Page 1 of 10 12345 ... LastLast
Results 1 to 100 of 902
    Let's ride
    Reputation: rensho's Avatar
    Official 650b fork thread
    I'll start us off, and will constantly update this list.
    Let's try and keep this thread to just the facts about which forks work/clear for 650b wheels.
    The official height of the Panceti tire is 702mm. That means if you go measure your axle to bottom of arch/brace of the fork and get 356mm or more, you should clear. I'd like 5mm+ of clearance. The tire may still bottom on the fork crown at FULL travel, but that can be remedied by a spacer in the internals.
    I put all forks that are suspected to clear in the 'clear but may need a spacer' listing until someone confirms the tire clears the crown as well as the arch.
    Forks that work out of the box:
    WhiteBrothers 650b forks
    2008 Fox RLC/FX
    Any 29" Suspension fork
    Any Rigid fork with a AC longer than 360mm
    manitou R7 (2006 tested)
    All Fox Forx (some forks may rub so slightly on the bottom of the crown if all the air is removed)
    Forks that clear but may need internal bushings/shimming:
    RS Pike
    RS Psylo
    Cannondale Lefty
    XFusion Velvet
    Maverik DUC and SC32
    Manitou Stance
    Manitou Nixon Comp 145
    RST Capa T26 ML
    SR Suntour XCM
    Forks that don't clear:
    RS Revelation
    RS Reba 2005 (wheel clamps in, but Neo tire is rubbing the arch)
    Reputation: MMcG's Avatar
    Jul 2003
    Reports have the Rockshox Psylo forks clearing just fine.
    I think some older and maybe current Shermans and Nixons are fine
    XFusion Velvet is fine and even okay'd by X-Fusion to use
    And of course 29er forks clear
    White Brothers have the only 650b specific forks available right now as far as I know.
    A Lefty would work of course, as would the Maverick forks either the dual crown or single crown. I also suspect that there are other inverted dual crown forks that will work as well such as older White Brothers forks and what not.
    I wonder if a Shiver Single crown would work?
    Can you tell I've pondered this a bit!?
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    My List I've found to fit.
    1. Maverick SC32
    2. X-Fusion Velvet
    3. Manitou Stance
    4. Manitou Nixon Comp 145
    5. RST Capa T26 ML
    6. SR Suntour XCM
    7. Any 29" Suspension fork
    8. Haven't found a Fox fork that doesn't fit, yet.
    www.derbyrims.com
    Reputation: derby's Avatar
    Word of caution: A suddenly locked or slowed front wheel from tire to crown rub in a situation that bottoms the fork travel would cause a terribly bad crash.
    The Fox Vanilla 32/140 fork, with 650b Neo-Moto tire, rubs the crown very lightly when I removed my coil spring and put as much weight as I could on the fork's bottom-out bumper.
    As everyone knows who rides one of these Fox forks they are very over sprung and nearly impossible to get within 1/2 inch of bottom travel. The possibility of interference when riding this fork is very unlikely. A 5mm thick washer under the internal bottom-out bumpers would prevent any mechanical possibility of interference.
    Any fork that is not designed for 650b should be checked for tire-to-crown interference by removing the coil or air pressure; and if itís close then monitor your max ride-time travel using a zip-tie or o-ring around an upper stanchion.
    Thank you Derby. I'm not very excited about this thread, FWIW.
    Bike Shop Girl
    Reputation: Arsbars's Avatar
    Yeh I agree.. there should be a "cleared" and "compatible" section.
    ARLEIGH.CO Empowering women to ride more and worry less.
    TranceX Rider
    Reputation: Onie's Avatar
    Nice initiative, Rensho! Yeah, for starting this thread! This would be a big help for us 650B aspirants! And to CH as well for adding up some more to the list!!! To Derby for the tips! Well, we only need some categorization...
    Keep it up, guys!
    Thanks again!
    Quote Originally Posted by jcatienza
    There was no need to scare potential buyers and burn bridges "buddy"
    Tell me now, what's Product testing all bout then?
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    I'll add the Fox Van 36 and the '08 Nixon 160...both in the 20mm axle format. Both have adequate arch and crown clearance.
    Jul 2003
    I received a photo via email of a Neomoto paired up with a Psylo - it is the most arch to tire clearance on a 26" wheeled fork that I've seen to date. I will ask the emailer if I can have his permission to post up the photo. Impressive is what came to mind when I saw the image.
    Let's ride
    Quote Originally Posted by Cracked Headtube
    1. Maverick SC32
    2. X-Fusion Velvet
    3. Manitou Stance
    5. RST Capa T26 ML
    6. SR Suntour XCM
    Thanks CH, I'll add those.
    Let's ride
    If folks have pics of tires hitting crowns, I can post those up as guides for people thinking about setting up their forks.
    Wanted to point out there there are four 650b specific forks from White Brothers. Again I got mine (a Fluid 130 with a thru axle) and am super psyched...
    Fluid 130 and 100mm (both are air only, the 100 can be bought quick release or thru axle).
    Then their Magic 80 and 100mm for the XC guys...
    More info here... I can 100% confirm these are their forks for 650b. White Brothers are doing pretty well with the 29er crowd, sort of a resurgence IMO and I think some recent design changes have made them a pretty good contender IMO...
