of the components, I was getting into brand new bike territory. I figured about $1k-$1,200 in parts, and a new one was $1,300 off the showroom floor.
    I ended up buying a new bike and will tinker with the Scale when I find used parts or free to get her back up and running.
    '18 Scott Spark 730, 27.5+ FS happiness
    '10 Scott Scale 29er hardtail with a billion miles on it
  1. Replies: 24
    Last Post: 07-22-2015, 08:29 AM
  2. Replies: 1
    Last Post: 02-20-2015, 02:06 AM
  3. 2015 trek fuel ex8 vs 2015 remedy 8
    By Armyn Pascual in forum 27.5
    Last Post: 12-26-2014, 06:08 PM
  4. Replies: 3
    Last Post: 11-27-2014, 04:56 AM
  5. Trek Remedy Worth?
    By hawsb in forum Beginner's Corner
    Last Post: 04-29-2014, 07:44 AM
