Results 1 to 3 of 3
    Mar 2018
    Replacing fork with shorter travel?
    Is it possible to replace my current stumpjumper 650b 150mm fork with a 130mm fork? I'm looking a Pike but I want to achieve better climbing. So essentially I'm thinking in "camberizing" my stumpy. Or should I go with the 150 pike?
    On most forks you can alter the travel without too much work.
    Sent from my Pixel 2 using Tapatalk
    Nov 2016
    My SJ is a 29er, but I originally had the 150mm Revelation reworked to have 130mm because I couldn't keep the front wheel down climbing. Now I have a 140mm Pike on it, and I like that.
    I realized later that my main problem was the seat post angle. My seat is extended almost all the way up, and that put my seat too far back. I solved that problem by turning the dropper post around backwards so the offset is forward. It looks kinda silly, but my center of mass is where it should be now.
    2016 Fuse Pro 29/6Fattie
    2017 Stumpjumper Comp 29/6Fattie
  1. Moving from longer travel to shorter travel question?
    By socalMX in forum General Discussion
    Last Post: 06-22-2015, 01:05 PM
  2. Does shortening the travel make my Fox fork shorter?
    By turbogrover in forum Shocks and Suspension
    Last Post: 07-21-2013, 09:03 PM
  3. Replies: 34
    Last Post: 06-30-2013, 09:24 AM
  4. Replacing a fork with shorter steering tube length, do it or not?
    By paries127 in forum Shocks and Suspension
    Last Post: 04-05-2013, 10:08 AM
  5. Replies: 5
    Last Post: 01-24-2013, 09:02 AM
Members who have read this thread: 27
