slack HT hardtails?
Printable View
  • 12-13-2012
    zombinate
    slack HT hardtails?
    Greetings all. anyone know of a slack headtube frame that fits 650b in the rear triangle? I am thinking of trying to replicate the Diamondback Mason 29er, but obviously in 650b. I have a Surly Instigator frame that I might try something with, but wouldn't mind something more appropriate if it exists. Seems most of the hardtails have headtube angles north of 70 degrees.
    And yes, this would just be a "because it is there" type project.
  • 12-13-2012
    Kirk Pacenti
    3 Attachment(s)
    The Santa Cruz Chameleon works great. :thumbsup:
    These pics show the wheel location with the swinger dropouts almost all the way forward. There is lots of room to go back if one needed more tire clearance.
    Cheers,
    KP
  • 12-13-2012
    TheSchwagman
    Evil Sovereign...
  • 12-13-2012
    Fix the Spade
    Outside of custom builds the slackest hardtails I know of are the Ragley 288 (65-ish un sagged) and the BTR Belter (63-ish with a 160mm fork).
    Production Privee's Shan lands at about 66, again with a 160mm fork and Cove Stiffee's seem a tiny bit slacker now than they were.
    All the others give it a good shot, but 68 degrees is not slack anymore...
  • 12-13-2012
    durtydurham
    Cheers,
    KP
    What's the BB height on a converted Chameleon?
  • 12-13-2012
    JRR
    Yes,bb height with what fork and what size tire was that on the camy
  • 12-14-2012
    Kirk Pacenti
    This bike isn't mine, but I'll check into it for you... my guess would be 13".
    Cheers,
    KP
  • 12-14-2012
    Chromagftw
    Originally Posted by TheSchwagman View Post
    Evil Sovereign...
    Yes for the older Sovereigns with the Reynolds tubing. Not entirely positive about the 2010 + version 2's with the Tange tubing though
  • 12-14-2012
    Kirk Pacenti
    Another pic
    Here's another picture. BB height is about 13" according to the shop employee that owns the bike.
  • 12-14-2012
    dwt
    Deleted as duplicate
  • 12-14-2012
    dwt
    Note:
    A Works angled headset can reduce the HTA on a frame with straight 1-1/8 HT up to 1.5*. Up to 2* for tapered HT. There is also a slightly more expensive and more complicated "Angleset" from Cane Creek.
    This is the 1.5* Works on a 69* Jamis 650B2:
    Attachment 744949
  • 12-14-2012
    GeePhroh
    Chromag Samurai -- according to the intrawebz...
  • 12-14-2012
    StiHacka
    Has anyone mentioned On one 456 Carbon yet?
  • 12-14-2012
    bolandjd
    Yeah, that's what I was thinking. The steel 456 too. Pretty slacked out.
  • 12-15-2012
    zombinate
    Originally Posted by dwt View Post
    Note:
    I had pondered the angleset from cane creek, but it didn't appear to work with a straight 1-1/8 HT. I'll have to investigate this A Works deal further.
  • 12-15-2012
    eurospek
    2Souls "650Bee" Studie
  • 12-15-2012
    dwt
    Skidad from this forum and a bunch of folks in the AM forum recommended the Works over the CC.
    What these head sets do is angle your steerer within the HT in order achieve skacker (or steeper angle). So the steerer moves a few mm closer to the rider on top and further away on the bottom (or vice versa). The Works design takes into account HT length so the top cap ( which has external cup) has to be installed to line up with the bottom cup, which is either zero stack or EC depending your HT. The CC has spherical gimbals which interface with the bearings which make the HT length irrelevant. The trade off is that some folks couldn't get the gimbals to stop creaking and others didn't think they felt solid. So I went with Works and am very satisfied.
    Both Works and CC have HS which fit 1-1/8" straight steerers 44mm id.
  • 12-15-2012
    Entrenador
    Hey Kirk. Do you know if that forks set at 100mm or 120mm? Would love to talk to the owner about this bike and get his thoughts on it.
    Cheers.
