Results 1 to 2 of 2
    Pivot Mach 5 conversion????
    Anyone out there convert their Pivot Mach 5 to 27.5?? I've seen some threads on the 5.7 being converted, but nothing that would suggest it's do-able on the Mach 5. Any input is appreciated.
    Reputation: kleinhead's Avatar
    Nov 2008
    I converted my 2009 Mach 4 (front and rear) over a year ago. Just enough clearance in the rear for a IRC Fire 2.1. No issues with rubbing when rear is fully compressed. My results have been all positive.
    Would need to review the geometry of a Mach 5, but if rear triangle is similar to a Mach 4, you may be able to squeeze a 27.5 into your M5.
  1. Pivot Mach 427 - Mach 4 conversion
    By kleinhead in forum Pivot Cycles
    Last Post: 03-24-2015, 02:14 PM
  2. Replies: 6
    Last Post: 10-13-2013, 10:04 AM
  3. Replies: 26
    Last Post: 09-27-2013, 01:55 PM
  4. Pivot Mach 5.7 pivot periodic maintenance
    By LeeL in forum Pivot Cycles
    Last Post: 07-10-2012, 10:03 PM
  5. Replies: 1
    Last Post: 05-21-2012, 06:37 PM
