Results 1 to 8 of 8
    Sep 2017
    Rear wheel suggestion for 148 boost
    I seem to keep denting giant stock (xct1) rear rims on my 2017 trance2. Can anyone recommend a more heavy duty rear wheel than the giant factory stuff?
    Do carbon rims stand up to more abuse than aluminum rims?
    Reputation: brent701's Avatar
    Sep 2012
    Quote Originally Posted by tommytman View Post
    Yes on Carbon,
    Look at Light Bicycle US, or Nox rims. The rim has nothing to do with the hub size. You want to get a boost spacing hub in 12x148 if that's what your bikes spacing is.
    I love my Nox rims and I9 hubs
    Too Many .
    Are you running the right pressure for your weight and riding?
    Tallboy 3.1
    OG Ripley v2
    Reputation: MSU Alum's Avatar
    Yeah, seems as though your pressure could be too low....and yes on carbon also.
    Reputation: Little_twin's Avatar
    Feb 2016
    Giant rims are garbage. Pretty much anything will be better. Hope wheels from crc are a great value. I recently got a bontrager line elite to replace the xc 1 rear on my anthem and have been very impressed with it as well.
    Sep 2017
    Quote Originally Posted by Little_twin View Post
    Thanks buddy. I started a thread in the wheels section since I thought it was a better place for it. I didn't see the wheel forum the first time through. Sorry about the double post.
    I am about 180 lbs. I keep the rear wheel at 32 psi. I have a 2.20 hutchinson cougar tire on there right now in tubeless mode. The tire is pretty tough and at 32 psi I do not believe that is the issue.
    I've been looking at wheelbuilder and colorado cyclist. They seem to have good selections of rims, hubs, etc. Right now I'm thinking of a 350 DTswiss hub with a EX471 DT rim. At this point I could pick a carbon rim.....I just need to figure out which one to pick.
    Although potentially not related .....we once used aluminum arrows for archery. They always bent and exploded if you missed the target. When carbon fiber arrows came along the whole thing changed....those carbon fiber arrows are really tough and outlast aluminum ones by a lot. So this is why I wondered if it is a similar situation for aluminum vs. carbon rims.
    BTW who is crc?
    Feb 2016
    BTW who is crc?
    Carbon is plenty durable for rims, but so is aluminum. It just depends on your budget. High end aluminum rims just aren't as stiff as carbon.
    Crc= chain reaction cycles
    Reputation: djevox's Avatar
    Nextie carbon wheels with dt350 hubs can be had for 800-900 depending on options. Thatís about the price of a good set of alloy wheels with good hubs and spokes.
  1. Boost 148 rear on a 142 frame
    By Davide in forum Wheels and Tires
    Last Post: 06-01-2018, 09:29 PM
  2. XC bike with boost 148 and boost fork?
    By La Nada in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 04-08-2017, 06:04 PM
  3. 12mm x 142/148 boost rear ends
    By MannaDesigns in forum Frame Building
    Last Post: 03-10-2016, 12:40 PM
  4. Boost 148 rear triangles?! To purchase
    By Mayor69PRS in forum Niner Bikes
    Last Post: 11-15-2015, 01:13 AM
  5. Replies: 6
    Last Post: 06-24-2015, 05:06 PM
