Results 1 to 7 of 7
    May 2018
    Running a 29" fork on a 27.5" frame?
    Hi fellas,
    My friend is looking to upgrade his bikes forks and had a question that I couldn't help him with, so I thought his was the right place to come!
    He has found two different forks for his 27.5" frame bike, both with 120mm travel, same as the stock one. The problem is one is a 29" fork, and he can get it for a much better price than the other 27.5" one.
    He was asking if you can run the 29er fork on the 27.5er frame without having to worry about putting too much force on the head tube?
    Is there anything else that he would have to worry about with this combination?
    Jan 2005
    It wouldn't put excessive force on the HT or anywhere else, but it will jack up the front of the bike by almost an inch.
    Nov 2017
    Quote Originally Posted by RonSonic View Post
    What he said. Basically it will slightly mess with the geometry of your bike a bit but thatís about it. Iím assuming youíll be keeping the 27.5Ē wheel on there. If so it wonít be an inch increase. I currently am using a 29Ē fork with a 27.5Ē wheel on my bike and it works perfectly fine for me.
    Reputation: R_Pierce's Avatar
    May 2017
    The offset is likely different as well. Which will more than likely be noticeable in the handling department. Still, depending on the price difference it may be well worth it.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    It will slacken the head angle and raise the bb. Raising the bb will make the bike more stable in a straight line but less nimble in the corners.
    Oct 2013
    FWIW: My Heller Shagamaw GX-1 27.5+ came with a 29er fork, for the very reason that I can alternatively run 29er wheels on it if I want to.
    Heller Shagamaw, Salsa Warbird, All-City Nature Boy, Focus Marex CX, Cervelo C3...it'a all good
    It will slacken the seat tube angle, too. If he already has his saddle pushed forward that could be a problem. If not, it will probably be okay.
  1. Anyone try 26" fork running 24" wheel with brake post extenders
    By Birdman in forum Families and Riding with Kids
    Last Post: 08-27-2017, 05:04 AM
  2. Replies: 16
    Last Post: 02-05-2015, 06:52 PM
  3. running a fox 26" fork on a 27.5" bike
    By blantonator in forum 27.5
    Last Post: 04-13-2014, 11:04 AM
  4. Replies: 1
    Last Post: 10-24-2011, 12:24 PM
  5. Replies: 0
    Last Post: 10-16-2011, 10:12 AM
Members who have read this thread: 53
