Results 1 to 23 of 23
    Ritchey Timberwolf build
    Yes I pulled the pin and got another Ritchey frame.
    This time a large Timberwolf in the brightest orange around.
    Now the build starts, but firstly I need forks & wheels.
    Forks?? I'm liking the 018 Fox34 Factory edition. But I here that Fox may be coming out with a step cast version is this true?
    RS Pike/CC Helm/MRP Ribbon are other options but they are a little fat for my first choice.
    Wheels; Re spoke my Hope Pro 2's with new rims (Stan's Arch Mk3), or a set of Stan's Arch Mk3 wheels. But lots of options out there for carbon rims etc. In the mean time I'll either use the Valours from my Spark or custom hope Pro 2/Crests from the P-650b.
    I will update as the build progresses but if anyone has another Timberwolf build be great to see pics etc.
    Cheers
    Conrad
    Attached Thumbnails Attached Thumbnails Ritchey Timberwolf build-25627001_10155986559799140_7656370387885027579_o.jpg
    Starting the build, will keep with an orange/black colour theme.
    Attached Thumbnails Attached Thumbnails Ritchey Timberwolf build-26961900_10156071826229140_2121694014875257024_o.jpg
    I like using a tough alum rear wheel and a light carbon wheel in the front on my hardtail. The al wheel smooths out the ride some.
    I've opted for a MRP Ribbon air fork set to 140mm travel, 100mm axle. Ordered and now awaiting delivery (about a month).
    The Ribbon is the best work of 2017 so the logical choice in a market full of Pikes & 34s (yes I like to be exclusive). Plus the all black livery suits the build. I can then save my RLC for my P-650b.
    Reputation: joshhan's Avatar
    Mar 2011
    Just ordered a Timberwolf frame myself. How is climbing on the bike with 140mm of travel?
    Bikes, lots'o bikes
    Quote Originally Posted by joshhan View Post
    I haven't finished the build yet. The MRP Ribbon came in 110 boost. So have to get a new front hub.
    Also added one of the Ritchey Kite droppers. A nice bit of kit too.
    So its a work in progress.
    Went with a m8000 180mm crank with a Blackspire oval 30t ring. I've run the ring on my Spark & SS and they are good.
    Mar 2011
    Gotcha.
    Did you think about trying your current wheel with the 2x 5mm spacers?
    Bikes, lots'o bikes
    Gotcha.
    Yes I did, I can get a spacer kit (2 end caps & a rotor spacer) for my Hope pro 2 evo wheel, but not for my Stans Valour one. The Hope has a Stans Crest rim so that might be a bit soft for the intended use of the Timberwolf.
    With every fork now a plus size one all the older hubs have to be spaced up or replaced. Oh the joys of owning a bike!
    The Wolf thus far. Need to add the dropper and change the bars/stem to my 55mm/RSR Enve combo. Brakes/rotors to add and that front wheel.
    Attached Thumbnails Attached Thumbnails Ritchey Timberwolf build-dsc_0009-1-.jpg
    Jan 2015
    I'm surprised more people aren't riding this bike - frame has great details, the geo is slick, and the complete build seems like a great value.
    Also I just saw they dropped the Shimano brakes for SRAM Guide and the price went down to $1898. Although I'd rather have the Shimano brakes, unreal deal.
    Quote Originally Posted by jtbadge View Post
    I know, guess steel slack hard tails are out, everyone wants a 27.5+ fully or HT. Marketing etc and their cheap.
    The Wolf is only available here in NZ as a frame set and even then they only brought in 6 (2 S, 2 M & 2 L) makes them very exclusive to own here!
    Feb 2017
    I just bought me a Ritchey Timberwolf frame and excited to share build progress and info with other timberwolf riders!! I got the Timberwolf frame w/ Cane Creek 40, 2018 Rockshox Pike 140mm Boost Debonair, Magura Mt8 racelines, and a Sram X1 1400 gxp crank ($1500 spent at this point)... Everything i've bought so far is new except the pike and Magura's having one ride on them ! How do you guys feel about carbon rims on a hardtail? I like light wheels, but I also like sweet deals .
