Results 1 to 45 of 45
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Peeled my Neo off my ZTR355
    Funny that another poster mentioned blowing his Neo off a ZTR while inflating it...and causing the rim to go out of true. Saturday on a long ride on my Nomad with Neo/ZTR in front, I was cornering into a bermed corner at a pretty good speed. The bike started trying to turn into the inside of the berm, so I pushed it back out a bit. This trail is on a dirt motor ranch with some outstanding bermed corners. At some point in the corner the bead of the tire let go, and down it went. This was all dirt, and I was wearing body armor, so not even a scratch. I was surprised to find my ZTR had a slight wobble...nothing a fairly easy truing won't address, but wobbly nonetheless.
    I use an Olympic rim strip with my Neo and had plenty of Stan's in the tire. I've used this combo for several months with no issues. I am not Steve Peat, but I tend to ride my bike a little more dirt motor style because that's what I'm used to. I've been leary of this completely built Stan's wheel from the start, because I really feel it's more of an XC setup. I was really happy with the Blunt I started out with on the front of the Nomad a year ago, but the undersized rim resulted in a couple of failures...again...thank goodness for body armor. I'm not freeriding my Nomad...just aggressive trail. I ran that Blunt setup on my Nomad at Moab for a couple of weeks with a tube installed with no problems, but I refuse to go back to tubes. I'll go back to straight 26'er stuff before I have to run tubes again. I'm thinking of trying a ghetto setup on my Blunt wheel like Rainman has had success with. I'm thinking it may make a better bead/rim interface with the way the split tube fits the rim and tire.
    I'm also still waiting on the Kenda Nevegal to see if there is an improved fitment at the bead. The Neo is an absolutely awesome tire, but one of these days I'm gonna have a blowoff resulting in a worse crash than I've had so far. I can honestly say that I haven't had a blowoff with any of my rim stripped 26'ers, so I'd like to experiment with another tire or two to see how things go. It seems I have fairly lengthy periods of reliability with the two Neo tubeless setups I've used, but I have zero blowoffs with 26'ers...most of them non-UST like the Neo. It's a bit disconcerting. I'm still not totally impressed with the fit of the Neo to either the ZTR or new Blunt. I'm also thinking about using a 650B CR18 rim I have to build a wheel. The fit on this rim and the Neo seems much more appropriate to me.
    www.derbyrims.com
    Reputation: derby's Avatar
    That is disturbing. One time a bead blow-off happened to me mid-ride with a tubeless converted 26 inch Panaracer Rampage tire on a DT Swiss TR rim. So I don't believe that switching to 26 wheel would be any safer for harder riding stresses, unless using a TR designed tire and rim.
    Any tire bead in use stretches looser over time more or less. Compared to Stan's rimstrips, it makes good sense that a ghetto strip should maintain a more consistent rubber to rubber sealed contact interface as the bead stretches.
    Hopefully soon there will be safer TR type 650b tires, with more Kevlar in the beads to prevent stretching so much, and that are close otherwise to the Neo-moto.
    TNC
    TNC is offline
    noMAD man
    I don't know, derby. When Stan's rim strip system came out years ago, I haven't burped or blew off a tire since. And even in the dark old days of the roll-yer-own packing tape and latex mold builder with non-UST tires and non-UST rims, I only blew one off in a g-out situation.
    In recent years the only tubeless issue I've had is occasionally finding the right non-UST tire to run tubeless that still provides puncture durability. In our rocky terrain, I even have to be a bit careful of the UST tires I run...especially on the rear. The selection of good UST tires that are durable and don't weigh a ton are becoming more numerous, so this has been good. But none of this has anything to do with the sudden bead separation blowoff I'm talking about here. At least when I have punctured a tubeless tire with a sharp rock or such, it goes down slow and gives you a loud hissing warning. I've never crashed with one of my tires getting a fatal puncture over the years...even on a fast, nasty downhill. A rapid bead separation blowoff for me has always resulted in a crash, as I'm usually in an aggressive situation that brought on the blowoff.