  • 12-16-2012
    jeffw-13
    Sexy! :thumbsup:
  • 12-16-2012
    Kirk Pacenti
    Cheers.
    He's been playing with 100-140 set ups. Sam says he loves the bike and the wheel size. PM me and I will give you his email address. Fwiw, I just ordered a Chameleon for myself after seeing his bike. :thumbsup:
    Cheers,
    KP
  • 12-19-2012
    bubba13
    Carver Ti 420
    I keep looking at the Carver Ti 420 for a B9er or full 650b. The geo chart on the site has numbers that are based on a 100mm 29er fork sagged at 480mm A-C. As a 29er with a 100mm plus fork the bottom bracket is high for technical rocky riding.
    Website also says with 650b 2.35 tires the bb height is at 12.24" I called and asked what was the fork A-C used for that number. Reply was a 120mm X fusion Velvet sagged to 479mm A-C. (guesstimate) Plus, minimum chain stay length is 415mm or 16.3". A 650b 2.35 should fit without issue at that CS length.
    I am thinking this could be the perfect conversion for a hard tail 650b with a 140 to 150mm fork. With a longer travel fork I think the average bottom bracket height would be reasonable. The sagged A-C for a 150 WB Loop 650b fork vs the X fusion is about 35mm difference. Not exactly sure where that would put the BB, but guessing over 12.5" w/fork sagged 20mm.
    As a 29 front with a 120 fork and a 650b rear, both on 2.35 Hans Dampfs. The difference in wheel radius is 19mm between the 27.5 and 29 with the same tires. I have guesstimated the sagged BB would end up around 12.7" with a sagged 120mm fork.
    This could be one of the best frames available if you want to experiment with wheel sizes due to the numbers. You have your pick of almost any drop outs/hub axles you want to run from Paragon. Short chain stays. 31.6 seat post and standard BB. HT angle is set to work with multiple combinations. Reasonable price for a Ti frame etc. The only thing it is lacking is ISCG tabs. But with the new clutch derailleurs, they become less important on this type of bike.
    This could be fun :thumbsup:
  • 12-19-2012
    MMcG
    I ran a Ragley Blue Pig as a 650b Trail bike hardtail a while ago.
    Oh and I think the NS Surge is 650b ready
    As mentioned before Evil Sovereign - especially the rarer first version
    Transition Trans Am - but I think maybe only in Single Speed mode (not sure)
    Some versions of the Sinister Ridge might work (Frank the Welder!)
    Would love to try it on a Surly Instigator though. I had one of those as a 26er with a 130mm Manitou Minute fork up front and it rocked big time!
    Oh the Ragley MmmmmBop works too!
    I think there's also that Chumba hardtail frame that works
    TONS of options!
  • 12-30-2012
    zombinate
    TONS of options!
    Any feel for what the BB drop (or height) was with the 130mm fork?
    It appears that I can get close to what Kona has in play with their new Explosiv with the Surly, albeit with a higher BB. While my math skills are working well enough to figure out the Headtube angles, I am having a hard time trying to figure out the change to BB. I would imagine that with a 130mm fork, the BB drop would have been close to zero (in line with the wheel axles). If it was a fun ride like that, I think I will go forward.
    All of my experience with the Instigator, and the surly documentation, is with he frame and a 100mm fork, putting the BB at about a 1 in drop. with 26" wheels. That puts the Instigator BB close to 12", but with 650b the BB rises to 12.75", and by eliminating any drop due to a longer fork, the BB goes over 13.5".
  • 12-30-2012
    skidad
    New SC Chameleon vs Kona Explosif 27.5
    Never had a hardtail before but I'm looking at these 2 possibilities now
    Aluminum vs steel, Kona accepts 12x142 dropouts (very nice), I like the higher BB on the SC which would be about 1" higher with 650 wheels, frame only list price is $250 less for the Kona, lots of other dimensions are nearly identical and both have ISCG tabs and can take a tapered fork.
    Is the 12.1" BB of the Kona gonna be an issue here in the New England rocks is my big question/concern. Total HT newbie here but want to give it a whirl.
