Results 1 to 29 of 29
    Reputation: trailbildr's Avatar
    Dec 2004
    Pike 275 Now Available
    I'm looking at a popular distributor with Pike 275 forks in stock. 2 of them, actually. A bunch got snatched up today already.
    Just letting y'all know that they should be available in general, all over, in the coming weeks.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    Reputation: highrustler's Avatar
    Grabbed a 160mm Solo today! Gonna sell my Float 34 from the Bronson...
    Cool. Would really like your thoughts on both the Pike and the Bronson geo at 160mm vs 150mm. Thanks.
    -Shane
    Quote Originally Posted by highrustler View Post
    Why are you ditching the F34 for the Pike? Is the F34 that bad, or do you just wanna try something different already?
    it's the ride....
    Quote Originally Posted by mastakilla View Post
    Same question here: Trying to figure out if I should get Pike or F34 for my 160mm fork to lighten my bike for a trail day.
    Would be great to hear feedback on any of them.
    Ulating blencong sejatine tataraning lelaku...
    Reputation: DJ Giggity's Avatar
    Quote Originally Posted by softailteamrider View Post
    I spent a day on a 150mm Float 34. It was garbage. The small bump sensitivity was really poor even in descend mode. My baseline for comparison is a Float 36 RC2 FWIW.
    Only two infinite things exist: the universe and stupidity. And, I am unsure of the universe
    - Albert Einstein
    Just ordered a Pike Solo Air 150mm, there were 3 left (assume my shop deals with QBP as BTI shows out of stock on all versions) so now there be 2.
    Going from my lowered Fox 36 180 Float to the Pike I'll be dropping 549g, that's some serious weight!
    it's the ride....
    Quote Originally Posted by DJ Giggity View Post
    Thanks for your feedback DJ. I got the impression from reading it somewhere the first iteration of Float 34 was not enough damping and tend to dive even with low compresison cranked up (Climb mode?) and Fox revisited it on 2014 model for better damping.
    What model year was your Float 34?
    it's the ride....
    Quote Originally Posted by kburati View Post
    Give us your thought comparing both forks. *thumbsup*
    I got an old Van 36 160mm, and always want to lighten it a bit. But also I'm not sure if I will feel a loss of stiffness coming from 20mm TA to 15mm.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    You'd notice far more difference with a straight 1.125 steerer vs a 1.5 lower steerer in terms of fore-aft flex and big crowns in terms of lateral, and of course for torsion the axle is important, but those crowns and stanctions do a lot by themselves and make the 15 vs 20mm aspect a mute point IMO. 20mm would be nice for standardization, but you aren't really giving up much, the real gains on those forks are from the other areas. I had a lot of DC forks back in the day, and a quick release DC fork like a manitou X-vert or Jr T was far stiffer than a 20mm axle single crown fork. Although you want a thru-axle due to how it clamps, 20 vs 15 shouldn't make much real difference.
    It was on a Bronson. I would assume it was the 2014 but I don't know for sure. Once you got it moving it didn't feel under dampened like some complain about with the 2013. Had it been mine I would have cracked it open to make sure it had enough bath oil. It had the feel of one that did not.
    I have also tried a couple of 2013 32 talas forks. Those felt sticky and then under dampened. I thought it was just the talas version.
    - Albert Einstein
    it's the ride....
    Jayem.. Thanks. Make more sense, as the TA will be clamped static (in term of fore-aft movement) with the hub. If any flex it must be coming from wheel or steerer deflection.
    Can anybody who has gotten one of these tell me if the lowers are centered or not?
    My last RS fork had off centered lowers and I was looking at the Pike promotion video on Youtube and lowers looked off centered on that video.
    I'll definitely report back with a comparison but Jayem below is probably correct in that the Pike will have less flex as it's a 1.5 lower steerer where my 36 180 is a straight 1.125.
    May 2005
    Decent price. Cost is around $665 for that fork.
    Dec 2004
    My big issue is justifying the Pike over the Revelation. I have a Revelation 26 that I've been running on my 275 bike for about a year now and really like it. Damper is easy to service, the low speed compression adjust provides some great settings for my riding style and it's stiff enough.
    I really want to check out that Charger damper though. The FiT damper in the Fox forks is pretty nice and seems to be very robust.
    Poor me, right?
    mk
    TrailWerks Cyclery
    UPS man just stopped by:
    Dec 2004
    Sick. Looks dope all murdered out...
    mk
    TrailWerks Cyclery
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    RCT3 and damping....