    The fit of the Neo and ZTR355 is way better than the Blunt, but apparently still not good enough. I'm going to try a Nevegal post-haste when they come out to see if there's improvement...and I'll probably try the ghetto deal. But frankly, I'm getting gunshy of the Neo. This tire is a downright winner in terms of traction and wear performance, but if it won't hold up in tubeless mode, it's outa here. Body armor and luck have been on my side in two good crashes, but I don't even buy lottery tickets...LOL! I don't think XC folks are going to have this issue for the most part, or those running tubes.
    And this isn't a hate rant or anything close as far as the Neo and 650B are concerned. The Neo was never touted as a tubeless tire, so it is what it is. I love the wheel/tire size, and I still standy by the performance and handling improvement it brings to MTB'ing. Some of us just apparently need a wider selection/availability of wheels and tires for certain types of riding...at least if we want to run reliable tubeless setups.
    Too much...
    Too much front wheel bias is my guess. You know... full face helmet, 6 gallons of water, 16 power bars and a fig newton in the camelbak make that thing way front end heavy. Hell that would make anyone look for a way out.
    BTW, I blew the Quasi off the rim yesterday also.
    Reputation: SuspectDevice's Avatar
    Sounds like you just need a fresh tire. Beads can't stretch (aramid) but the casings do start to deform and break down after a while. It's not the tire or the rim per se, nor is it a combination of the two. It's mostly just wear and tear.
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    +1 to Mickey. From my understanding the Neo and Quasi a bit undersized, but with use the casing gets worn. I've noticed the casing wearing on my (first set) of Pacenti tires. I use them so they wear out...
    Reputation: alex_k's Avatar
    Can the rim design be the cause of the problem? You are not the first who experienced blow-off with stan's rims.
    from their site:
    Rim Features:
    * This new rim design eliminates the traditional bead hook and uses our new bead socket technology™. It moves the sidewall of the rim down by 2-3mm.
    * By eliminating the bead hook and lowering the sidewall by 2-3mm we reduce the weight of the rim. Some of this material can be used in the center part of the rim making it stronger and stiffer.
    I think it is fine for the most tires but some might have too weak sidewalls for those rims
    TNC
    TNC is offline
    noMAD man
    Well...
    Quote Originally Posted by SuspectDevice
    I've never had this experience with 26'er setups with Stan's rim strips. I've run tires down to the nub and didn't have them unseat at the bead under hard use...and many of them non-UST tires. The worst case scenario has been that when the knobs start wearing down a great deal, they seem more prone to a rock poke that the Stan's won't seal up. I have always felt that the Neo and rim fit situation has been a little loose.
    Texheckler and I work at the same shop, and now he just reported a blowoff on a new Quasi. He's using a pair of Stan's ZTR355's on a Stumpjumper FSR. He's never had a blowoff with Neo's, but he's always been able to run lighter tires and wheels than me with no problems. We've been working with homemade and factory tubeless setups at our shop since they first came on the scene. We know how to set up tubeless tires in just about any configuration. I disagree with your statement about it not being the tire or the rim. It's one of them. I still don't like the way the Neo fits the two...three if you consider the two alleged sized Blunts...rims I've tried. I still contend a tighter fit would solve all this. The Neo's carcass is obviously tough enough. I've not had a serious hole poked in any of the ones I've used yet. If I had blown off a few 26'er tires over the years, I might give credence to your assessment.
    www.derbyrims.com
    ...Beads can't stretch (aramid) . ....
    Forgive me for not understanding this, but why else is it always much easier to remount used tires?
    Quote Originally Posted by derby
    The stretching and deformation in the casings. Steel and kevlar beads don't stretch. Etro specifications pretty much demand that. Cotton or synthetic weaves and rubber have far, far more give in them than the two highest tensile material used in industry.
    A tire "stretching out" is pretty complicated, but blaming it on either the rim or tire manufacturer is a little more complicated.
    Just trying to defuse some of what seems like anger bubbling below the surface here...