  • 12-30-2012
    JRR
    Tough choice, I wouldn't let the 142 sway you on the hard tail.If the kona rides like my Honza it's a nice ride.The SC looks like it would work in a lot of different formats xc,AM Hardtail.Im going for the SC since its available and I have 26 stuff to get it going till I get some 650b wheels.Dont think the kona is available yet.If you get the kona look at getting a 140mm 34 to get the BB right for your trails if the frame will take it and still warranty.
  • 12-31-2012
    matmattmatthew
    I think it's a pretty big thing to consider. Since owning a trail bike with a 142x12 I'll never go back to QR. I look at it the same way as a thru axle fork, I had my first 20mm fork in 2004 and haven't owned a fork that wasn't either 20 or 15mm since.
    But then again, if you've never ridden it then you don't know what you're missing ;)
  • 12-31-2012
    JRR
    Yes agree 100 percent on the fork ,but the rear triangle of a hard tail not so much.Flex were the chain stays meet the bb area will be felt first then seatstay to seat tube .The frames that have the rear triangle attached to the front with linkages and pivot bolts can use all the help they can get for a 250# rider
  • 01-01-2013
    bitewerks
    The '10 Evil Sovereign will do 650b. I've seen photos somewhere on mtbr. I ride a Sov & when the dropouts are pull all the way back, there's a lot of clearance. If I could afford a new fork,tires, & wheelset, I'd give it a try. May look into it in a year or so.
  • 01-01-2013
    RSAmerica
    Me and my son have been riding Jamis Dragon 650, fun bike
  • 01-01-2013
    eurospek
  • 01-01-2013
    joshboston
    That chromag looks awesome :)
    The Jamis is pretty similar to the Kona Explosif on paper. The Kona has the advantage of a modern headtube and swappable dropouts, if you care about those. It's also available as a frame-only. The Jamis has the advantage of greater availability.
    The Chameleon also looks awesome. The big advantage that it has over the Kona is that you can run it as a 26er if you decide you're not into 27.5 after all. The Kona's bottom bracket is probably too low to run as a 26er.
  • 01-01-2013
    joshboston
    @RSAmerica - I'd also add that the green Jamis looks sweet, I'm not as big a fan of the new color, not that it makes any difference to the ride :)
  • 01-02-2013
    skidad
    I agree, those are some important points to consider for the Kona and SC over the Jamis and both also have ISCG mounts. I could also use my 26" studded tires/wheels with the SC for winter use since I don't think there are any studded 650 tires yet.
  • 01-02-2013
    RSAmerica
    The head tube on the Jamis Dragon 650 is 1 1/8 which does limit the fork choices. That being said the White Brothers Loop TCR 650B fork performs great.
  • 01-21-2013
    zombinate
    Decided to try the angle headset route, and ordered a Works 1.5 degree set for the Instigator frame. This will put the HTA at 69.5, and I imagine I will be pairing it with a 120 or 130 fork (probably the White Brothers), which will slacken it out a bit more relative to the base measurements. I will update as the parts come together.
  • 07-05-2013
    rickyx5
    I have everything to building a Kona Explosif 650b. But I don't have the frame, and looks like I'm not getting one soon. I should have started the other way around, from the frame up.
    I've seen your options, the problem is that I have a tapered Fork 32 Float 27.5 120mm. So, some of the frames won't work with it.
    Also, since I have a Niner rigid Fork laying around, I was planing on converting the Kona Explosif (that I don't have) to a rigid Single Speed for racing a winter series. So I need it to have SS option.
    I know there are a lot of options on Ti, but they are just too expensive. The 456 C is an option, the SC Chamaleon is another one, but I think they are a little too slack for converting it into rigid SS racer, even with a niner fork. I may try it.
    Or I should save several dollar since I fall in love with that Pucker from Durango Bike Co. that is in the back of my BIKE magazines
    Any other one you know?? I don't care for material now (exept Ti or really expensive Carbon frames). Just to be tapered/44mm, sliders/EBB or at least BB30, 650b or 650b compatible, not too steep, not too slack (around 67/69, optimized for 120/130mm travel)
    hehehehe ... I should start drawing it and call a builder
