Results 1 to 1 of 1
    Idea! SRAM Rise 40 Rear Hub Conversion STD to 12mm
    I picked up a pair of SRAM Rise 40 wheels in the 27.5 size. They came with 15mm front hub which is convertible. The rear hub was a standard 9mm skewer. I was hoping to convert it to 135mm x 12mm thru axle.
    I called SRAM and they said that hub is not convertible. Forever the doubter I took the hub apart and learned why. The 9mm threaded axle in the hub is seated in the wrong size sealed bearings so you cannot remove & replace axle. If you had the right size bearings I thought it would work. I was wrong again. The reason is the hub shell is not milled to accept the larger inner diameter bearings needed for a 12mm axle conversion. If you look at the Rise 40 wheelset with the 12 x 142 mm hub it is clearly a completely different hubshell. The only solution is to replace the hub with a 24h (hard to find) hub that has the 12mm convention already. That was my solution. Did anyone else have any solutions besides just buying a different rear wheel altogether? FYI I just finished replacing rear hub to a Reynolds 24h straight pull convertible hub it weighs 294 grams. The SRAM non-convertible 135mm x 10mm hub weighed a whopping 444 grams. Nice way to save 150 grams on my rear wheel. Please if anyone else has any other solutions please share them.....
  1. Replies: 2
    Last Post: 06-17-2013, 06:48 PM
  2. 10mm to 12mm conversion?
    By vibiker in forum Wheels and Tires
    Last Post: 03-03-2013, 06:08 PM
  3. 142 x 12mm conversion kit
    By Daniel Soh in forum Trek
    Last Post: 02-03-2012, 09:05 PM
  4. SRAM Attack grip shifters with rapid rise rear mech?
    By namaSSte in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-28-2011, 03:34 PM
  5. Asr-5 - 12mm rear hub conversion
    By charliemort in forum Yeti
    Last Post: 01-17-2011, 06:15 AM