    TNC
    TNC is offline
    noMAD man
    Bubbling anger?...LOL!
    SD, if that was referring to my comments, then you really don't know me. I may be frank and try to say it like I see it...and actually experience it...but real anger over stuff like this is wasted. Now...if I was in a body cast over this crash, I might be a little peeved.
    I love 650B. I think it's a real deal. The relative newness of this tire/wheel format deserves great praise when it works and frank discussion when a possible problem surfaces. You think I'm complaining?...just ask krolik.
    Harshing my mellow, man..
    Whoa there, buddy...
    TNC, you need to just calm down and go to bed. You alway HAVE had a temper...at your age, this can't be good for your heart. Just put down the tequila and go to sleep.
    Quote Originally Posted by locobaylor
    TNC, you need to just calm down and go to bed. You alway [U]have[U] had a temper...at your age, this can't be good for your heart. Just put down the tequila and go to sleep.
    Glad you were not hurt. Body armour a good thing for that application..... ztr's ?
    I think maybe ghetto is a tighter fit as Derby says. The inner tube over the rim bead makes it tighter i beleive and a little more tolerant as well as grippier. (word?)
    When building up my neo/ztrs i just did not see how the lil yellow tape was going to get the job done (observations during inflation vs ghetto + c-clamp testing.)
    I've worn my ztr based neos down to semi-slicks with no issues + I ride the h*&ll out of them aggressively downhill and weigh 160-170.
    But geez guys, with the different class of aggressiveness in downhill applications you guys do, I'm not sure I wouldn't run thick a*&s tubes
    Why not do some of the C-clamp testing Stan does on his site, with various tires and setups (yellow rim strip, rubber rim strip, ghetto) ? Try and get an idea if any rim bead/non-tubeless run not-non-tubeless tire would suite your needs for the aggressive stuff you do ?
    (Btw, Not sure I would be running ztr's if application was aggressive enough for body armour, but glad you were.)
    TNC
    TNC is offline
    noMAD man
    LOL!...locobaylor
    Quote Originally Posted by Cracked Headtube
    Don't worry, CH. When I get back to the shop, locobaylor will be the recipient of some of my "bubbling anger". I tell ya...these youngsters today have no respect for their elders. But when you see this pic of Baylor out at our ride last week, it becomes clear why that is. Hey...he's actually not a bad kid. We needed someone to sweep the floor at the shop. We always try to help the "challenged" folk in our community. In this pic I think Baylor was still in makeup from his stint as an extra in the remake of the movie, "Planet of the Apes".
    Reviewer/Tester
    Reputation: Rainman's Avatar
    Interesting observations, TNC.
    I have had no burps, no blow-offs or roll-offs so far with the Blunt set up as ghetto tubeless on the front with the Neo Moto...and i've tried to make that happen.
    It seems that the ghetto tubeless holds onto the tire and rim better than the Stans rim strip does.
    However, folding bead tires do stretch, as has been said, and there is always the chance that one will stretch just enough to give way under cornering or landing slightly sideways stresses...although as I said, i've really tried to get mine to let go, and [touch wood] they haven't yet.
    Having said this, mine will probably blow off on the next ride....
    R.
    It is inevitable ...
    www.derbyrims.com
    Quote Originally Posted by Rainman
    R.
    R, you have seriously jinxed yourself
    Since I have no experience with ghetto tubeless, my humble theory is that the drying sealant glues better to the more porous rubber to rubber interface. Any reliance on rubber to metal or rubber to plastic tape has reduced bonding effect which allow for the dry seal to peal away, burp, get wet then possibly suddenly bead stretch more and blow off easier.
    With well settled sealed ghetto technique, any side load that would pull the bead away from the rim would also pull the ghetto rim-strip away from the rim with the bead because of the superior glue like bond. Stan's rim strips are too stiff to move or stretch with the bead.
    Just my theory. And I plan to test the theory soon with my next set of new Pacenti tires.
