Results 1 to 30 of 30
    who has converted a Blur XC?
    I am considering converting my XC. What needs to be changed other than getting new wheels and rotors?
    Reputation: reformed roadie's Avatar
    Quote Originally Posted by jimmy View Post
    I am assuming you mean the Carbon XC...the Aluminum XC is not even close to fitting. It does work well with a 650b up front.
    Try using the search function...
    Quote Originally Posted by reformed roadie View Post
    Real helpful, thanks roadie. Have you converted a blur XCc to 650b? I did search and got loads of junk. I am hoping someone who has done it would kindly reply as to what they did.
    Try searching this forum w/ "XCc".
    There's a bunch in search, Here's one
    2012 Blur XC Carbon conversion
    Thx
    Steele, thanks, that thread seems to focus on "shims". I did pm the poster, maybe he can tell me what he did. I don't see how to seach an individual forum, sorry guys.
    Reputation: nyrdrms's Avatar
    2013 SantaCruz Blur 650B build...the real deal!
    I was in the same boat as you..hard to search the forums or just too stupid to figure it out. Anyway, many have converted the Blur XCcarbon. It is awesome with plenty of tire clearence all around using a Fox fork. Mine is a 2013. Love the rear thru axle. I couldn't be happier. All you need is 650B wheels, 650B tires, Fox 100mm fork (unless you want more travel), and maybe shim the shock depending upon the frame (some say they don't need a shim, I did).
    I converted my 2012 Carbon Blur xc. Im using a 120mm Fox Float, 26er fork, American Classic 650bxc wheels with 2.2 Racing Ralphs. I did not have to shim my rear shock and it has never rubbed. I will post pics later.
    I just love my bike, the handling, the weight, etc.
    NedwannaB
    Reputation: JMac47's Avatar
    Not mine
    But I wish. If I could only gety my hands on a white blk/gold accent frame I'd be loving it.
    Hurricane Jeff may chime in on his bike here. He has 2.25 RR's on it now with no shiming required.
    650B Picture Thread - Page 16 - Mtbr Forums
    Wait whuuut, who did he tell you that!?!?....
    NedwannaB
    Too late
    Quote Originally Posted by Hurricane Jeff View Post
    Already got yours covered!
    Jun 2012
    Blur XCc conversion
    In hindsight, conversion was pretty simple. Bought a set of 650b Stans Crest wheels and some Pacenti Quasi Moto 2.0 tires. No clearance issues whatsoever on the front with the Fox forks, but did end up using nylon washers (about 3-4mm) to shim the rear shock. Otherwise, the tire would just barely touch the front deraileur cable stop at full compression. Not worth the risk, in my opinion. Shimming was very easy and worked perfectly (with very minimal loss of travel). No other changes really required and below is the result...
    Attached Thumbnails Attached Thumbnails who has converted a Blur XC?-img_0657.jpg
    I have a fox 100 and an XCc frame, not the newest version, the first carbon frame I think. Now for the shimming...what do people mean by shimming the rear shock? I am not a mechanic not an engineer so I don't really understand how that works. At full travel what happens? Thanks.
    Jun 2012
    shimming
    Without shimming (reducing travel slightly), the rear tire would come into contact with the front derailleur cable and/or the cable stop at full compression of the rear shock (bottom-out). This is not something I want to happen while riding, as it would likely damage the tire and possibly a rather expensive carbon frame.
    I don't want to tell you to search here again, but there is a thread in 650b forum where I learned all that was necessary to shim the rear shock. Hardest part was finding the nylon washers, but eventually found some at Lowe's which had 3/8" inner diameter and fit perfect. Installing just involved releasing all air from rear shock (very important), then unscrewing the air canister while still attached to the frame. Once open, just pried the o-ring and silver washer down and put the washers above that. It is very easy, but hard to describe in words. The other thread had pictures which help alot. Best of luck in your conversion and I have no regrets!
    Wrench
    Reputation: FNFAL's Avatar
    It's fantastic.
    2010 frame, size LG, full XT kit. Weighs in at 23.5 pounds.
    This bike reads my mind.
    Searching threads
    If you go back into the top of the list of threads it this forum, the search is on the right side of the lower blue bar.