    Ayone else out there think the middle, "Compresion/Trail" setting on the RCT3 forks feels way too harsh?
    My Revelation feels too harsh in that setting, but I've heard they reworked the Pike so that is improved. If I knew that to be the case I'd be looking at buying one but I'm skeptical after my experience with the Rev.
    After folks ride the Pike how about re posting with a report on these issues please.
    Thanks.
    Got the new Pike setup last night, bike is now 26 lbs 8 oz with the Pike vs the 27 lbs 11 oz with the lowered Fox 36 Float 180. Good amount of oil on the stanchions when you cycle the fork, hope that's simply because it's new and this isn't an issue. Been pouring out past 12 hours and continuing on today so hopefully get out on this tomorrow/Thursday.
    I sweep myself
    Reputation: slomo's Avatar
    Note to self - Do not read MTBR without adequate amounts of morning coffee. When I first read this I pictured fork oil pouring out for 12 hours...doh...
    "In the past few years there has been building up within me an obsession that the only way to piece of mind is to go somewhere in the desert, far away from things, and just sit down." - Ernie Pyle
    This is a GOOD thing! Just about every fork, especially Fox are inadequately lubed from the factory, causing unnecessary stiction. I always have Dirt Labs service my forks before installation, but think the Pike may not need it.
    Jun 2013
    Does anyone know if the Pike can be lowered (with spacers), and if so, is it an easy process?
    Quote Originally Posted by White Bear View Post
    I don't know, find it hard to believe there would be any difference between the 160mm version and the 150mm version other than a spacer but that's just a guess. I'd assume you could reduce travel with spacers just like the other Solo Air forks.
    First ride report for the Pike, didn't stop raining for long so it was a very wet ride on slippery roots and rocks so not the perfect conditions but here goes. For my setup anyways the RS air guide is too high. Fork leg says 105-120 psi for 160-180 lbs and I'm on the heavier side of that range but started at 105psi. Entire ride I didn't use more than 60% of the travel, didn't do any drops but some fast downhills on pretty rough sections, expected to see the red band another inch up the stanchion. Fork tracked well though would probably have impressed me more if I switched to it directly from the Revelation I rode all last year, instead I've been on a lowered Fox 36 180 20mm thru axle for the past month and a half so I didn't notice any stiffness increase. Absolutely no fork dive and very good manners climbing. Need to get the psi right and try again on a day where I'm not getting soaked so I can mess around with it some more.
    Keep on Rockin...
    Nov 2003
    Thanks for the report.
    I'm having a hard time getting any word on how the Compression/Trail mode feels. Can you fill us in?
    The Revelation I'm using is OK in Open mode, but way too harsh in Compression/Trail mode, making the fork usable only in a small range of its intended settings.
    I'm interested in a Pike but not if it has the same issue.
    Quote Originally Posted by Miker J View Post
    It felt OK in the trail mode though I hope this weekends ride is 1000x better. It was raining so hard that when I hit things at any sort of angle there was just as much, if not more, sideways slideout as there was compression. Superb singletrack has morphed into running streams here in MA. I used the compression mode on the road for a little while but not on the trail. Never ran it open, not yet. Let me get the PSI right, pray for a couple days of sunshine and take the bike down to some trails that drain much better than my local ones to give it a real test.
    Dec 2004
    I have the .pdf from the SRAM media release in Sedona and it shows that the 'open' mode has an adjustable low-speed knobber on it. I'm guessing that the full open setting on that should be plush and dive, if that is what you are after. And that's low-speed so it shouldn't affect your hits too much, just brake dive. It seems like the primary goal of the new fork/damper is to keep you up in the travel. I'm confident that you should be able to get the desired feel out of it. The adjustment in the past has been very good.
    mk
    TrailWerks Cyclery
  1. Replies: 12
    Last Post: 04-25-2013, 04:07 PM
  2. Pike 454 noise
    By trailshdw in forum Shocks and Suspension
    Last Post: 04-15-2013, 02:58 AM
  3. PIKE 351 is wet...
    By chelboed in forum Shocks and Suspension
    Last Post: 09-07-2012, 04:23 PM
  4. pike 426 help
    By blindman22 in forum Shocks and Suspension
    Last Post: 11-28-2011, 03:34 PM
  5. HELP!: RS Pike 409 vs 454... Deal? What do you think???
    By juancho142 in forum All Mountain
    Last Post: 08-04-2011, 05:31 PM