    Reviewer/Tester
    Yes derby, I tend to agree with you on those observations.....especially the first one... [*oops!* I had better wear my armour next ride... ]
    R.
    TNC
    TNC is offline
    noMAD man
    Hey derby...on the bond between the tire bead and Stan's strip, they actually do adhere to each other when everything is done right. Sometimes I have to use a semi-sharp plastic tire tool to separate the bead from the strip during tire removal or to add sealant. When everything works properly, they stick together quite well. The strip lifts with the tire bead when doing this. When I pulled everything apart on my ZTR/Neo setup, the tire bead and Olympic strip were well sealed except one place where they separated. This was the spot where some dirt and such was present. I'm still a little suspicious about the ease with which a Neo and strip can detach from each other when compared to the many 26'ers I've tried. Most 26'ers fit quite tightly to their rim, so the resulting amount of movement is less and perhaps results in the bond between bead and strip staying put. On the other hand, you mention stiffness in the strip. This got me to thinking about the fact that we're using a 26" strip as recommended by Stan...Olympic model. This obviously stretches the strip more than normal on a 650B rim and probably removes some of the strip's compliance. You've heard me say this before. I still contend a tighter fit at the bead would probably alleviate this. It's not a blame statement, just an observation. Is it a rim thing?...a tire thing?...a "both" thing? Hell, I don't know. I'm just a guy trying to run non-UST tires in tubeless mode with a death wish.
    I'm still riding Stan's ZTR with only yellow tape and a Neo. No burps, roll-offs, or major leaks. Then again, I ride SMOOOOVE.
    I second SD. TNC, you do ride a lot from your posts. How old is the tire and how many times have you mounted and re-mounted it?
    www.derbyrims.com
    TNC, yes, for sure I've also seen the Stan's rim strips and sealant glue fairly well with the tire bead and lift the strip before peeling apart while removing the tire. Maybe a ghetto inner tube would flex with the bead under side loads and remain bonded even better. The ghetto riders seem to all swear by that technique for best air retention.
    I also think you have very good points about the reduced flexibility of Stan's rim strips when a 26' wheel strip is stretched another 3 inches or so to fit 650b rims. And I have also always noticed every Panaracer tire I've used, Fire XC Pros, Rampage, and Pacenti's are easier to mount than most other's I've used. A tighter bead would go a long way to reduce bead squirm burping or over-stretch the rim diameter easier.
    Possibly another small factor of the issue of making a good bond is that I'm finding the Pacenti tires need at least 3 ounces to seal fairly well for multiple rides. That is much more sealant than three other 26" 2.3 size tires I've converted tubeless needing at most slightly more than 2 ounces to seal well when new. The Pacenti casings bleed very little. This may indicate the roughness of the bead interface with the rim's bead hook interface is another issue.
    I'm also worried about my safety converting any tire! I may try over 32 psi again when I try Neo-motos with ghetto rim-strips to test the limits. But 32, really 30 psi, is the max I'll use with Stan's rim strips for any size wheel.
    I wish TR was standard for all tires. Why not make tubes or tubeless optional? I guess it must be much more expensive to produce tires with TR beads.
    Here is the original thread where we first beat the heck out of this topic.
    http://forums.mtbr.com/showthread.php?t=432509
    (incuding the non-metal rubber/rubber contact and tighter fit provided by ghetto....mind you this is still ghetto guess work.)
    Just remember guys this is all still done with a tire that is not supposed to be run tubeless. Ya don't see Kirk spending allot of time talking bout this.
    Oh yea, that reminds me I need to order some new Neos as these are worn out with 0 flats run ghetto in 6 months.
    PS, I hear bleeding is a real problem with some tires. (as said, not Neos) But I would think that would be a sure sign you should not be running those tubeless because the sidewall is questionable and needs the extra support of the tube.
    TNC
    TNC is offline
    noMAD man
    Not old...