    It helps to be as narrow and presice as possible. For example "XCc" works, but "blur XCc" will pick-up a lot of extra stuff, any and all mentions of blur.
    Dec 2012
    Awesome bike.
    thanks
    Quote Originally Posted by KeithASR View Post
    There is no way I could do that myself although I understand the concept of reducing the travel. Ha Ha someone needs to sell a "shim kit" for the XCc/650b.
    thanks
    Roadie that is helpful. Not he best search function I would say, but your advice has helped.
    May 2005
    Honestly, shimming a shock is as easy as changing a tyre.....don't need no kit or mechanic.
    Here's a pic of where to place this washer/shims....
    Just let the air out of the shock first, unscrew the air can, pull back air can a little, slit washers and slide over shock shaft, screw air can back on, air up shock, install and test ride.....
    Shock performance won't change.
    Too easy!
    Mine is a '12 Blur XCc, size large. Shimmed it about 4mm to clear a Neo Moto 2.1 on a Pacenti TL28 rim at full compression. Finding the nylon shims and cutting them was the most difficult part, don't even try using neoprene shims. Go nylon. Insertion into rear shock takes about 1 minute. Fork is a 2012 Fox Float 120 RLC. Maybe my favorite short-travel FS bike ever owned (and I'm not even a VPP fanatic). Bike is quick, fast and stable in any gear combo and terrain.
    wow, thanks
    Nylon shim, what is the size?
    Thanks for all the advice everybody. This may be my winter project. Ha ha, just have to get some wheels & rotors to start.
    Recommendations on lightish XC wheels?
    NedwannaB
    Can't beat Stans Crest/Arch
    Or Pacenti's line. Priciey tho. Universal Cycles has some items to choose from and can build up a light wheel for somewhat less the Notubes. You can check Outside Outfitters for Alex XD Lite 650 rims and a parts assortment of tires and hubs. I don't think they build them though.
    You keep mentioning "rotors", are you converting over to disc, or just need some new ones? The 650B wheels don't have anything to do with needing to chang rotor size if that's what you're worried about.
    rotors
    understood, just that I'd have to swap out my rotors from my 26" wheels or get new ones.
    NedwannaB
    Oh got it
    Keep wheelset complete. They're not that expensive and worth not hassling with the change out everytime.
    Fox 100m Fork
    No problems with the fork? It will fit in a 100 mm Fox?
    Thanks.
    Wrench
    Thanks.
    I've run a 2010 and 2012 Fox 100mm 26" fork with 650b with no issues whatsoever.
    Tires have been Kenda nevegal 2.1 and Neo Moto 2.1, Crest rim, Tubeless.
    NedwannaB
    We say no problem
    Thanks.
    I run them on an 80-100 a 130. But I'm only running a buck forty geared up. You should check clearences with fork empty of air. Chances are, depending on tires, they will scrub the inside crown. Installing some type of bottom out shim is the best insurance short of getting a 650b specific fork.
    Just say'n.
    I really appreciate the info.
    100mm fork
    I run the Crest 27.5 wheel with IRD FireXC tire and there is no need to shim the fork at all. Not even close to needing it. Agree with other poster that it is best to buy a couple new rotors so you are not swapping out with your old 26" wheelset. I like to swap the 26 and 27.5 wheels back and forth depending on the ride I am doing and it would be a hassle to always swap out the rotor. Shimming a shock is as simple as others stated. Don't be intimidated at all by that. I would add that you need to have an air pump for your shock, to reinflate it to your preferred setting after you have shimmed. I know people who didn't get one with their bike for whatever reason.
    Reputation: Robbo's Avatar
    Feb 2005
    Just on the shim thing - would the smallest Fox volume spacer do the same job as shimming? I'm a big boy so I have to run the air spring pretty high. I wonder if I could kill two birds with one stone? Running an L XCc V1 with straight 3x10 XT, KS LEV, a set of Sun 650 wheels and a 100mm travel fork. I found it too tall and flopsy in S/T with a 120mm fork. Utterly awesome in current spec.
    Cheers,
    Robbo
    Eat my shorts, build a bridge and get over it - Devil
