Results 1 to 3 of 3
    just some guy
    Reputation: talabardio's Avatar
    Will a 650b tire fit on a 650A rim?
    I am just curious; is it possible to fit a 650b tire on a 650a rim like the Sun CR-18? 650A is 590 mm, 650b is 584; could a tire stretch that extra 6mm, and then still work properly?
    just some guy
    650B kevlar bead tires will fit on 700D rims (587).
    Reputation: veteran_youth's Avatar
    Nov 2006
    I have seen 700c tires muscled on to 27" rims, which is an 8mm difference in bead diameter. You can make it fit but there is no hope of it ever seating properly.
    Edit to add: multiply the difference in bead diameter by 3.1 to see how much stretch you'd need to get out of it to seat assuming rim is within spec: 6mm=almost 2cm of extra bead to account for, don't think any tire I'd trust not to blow off the correct size rim would allow this.
  1. Fattest 650b tire?
    By Miker J in forum 27.5
    Last Post: 05-07-2013, 08:39 PM
  2. 650b xc tire Q?
    By Click Click Boom in forum 27.5
    Last Post: 10-25-2012, 08:44 AM
  3. Replies: 16
    Last Post: 10-09-2012, 09:23 AM
  4. What about 650a?
    By JonathanGennick in forum 27.5
    Last Post: 06-27-2012, 02:25 PM
  5. new 650b tire...
    By zippy895 in forum 27.5
    Last Post: 12-21-2011, 01:27 PM