    Quote Originally Posted by willie b
    And never removed. This tire was brand new and has only been mounted once on the ZTR. I've pulled a several inch gap on one side open to add sealant just once. The bead and Olympic strip were nicely bonded. My strict routine is to add sealant at a spot directly across from the valve stem on the drive side. The spot that "derailed" during this episode was right at the valve, so nothing amiss at that spot. I pushed the bike for a bit with the tire flopping, and the bead and strip were still strongly bonded...except at that one point. I was impressed. I would normally install a tube and keep riding, but we were close to our vehicles.
    willie, as I mentioned elsewhere already, two of the guys at the shop are using ZTRs with Neos and have had no issues at all using only yellow tape front and rear. They have been riding Epics, and I ride a Nomad. I think just the nature of the Nomad, and how one rides a bike like this probably challenges the wheels and tires a bit more. I am definitely no Steve Peat and no freerider, but I ride my Nomad much like I ride my dirt motor. This is a bike with suspension, and I'm going to get my money's worth.
    I just want to repeat, however, that I've run all manner of non-tubeless 26" tires front and rear on my Nomad and other bikes with no blowoffs. Some of those tires were poor tubeless candidates and often had a rock cut that totally ruined the tire...but...they never blew off the rim. Good, bad, or otherwise, those 26'ers had a relatively tight fit to the rim. The Neo doesn't. The Neo/ZTR fit was the tightest I've seen so far but still somewhat loose compared to 26'ers I've used...except that 650B Sun CR18 which is alleged to be a different standard from the old days. I'd contend that if all 650B rims were the size of that CR18, blowoffs wouldn't occur.
    But, back to the original issue, one can't really carp too much since neither the Neo nor Quasi are claimed to be tubeless ready. It's too bad really, as the carcass and integrity of the Neo are otherwise stellar. Aside from bead tightness, any non-tubeless 26'er I've ever run in tubeless mode that had the carcass integrity of the Neo always made a great tubeless candidate.
    Reputation: reformed roadie's Avatar
    Am I the only one who wishes that splitting a tube to create a 'tubeless' set-up was not referred to as 'ghetto tubeless'?
    Technically, it is not tubeless, since you are using a tube, right?
    Anyway - I am planning on converting my front - ghetto tubeless - and was planning on using a 24" tube. Is that what works best for 650b rims? (in this case, a Synergy OS)
    Full Tilt Boogie
    May 2005
    Really, why are any of you surprised that running a tire not designed to be tubeless has had this result?
    I totally understand that Stan's may have worked for you in the past, but you have to understand that using products in ways they are not designed for always has potential consequences.
    Buck up, it didn't work this time, oh well.
    I sell bikes here. Check out the Blog here. Facebook.
    TNC
    TNC is offline
    noMAD man
    Well benwitt...
    Quote Originally Posted by benwitt11
    And others...no one said this is some kind of end-of-the-world deal that it hasn't worked up until now. This is just the reporting of a relative ongoing situation of trying run 650B tubeless for those already running or thinking about running it. It's called information. The day I come on the forum and call Kirk, Stan, Velocity, and other 650B suppliers a bunch of obscene names, you'll know I'm totally pissed and being highly unreasonable. I don't think I've done that...have I? This being the internet, I realize that you and others can't read my demeanor, but most that know me are aware that I certainly don't mind discussing issues like these...as long as it's not an obvious troll effort like DC often dishes out.
    ben, if you know your history on tubeless, you know that Stan's and many others who thought outside the box probably did more to bring tubeless to its current state of popularity than Mavic, Michy, and Hutchinson ever did. It allowed people to try running tires in tubeless mode that they could actually get, on wheels they actually had and could afford. Many/most of them worked out quite well, and Stan's strips, sealant, and information probably brought more people into the tubeless fold than any of the biggies could. That spur to tubeless use then caused manufacturers to produce more real tubeless tires, and now we have the term "tubeless ready". Gee...whatever happened to the UST-only deal?
    ben, you made the comment that using products in ways they were not intended has potential consequences. The funny thing is that the tubeless history model isn't too unlike that of 650B. Here comes a funky wheelsize for which no frames are actually made. But...people are putting them in certain 26" forks or in frames in which they fit the rear...and lo and behold...we have something very interesting that seems to work. If we relied on in-the-box thinking in both of these examples, bicycling would probably be missing out on some very worthwhile concepts...or at least be lagging behind. I don't think anyone expects every tubeless, wheelsize, or other hair-brained idea to work. I don't. And while I'm disappointed that the Neo isn't working out as well as I'd like as a tubeless candidate, I'm hardly claiming that Kirk's mom wears combat boots.
