Results 1 to 12 of 12
    Which wheels should I buy?
    Trying to decide between DT Swiss M1700 30mm wide weighing 1822g. Or E1700 25mm wide weighing 1824g. The M series are trail/all mountain and E series are enduro and stronger. Which would you choose?
    Reputation: Curveball's Avatar
    Aug 2015
    Much would depend on where and how you ride. The 30 mm rim will give you more flexibility in tire choice.
    Riding Washington State singletrack since 1986
    I would pick out your go to tires and then pick the rim.
    I do about 65% high desert riding, 30% bike park and 5% down a mountain. My favorite tires to date are Vittoria Goma which have really good volume.
    Aug 2015
    Unless you're really slamming through rocks hard or you're very heavy, I'd probably get the M1700 with the 30 mm width. My wife's bike has Gomas on it and I think the wider rim should work well with that volume.
    Reputation: WHALENARD's Avatar
    Feb 2010
    My money is on the 30mm wide set. Especially if you like higher volume tires like the Goma. Those dt e splines 30 or whatever they're called are rated at 265# rider weight limit.
    It is no measure of health to be well adjusted to a profoundly sick society.
    Jan 2014
    Those DT Swiss 30mm ID rims came on my Firebird. I've been beating the shit out of them - weigh 85kg, running about 22 psi in the rear and riding some pretty rocky terrain. Mostly grade 4/5+. They're excellent! I was planning on an upgrade before I got the bike, but they're too good as is. Depending on the ratchet the hubs come with, you may want to upgrade to a 36 or 54 tooth (if it comes with 18t).
    I'm about 210lbs (95kg) with gear so both should support my weight.
    Looks they are the 18t so the engagement will be slow, but supposedly more reliable, think I read that somewhere?
    Jan 2014
    Yes, reliable but annoying if you are used to a faster PoE. Technical climbing will be where you notice it most. The ratchet upgrade is cheap and very very easy to DIY.
    Great thanks for the info. I'll make sure to do the upgrade
    Thanks for your input gents. Much appreciated. Cheers!
    Get the Ms and if you beat u the rim lace up an ex511.
    Sent from my Pixel 2 using Tapatalk
  1. Replies: 9
    Last Post: 05-07-2014, 09:27 PM
  2. What wheels should I look at before I buy flows 29?
    By curtboroff in forum Wheels and Tires
    Last Post: 05-26-2011, 01:32 PM
  3. Should i buy or should i wait?
    By carkingsheep in forum Brake Time
    Last Post: 04-04-2011, 08:41 AM
Members who have read this thread: 46
