Results 1 to 7 of 7
    May 2016
    Question on 1x11 swap
    I have a gt sensor elite am thinking about going to a 1x11 set up. Here's my question... stock is the fc-m612 crank set... I'm looking at going with the xt fc-m8000-1 crank set. Does anyone know offhand if my current bottom bracket will work out is the only way to know too try?
    Sent from my SM-G950U using Tapatalk
    Dec 2017
    Both are 24mm hollowtech cranks, so should work fine with the same bb. You should be able to convert the fc-m612 to 1x though by removing the inner and outer chainrings and replacing the center one with a narrow-wide ring, so no need to replace the whole thing.
    May 2016
    Cool... so I'll try it 1st with my cranks and make sure I like the chain angle.
    Sep 2015
    Definitely try your existing cranks first. Sometimes the 2x and 3x cranks can give a nicer chainline anyway, it depends on your specific bike. Plus you can often play with the spacers/washers either side of the BB - technically it throws the cranks a little off-centre, but you'd struggle to notice in practice.
    Reputation: armii's Avatar
    Jan 2016
    I converted my 3x by removing the small ring, replacing the middle ring with a narrow wide, and replacing the big ring with a bash ring, that kept the chainline right in the center where it needed to be.
    Reputation: SteveF's Avatar
    Yeah, if you have a triple crank, just take off the 3 old rings and put a narrow/wider ring in the middle ring position. Easy!
    May 2016
    Damn, already bought my front chain ring
  1. SRAM GX 1x11 chain length and setup questions, sram has no definate on 1x11
    By bertrenolds in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-25-2017, 03:32 PM
  2. 1x10 or 1x11 for a bike that was setup as 1x11?
    By Central Cal Rider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-24-2016, 09:01 AM
  3. Deora 1x11 swap
    By Bfear414 in forum 29er Components
    Last Post: 05-19-2016, 06:58 AM
  4. swap from xt 2x10 to 1x11
    By demarp in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-14-2016, 06:34 AM
  5. EX8 1x11 Swap
    By Alksion in forum Trek
    Last Post: 03-18-2016, 04:36 AM
Members who have read this thread: 4