    Gee...we 650B users as a group aren't turning into the same Kool-Aid guzzling category as 29'er folk...are we?
    That's a joke, BTW.
    Full Tilt Boogie
    May 2005
    A tubeless tire versus a tube type tire is what it comes down to. Stan has nothing to do with tire construction, and his products don't change tires. A non tubeless tire with a lighter bead and sidewall is still that.
    Using different wheel sizes in different frames is one thing. If you read through my posts on here I've been doing a lot of things that most would consider outside the box for many years now. I am in no way opposed to experimentation with different ideas, but my original point stands pretty much irrefutable, a tube type tire is not designed to be run without the internal support of a tube and it's effect on a rim/bead interface. Period. I have never recommended using this type of set up in any form, nor will I ever.
    Reviewer/Tester
    I have used both 24" and 26" tubes in my testing. Both worked fine, although I prefer to use the 24" inner tubes because they fit tighter on the rim. Whichever size is easiest for you is the right one, I guess. However, make sure you get Schrader valve [American type] tubes because it's easier to add new sealant when the time comes to do so.
    R.
    Quote Originally Posted by reformed roadie
    Reviewer/Tester
    I agree with you ben, but .......... we like to live, dangerously.....
    R.
    Full Tilt Boogie
    May 2005
    I understand the desire. I have really grown to like my tubeless set ups. That said, I've heard so many stories of "it works fine until it blew up," to make me say no. I do enough dangerous things myself without worrying about tires going wonky of their own accord.
    TNC
    TNC is offline
    noMAD man
    Bingo!
    ben, that's the only point I've been trying to make about non-tubeless tires. The many 26'ers I've tried...even the relatively bad candidates...in tubeless mode with Stan's strips on a large and diverse number of non-tubeless rims didn't blow off the rim like this. Any loss of air in even the bad ones was due to the carcass not having enough integrity to seal up with Stan's sealant after a small rock poke or really big mesquite thorn. The Neo on the other hand seems to have an outstanding carcass integrity in terms of wear and punctures but a poor grip on the rim. Is it the rim?...is it the tire?...both?...neither? I'm only posing the question. Some people on the other hand seem to be having good success even in tubeless mode. Some aren't. Just saying...not trying to indict 650B or the Neo on criminal charges.
    emtb.pl
    Reputation: krolik's Avatar
    No issues since I mounted my set with a rim strip.
    Nevertheless, the amount of burping and peeling the tire off and than mounting it again using just my hands (using tape only) makes you wonder, doesn't it?
    I think I will return to the blunt/tube setup in spring.
    Mar 2006
    Sorry, but this is not always true. It is only always true for downhill rims that have the larger hole diameter designed for Schrader valves.
    I am one of the original guys to run ghetto on the neos and here are some observations.
    I have run and tested both Schrader and Presta; and Prestas work best for all XC and all mountain apps with rims made for presta valves.
    It has been well documented http://forums.mtbr.com/showthread.php?t=432509
    that you do not need to go that way anymore (always drill your rims with large schrader holes.)
    You simply need to get removable valve core presta; the contis or the
    schwabes (sp). (These are the ones I would use, although I have even made 26ers work in 650b)
    http://www.everybicycletire.com/Shop...sta-valve.aspx
    History: All of the original old school ghettos (in the old videos on you tube and in the instruction manuals on the internet) where done schrader so that is what guys just.....did !
    But the original logic was that if you drilled your rim out correctly (and not too large !), you get a better seal around the valve (also, sandpaper burrs around the hole after drilling.)