    Added the Kite dropper & 55 enve stem, plus the XTR shifter. Slowly coming together. Needs the enve RSR bars of my SS though, not the Pro XCR ones currently on it. May swap my Hope Race X2 brakes over from the SS too. Hve the option of getting a 2nd hand set of Hope Tech 3 quad piston brakes with 203 & 180 rotors. But they might be a bit more brake than I need being 57 years old. Ritchey Timberwolf build-dsc_0012.jpg
    Reputation: Klainmeister's Avatar
    Question for you guys that may have a medium frame: what's the size range? Friend of mine is 5' 6" and based on reach/standover, seems like the 17 is probably the way to go for him....
    Klainmeister I'm 6'2" so I got the L or 19" frame size. My seat post height is 760mm from the top of the BB shell to the top of the seat inline with the seat tube & post.
    So yes a medium or 17" for 5'6" would be good with a 35-55mm stem depending on his reach.
    Mar 2011
    Have on hand:
    1) frame
    2) fork
    3) dropper post
    4) cranks
    5) wheels
    Waiting on:
    1) headset
    2) brakes
    Once I have everything on hand, I'll be transferring the 11 speed drivetrain (minus the cranks) from my Gnarvester and the stem/bars to the Timberwolf. The Gnarvester will be going back to SS duty.
    Can't wait for the first ride!
    Bikes, lots'o bikes
    Hmmmmmmmmmmm good on you.
    I'm going to order the MRP bolt up front axle & a WB-17-5107 rear bolt up to replace the DT-RWS/Ritchey QR. I like the clean lines of bolt ups and it sheds a bit of weight and means the wheels are harder to pinch.
    Mar 2011
    For those running an internal dropper post, is there another cover for the port? It seems kind of corny to be running the housing out of the huge opening where water could get in too easily. Pics maybe?
    Edit: Nevermind, found the cover with the cable housing clamps. I usually never use those because I prefer zip ties.
    Bikes, lots'o bikes
    yes the cover in in there, makes sense and is a tidy design. Better than an external cable dropper for sure.
    Mar 2011
    Haha yeah. After I thought about it for a bit, I decided to look for that little plastic baggy.
    In any case, got the headset and started putting things together.
    Was disappointed to see the mounts for the shifting cable aren't meant for full housing. Ordered some Problem Solvers stick on mounts to try out.
    Bikes, lots'o bikes
    Joshhan, looking good. What size is that?
    I know it doesn't factor, but does anyone have a actual weight on one?
    Thanks,
    Jon
    Mar 2011
    It's a small frame. Weights vary so much if you're building from frame up. I can weigh it when it's done with a component list. I'll be happy if it comes in at 30 or below.
    Almost done. Just need to swap out axles on the rear wheel and tune up the rear derailleur and she'll be ready for a test ride!
    Bikes, lots'o bikes
    Mar 2011
    All done. She comes in at around 28 lbs. Quite a surprise.
    2014 Fox 34 140mm
    Small frame
    SLX brakes
    XTR trail pedals/cranks
    XT shifter/derailleur
    Syntace stem/bars
    Race Face Aeffect wheels
    Maxxis Ardents 2.4
    XFusion dropper
    Bikes, lots'o bikes
  1. 17in Ritchey Timberwolf. Hoping for help re dropout spacing....
    By vintageman in forum Vintage, Retro, Classic
    Last Post: 10-31-2016, 04:53 PM
  2. Ritchey Timberwolf 650b frame
    By conrad in forum 27.5
    Last Post: 08-29-2016, 01:12 AM
  3. 1987 Ritchey Timberwolf
    By YakimaDeathYaks in forum Vintage, Retro, Classic
    Last Post: 09-17-2013, 03:14 PM
  4. 1987 Ritchey Timberwolf help
    Last Post: 08-15-2013, 07:31 AM
  5. 1985 Ritchey TimberWolf #1B35 (tons of pics)
    By -Anomie- in forum Vintage, Retro, Classic
    Last Post: 11-13-2012, 08:40 PM
Members who have read this thread: 103
