Results 1 to 3 of 3
    Nov 2017
    Shock N Roll Shock pump
    Hey fellas,
    Im new to the mtn bike world. I have a issue that i need some help with. My fork and shock are feeling a little soft and i seem to have a little to much sag right now, so i got a Shock N roll shock and tire pump, i put it on, switch it to shock mode, pump it, but air is comming out of the back of the pump. What the heck is going on???
    Reputation: Junersun's Avatar
    Jun 2014
    Not specific to this pump but I've accidentally pushed the air release when I try to push air in (rookie mistake).
    If that's not the case, maybe you have a leaky seal. Return it, get a lezyne and be done with pump problems
    Current Bikes
    2018 Santa Cruz Chameleon 27+
    2016 YT Tues AL
    2016 Banshee Rune
    From the info on Topeak's website, I assume the Shock N Roll is a two chamber pump. The large volume/low pressure chamber and a low volume/high pressure chamber are used together to fill tires. When filling shocks, the pressure from the high volume chamber is dumped ("out the back of the pump") and only the high pressure chamber is used.
    Sounds like your pump is fine. Where you able to to fill your shock and fork?
    My Joeblow Ace floor pump works the same way only it has 3 chambers.
  1. Replies: 2
    Last Post: 08-19-2013, 07:23 PM
  2. shock pump vs regular pump??
    By Luckyr in forum Beginner's Corner
    Last Post: 10-22-2012, 01:05 PM
  3. Floor pump as a shock pump?
    By AZGroundPound3r in forum Shocks and Suspension
    Last Post: 05-12-2012, 05:00 PM
  4. A 29er will roll over and a 26er will roll you over
    By Senor StrongBad in forum North & South Carolina
    Last Post: 07-22-2011, 08:13 PM
  5. Pump Pump Pump Pump POP!!!!!!
    By prowlus in forum Scott Sports
    Last Post: 06-25-2011, 05:34 PM