    But, removable valve core prestas work without having to drill the rim out at all in many cases and they are lighter. (Does it really make too much sense that if you do need to drill to do a tiny bit for presta first and test !)
    All that is required is making sure that the rubber around the valve comes up enough into the hole in the rim. (see stans video where he shows how to do a tiny drilling for presta ONLY IF REQUIRED on certain rims.) (Btw, Stan's rims do not need to be drilled, they have slightly larger and better designed holes and make great bullet proof ghetto set ups.)
    Then when you need to remove the core and add sealant it is a simple matter with a pair of needle nose pliers to remove the core and add sealant with this injector tool.
    (I made my own but this is really cheap and easy.)
    http://www.notubes.com/product_info....a6e15663ee6754
    So, guys before you void the warranty on your rims by drilling large holes in them, at least try the ghetto setup with presta valves....
    Part of the attraction to run big heavy shrader tubes is they are easy to get. (don't have to order) They all have removable valve cores and it is easier to pour stuff "sealant" in the large hole. Plus, your really feel like you are doing a neat custom engineering job if you have drilled a big hole in your rim !
    That said, once you know what you are doing with the technology and how to make it work. Presta valves work just fine. (That includes a mix of Stans and Slim tire or auto tire sealant with the injector.)
    Just think it through first which ever way you decide to go.
    I think a pretty safe bet is if you can flip the bead over easily with your hand or if sealant leaks thru a porous weak sidewall integrity, you should not be using that tire rim combination with that tubeless technigue (rim strip or ghetto.)
    I think it's safe to say if you won't do the research on what works and what doesn't, and won't take time to do testing such as c-clamp test, you should not be doing something you shouldn't be doing in the first place....your children may need you. Unless this is what you are after
    http://www.darwinawards.com/darwin/
    I think drilling out lightweight xc rims might help get you qualified.
    Reviewer/Tester
    Schrader V Presta.
    Well, i've tried both methods, Presta and Schrader and the Schrader valve will let you get a home brew sealant into the tire a lot more easily, especially if you use chunks in your sealant.
    Drilling out the rim a little with a sharp drill is not going to weaken it , even Stan drills his rims. My experience is that the Schrader valve seals better in a ghetto tubeless system every time, better than the Presta does. The rubber around the Schrader valve helps to seal up the valve hole and grips really well ... I don't think it matters whether the rim is designed for Presta or Schrader, personally. They are the same rims, made at the same factory, and some are drilled for Presta, and some for Schrader
    Every tire I have set up as ghetto tubeless has performed better with Schrader valves than Presta. That's been my experience....
    R.
    Quote Originally Posted by glovemtb
    TNC
    TNC is offline
    noMAD man
    Schrader 24"
    R.
    OK Rainman...I brought a 24" shrader tube home from the shop today. I won't have time to try it until next week, as I'm gone for a 3 day camping and riding weekend. I'll be using the Blunt on the front of the Nomad...with a tube...Oh the humanity!
    Quote Originally Posted by TNC
    Well, Stan is probably about the best expert that I know of running tubeless systems much more than all of you guys and myself. He has gone presta. As have all of his guys that work for him.
    I too have done both methods and have no problem sealing around the hole at all with presta. So why drill a bigger hole than necessary and potentially weaken the rim. I am not going to tell you guys that it will not weaken the rim as I was not involved in designing the specific tolerances for each rim and they are not all the same. Yes, we do like to live dangerously, but I don't like to give dangerous advice.
    Reputation: D.F.L.'s Avatar
    Just to pile on:
    355? Isn't that an XC rim?! Don't XC riders get off, run through the corners, then get on and hammer until the next turn,brake, and repeat? There's your problem!
    Kidding!
    Quote Originally Posted by D.F.L.
    Just to pile on:
    Kidding!
    Absolutely !
    He we are all pioneers and that is what is fun !
    I think ethier way works well. But, think for a minute what we are talking about as far as sealing around the valve hole.
