Results 1 to 5 of 5
    Sep 2017
    SRAM GX drivetrain on my Kona Unit X
    Hello, I want to put SRAM GX drivetrain on my Kona unit X - I know that GX casette needs XD body so I guess I will have to change rear Formula hub. I want to get DT Swiss ONE - can you tell me which one will fit ? I am not sure. My bike has Front Hub: Formula 100x9mm | Rear Hub: Formula 135x10mm
    Reputation: racebum's Avatar
    Mar 2013
    it may be worth it just to sell that bike and buy another one. wheelsets get expensive and at a minimum you need a new rear hub but you could also sell your existing wheelset and get another. problem there is you're on QR flanges where as everything now is 12x142 and 15x100 or 12x148 and 15x110.
    by the time you buy a new wheelset and the GX drivetrain, add that money in with what you could sell the bike for and it's a pretty decent amount
    another easy way to go if you want range on the cheap is shimano 11spd with the 11-46 cassette. the range isn't quite as good as eagle but you can use your existing wheelset and it costs less. a lot less. a full slx or xt conversion can be had under 300.
    Oct 2016
    Use the 1130 cassette with GX 11 speed, or Sunrace makes an 11-50 cassette for GX Eagle.
    Eat Clean and Pedal More
    www.eatcleanpedalmore.com
    Sep 2017
    I spoke with guys from Kona and here's what they told me
    "The Unit's have 10x135mm QR hubs stock. You can also convert to 12x142 by swapping the dropouts. If it was me I would probably convert to a thru axle at this point." -
    So I assume I have to convert to 142 by exchanging dropouts - then get this XD body 142 hub like DT Swiss 350 and voila My intention was not only to get that GX group but to make my wheels more stiff, I have two other bikes with thru axles and I am really happy with them.
    Never trust a fart
    Reputation: frdfandc's Avatar
    You don't need the XD body. There are cassettes out that utilize a regular freehub.
    SRAM NX PG-1130 is one for example.
    By utilizing a Non-XD cassette you will save a bunch of money. No need to get a new hub/wheel or a XD cassette.
  1. Replies: 3
    Last Post: 04-18-2015, 03:46 PM
  2. Replies: 0
    Last Post: 04-09-2015, 08:31 PM
  3. 2013 Kona Unit or 2014 Kona Unit
    By evosil98 in forum Singlespeed
    Last Post: 12-10-2014, 10:06 AM
  4. SRAM Grip Shifters on Shimano Drivetrain & SRAM Drivetrain....
    By Dragon Of The East in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-24-2012, 07:47 PM
  5. Spam: Kona Unit, Kona Honzo, Salsa Selma Ti
    By appleSSeed in forum 29er Bikes
    Last Post: 05-10-2012, 01:09 PM
Members who have read this thread: 47
