Results 1 to 12 of 12
    Nov 2016
    Specialized Enduro (Fox Float x2) - Water bottle help
    I was wondering if there was solution to this. This is the Lezyne side mount with a 22oz.
    Nov 2016
    Not sure why the photo is sideways.
    Jan 2005
    Camelbak?
    I have a very different bike with the same problem.
    Nov 2016
    Yeah, a hydration pack might be the only solution and I do have one, but apparently I don't take enough electrolytes when I ride so I was going to try to have a water bottle for this.
    Plus, on short 10 mile rides I was hoping to just run a water bottle.
    Looking into kids bottles.
    Jul 2017
    Can't do much due to the piggyback chamber from your shock
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    Contact Gravity Guerrilla, they have used a cage that will let you slide the bottle lower.
    I got some bad ideas in my head.
    Aug 2016
    I cut a piece of aluminum flat stock long enough to move the cage down a bit. Cut the 3/4" wide piece long enough to drill three equally spaced holes on the strip. Hint: Use the cage to lay out the holes, mark he center hole first then move the cage up and down the strip to mark the others. Use the top hole to mount to the bike, the center hole to mount the cage and the strip to the bike and use a rivet or short nut and bolt to secure the cage to the strip on the bottom........or just try one of these:
    https://www.worldwidecyclery.com/pro...SABEgKVH_D_BwE
    Bicycles don't have motors.
    Nov 2016
    I came across one of these Wolf Tooth Components B-RAD 2 Base Mount for about $17, so I'll give this a try and see how it goes.
    Reputation: Junersun's Avatar
    Jun 2014
    Here why I did to fit a 20 oz bottle in my front triangle. Not enduro but you can probably get away with the same setup
    Current Bikes
    2018 Santa Cruz Chameleon 27+
    2016 YT Tues AL
    2016 Banshee Rune
    Nov 2016
    Ok, the wolf tooth b-rad 2 didn't work because of the downtube and the BB, so I thought i'd try the the WT b-rad half bottle with dogbone.
    The 22oz bottle fits and fully engages the cage, with a very slight rub on the float x2 piggyback, but a 20oz bottle should fix this.
    Now the only issue I might have it the bottle sticking out the side of the frame. I'll give this a few rides to see how this goes.
    Specialized Enduro (Fox Float x2) - Water bottle help-screen-shot-2017-12-20-8.43.33-pm.jpg
    Specialized Enduro (Fox Float x2) - Water bottle help-screen-shot-2017-12-20-8.43.49-pm.jpg
    Specialized Enduro (Fox Float x2) - Water bottle help-screen-shot-2017-12-20-8.44.06-pm.jpg
    Specialized Enduro (Fox Float x2) - Water bottle help-screen-shot-2017-12-20-8.44.22-pm.jpg
    Nov 2016
    Nov 2016
    I've been on a few rides, and I don't even know the bottle there. This works for me, hope this helps someone out there.
    Took a second look and the bottle doesn't even touch the x2 piggyback
    Specialized Enduro (Fox Float x2) - Water bottle help-screen-shot-2017-12-23-9.48.08-am.jpg
  1. seat post mounted bottle cage that wont loose bottle
    By Gabe3 in forum XC Racing and Training
    Last Post: 03-14-2016, 08:28 PM
  2. Help finding water bottle cage - no mounts on bike
    By lardo5150 in forum General Discussion
    Last Post: 06-23-2015, 06:24 AM
  3. Replies: 25
    Last Post: 05-27-2015, 07:38 AM
  4. Replies: 10
    Last Post: 02-24-2014, 12:27 PM
  5. Help with water bottle cage decision
    By straw in forum Beginner's Corner
    Last Post: 08-31-2012, 03:59 AM
Members who have read this thread: 52