    The ghetto tubeless schrader or presta has the tube (1/2 a tube actually ) preventing sealant from leaking out of the hole regardless of which you use. Why would you want to create a larger hole if you don't have to ? (Btw, chunks go in a presta valve with the core removed just like you have to do with schrader; just fine.)
    Regardless, have fun with it. Experiment both ways. Try to measure twise and cut once......Think about which you should try first.
    Note: My schrader ghetto tubeless setups run roughly 30 grams heavier PER Tire than my presta (or 60 grams over a tenth of a pound added useless weight and mainly in one spot on the rim...the valve, which is significant with XC 650b larger diameter hoops. Not so much with the downhill wheels.... )
    In the early days the schrader valve worked best with Stans rim strips because of the fit of the strip against the tire bead. But, with ghetto there is no gap there so picture how would you get a bad seal around the hole ???? So better seal with schrader vs presta does not really apply when seating the ghetto by it's very nature imho.....
    Once you learn what you are doing it is really easy to do ethier systems..... Just be sure and put the valve lock washer/nut on presta (that we normally never use). Remember you want rubber of the valve seating into the hole, not metal/metal.
    Anyway, notice in Stan's videos how he mentions it is important to have rubber against the hole with the presta valve on his strips? In addition notice how his rims that ship with the valve area re-inforced around the hole and with yellow rim strips ? That's to prevent any leakage this a very possible if you don't have a 1/2 tube that overlaps the bead and ghetto (schrader or presta) is the only "system" that delivers that kinda sealing.
    TNC
    TNC is offline
    noMAD man
    Absolutely.
    Just to pile on:
    Kidding!
    We ordered several sets of these from NoTubes. On our first order I questioned the guy about how this rim didn't strike me as being very strong going by its weight. I even told the guy I was needing something to go on a Nomad for aggressive trail riding, and he stated that they have very heavy guys doing very aggressive riding on this rim. Obviously I was very skeptical, but at the time the Blunt wasn't working out well, and nothing else was readily at hand. I'm just glad I got the wheel at a really cheap employee price. At least I'll be able to use the Hope Pro 20mm hub for my next project. I think many riders will have very good service from the ZTR355...just don't get too wiggy with it.
    Yea, I've had really good luck with these rims as well. I think if I were up around 200lbs (and doing downhill) I might go to something else (or build the wheels up differently) as they are a bit flexy with a lighter db spoke build. I'm running the 15mm thru front Hope 2. They are remarkably light for how well they have held up, plus really easy to setup tubeless with no rim mods required as that is what they were designed for.
    TNC
    TNC is offline
    noMAD man
    Tubeless
    rr, it's truly a tubeless setup, as you're only making your own strip system. The tire carcass is still running unobstructed by a tube and therefore more compliant like a tubeless tire should be.
    TNC,
    You need to just admit that you forgot to check your tire pressure before you left on the ride! There is no way that tubeless setup will work under 20psi! I think dimensia is setting in a little early. I haven't burped one yet and I can ride down a hill faster on a unicycle than you can. Check your pressure, drink more tequila, let off the brakes and you will be just fine!
    Ron
    Ron is offline
    Reputation: Ron's Avatar
    the rim bed can be built up for a tighter bead fit if needed with multiple layers of fiber reinforced strapping tape...that's what i did...4 layers plus pipe tape on a 700c cr18 rim (should be the same for any rim tho)...i wanted the tires to fit TIGHT
    TNC
    TNC is offline
    noMAD man
    Nobody likes a braggert!
    Quote Originally Posted by aaron81fire
    TNC,
    Yeah...you wait until I'm gone for 3 days to make a smarta$$ post. I should have cut the tires on your Xterra while it was parked in my camp.
    BTW...we just happen to have a unicycle at the shop. What day are you working? The gauntlet has been thrown.
    Smart guy...you know my anal obsession with tire pressure, shock pressure, and fork pressure. I think I'm the only one who's ever worn out their rear shock from checking it so much.
