Page 2 of 2 FirstFirst 1 2
Results 26 to 42 of 42
  1. #26
    May 2005
    I'd feel right at home out there
    2013 Banshee Spitfire V2 650b
  2. #27
    Go ride!
    Dec 2011
    Quote Originally Posted by Gripo View Post
    I tried a 2.35 NN in my 32 Fox Float and it clears the back of the crown (closest part of the crown) by 7mm.
    It cleared a medium TRc rear end by a similar distance, definately a dry weather tire.
    Also it was a heavy sucker at 710g especially after running a 510g 2.25 RaRa for the last 18mths up front.
    Needless to say it's not staying on the bike!
    I'm looking forward to a 600g or there abouts 2.25 NN, anyone seen one yet?
    Of the three newly released 650 Tires that we just got:
    Nobby Nic 2.35 692g
    Rocket Ron 2.10 428g
    Rocket Ron 2.25 528g
  3. #28
    Just fitted a front only 650b Schwalbe Hans Dampf. Weight is 838g and the diameter is 705mm fitted to Flow EX wheels and inflated to 26 psi. This is about 10mm bigger than the 26" tyres I was running (Conti 2.4 Rubber Queens). They roll really well, nice grip in corners and are super fast downhill.
  4. #29
    Feb 2012
    They HDs are over 200g lighter than the Rubber Queens, that should make a difference somewhere.
  5. #30
    The MTB Lab
    Reputation: pastajet's Avatar
    Quote Originally Posted by StiHacka View Post
    Hmmm. He reported "Just fitted a front only 650b Schwalbe Hans Dampf. Weight is 838g ..."
    According to my measurements...
    Hans Dampf 26x2.35 - Weight: 806 and 784 grams
    Rubber Queen 26x2.4 - Weight: 826.8 grams and 829 grams
  6. #31
    Feb 2012
    Quote Originally Posted by pastajet View Post
    I was comparing 650b HD vs. 26" RQ. Shame on me for a sloppy research job but Continental reports the weight between 870 and 1110g, the UST being the heaviest one.
    Continental Bicycle -Rubber Queen/Trail King
  7. #32
    The MTB Lab
    The UST version are pigs...
    Conti RQ measured:
    2.4 UST - 1132.8 grams and 1129.1 grams
    2.2 UST - 801.4 grams and 802.4 grams (not the newest version)
  8. #33
    I would like to hear from somebody that has used HD's in 26" and 650b. What are the differences in performance ?
  9. #34
    Reputation: brankulo's Avatar
    Aug 2005
    what fork? is it HD 2.35?
  10. #35
    Reputation: in the trees's Avatar
    Mar 2005
    I now have a 650b HD mounted up and ready to go (Fox 34, HD, i23). And I've been on front and rear 26" HDs for the better part of this year. About 1.5 miles in on its maiden voyage today, I shattered my rear derailleur. So no real review or comparisons from me just yet.
    It pushed real nice through the woods, though!!!
  11. #36
    Quote Originally Posted by brankulo View Post
    BOS Idylle SC. 2.35's
  12. #37
    So, will th HD's fit in a 26 inch fox?
    Thanks in advance
    Cptjack
  13. #38
    The 650B NN 2.35 fit fine on the 26" Fox 36 TALAS/FLOAT/VAN
    Is there more room in the 36 Fox forks than the 32s ?
  14. #39
    The MTB Lab
    Quote Originally Posted by shutterbug67 View Post
    Not sure, the only Fox 32 fork I have is a 6 year old FLOAT, that has a 9mm axle. I would assume that Fox uses the same basic shape for their forks, and the 36 would just have more material? But that's a guess.
  15. #40
    HD fit a Velvet? Inquiring minds want to know...please!
    We Ride In God's Country!
  16. #41
    650 HD + Fox 36 (2011 model and up)?
    Anyone with a 650 Hans Dampf front tire having clearance issues with a 2011 and later FOX 36 fork?
    From reading around there should be 3.5 - 4mm from bottom of fork arch to top of middle tire lug.
    Just need to confirm before pulling trigger on the rubber.
  17. #42
    Anybody know if a 2.35 NN would fit a 32 RLC 100 Fox Fork? I am probably more likely to run a 2.25 NN but just curious if the 2.35 would ever even be possible. Figuring out the limits to my options. 2.35 HD too much tire and too heavy for me.