    Quote Originally Posted by derby
    Adding another bumper may prevent the damper from refilling with oil after reassembly. You may need to "port" the washer to allow the oil to flow back into the damper on the right leg.
    Ask me how I know
    Reputation: SteveF's Avatar
    When I go 650b, I'd like to buy a fork that encourages manufacturers to produce more forks for this wheel size. I wonder which purchase would be more effective, buying a 26" or 29" fork strictly because it fits a 27.5er and in hopes of encouraging that company to produce a dedicated model, or buying a dedicated 650b fork to support a company that has already made the leap?
    I wonder if it would be possible for a manufacturer to produce 650b-specific replacement lowers that would retrofit a 26" fork to fit 27.5"?
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    Quote Originally Posted by eMcK
    Ask me how I know
    Ok, "how do you know"?
    Are you saying that a raised bottom out bumper presses up against the base valve such that it is sealed off? In that case the lockout wouldn't work correctly (no blowoff)..
    Quote Originally Posted by SteveF
    Its not really the lowers that cause problems. Aside from a few forks (for example the Revelation), there is enough clearance for a 650B since manufacturers plan for beefy 26" tires + a good bit of mud.
    The problem lies in the axle-to-crown distance when the fork is fully compressed. Fixing this doesn't require new lowers, it requires new uppers. Either the stanchions need to be ~5mm longer to make the fork bottom out before the crown hits the tire or the crown needs to be ~5mm taller in it's center section to still clear the tire at bottom out.
    The stanchion fix is the easiest since it doesn't require new casting molds at the factory. The downside is you loose a little bit of travel.
    op
    www.msmtb.org - Mississippi Mountain Biking
    TNC
    TNC is offline
    noMAD man
    Gotta start somewhere.
    You make a good point about wanting manufacturers to run with the ball and produce forks and frames, but that can be a tall order. I'm sure that before they spend what would probably be a decent amount of money and resources to strike out on an untried format, they'd like to know if there's much of an interest level and an actual resulting performance return. This is where we as consumers and passionate MTB'ers often have to step out and show our interest by trying out what is available...including getting creative when necessary... and then reporting on those results. It's a lot easier for me as an individual to buy a wheel and tire setup, find a fork it will fit in, and then see how things turn out.
    Please understand that I'm not attacking your concept here, as I too would love to have some manufacturers just step out with dedicated 650B options quickly and in numbers providing lots of good choices. But that's just not the way it usually works...and perhaps understandably so. That's the bad news. The good news, however, is the fact that 650B isn't the leap of engineering and perhaps even manufacturing issue that the 29'er format presented, so indeed, manufacturers will hopefully be able to wade into these waters without the fear of large financial commitments and the potentially larger fiscal losses that could follow. Your suggestion of slightly modified lowers to accomodate 650B is one such example of the potentially simplified possibilities with which 650B could be addressed in some fork designs. Also some forks could probably use modified stanchions, since we're not talking about changing travel necessarily, just clearance. It's apparent that there may some relatively simple and creative approaches to the issue in many cases.
    If enough people try 650B with the existing products available, and it becomes clear that the concept has legs in terms of an actual increase in performance, the manufacturers will most assuredly follow with products to support it. IMO the 29'er format has effectively "plowed the ground" with the concept of stepping outside the box of wheel size convention, so hopefully the 650B challenge won't appear as imposing to manufacturers. I still think it will take more of us as riders running with what's available and reporting our results in a meaningful way to reveal the viability of the concept. Though I'm convinced of the worth of the 650B setup, even though I've only experienced some extensive use on the front wheel/tire setup, it may take a bit more convincing on the part of manufacturers before they are willing to step out seriously. On the other hand, it's been fairly impressive IMO how quickly interest has developed. Bicyclists as a whole have been notoriously entrenched in certain concepts of "what works best", but even that seems to be changing thankfully.
    I am not someone with a long history (multiple years) with MTB technology but in the last year I have been full fledged commited and have quite a bit of time on a variety of bikes and forks. I have been told that in the past White Brothers forks have been moderate or have been having some reliability issues. But it seems particularly in the last 1-2 years and particularly with their 110mm and 135mm 29er forks, and taking that technology from those forks and applying it to their other forks, that they have gotten themselves fairly dialed. Over in the 29er section they are all the rave, people are having no problem spending the $870MSRP for some White Brothers forks there. People are reporting "this is the best fork I've ever had" and "super plush" etc. I probably come across as biased (but I don't think so) because I just built their new web site and I have a few for sale, but I gained a real understanding for their technology while building their site and am super impressed. My impressions were only compounded when I actually recieved my first fork from them.
    So I wrote up my impressions here:
    White Brothers 650b Fork / My Decision to Go 650b
    I am also 110% pleased with the weight of their Fluid 130 thru-axle (4.2lbs) which is not touched by a Fox or any other thru-axle model on the market. I also think the 29er guys, who are running through axle in 32mm stanchion XC/AM versus dedicated AM forks, are on to something because the axle is so laterally stiff. There is slight weight increase (usually about .4lbs) with the thru-axle but also some weight savings in the hub with less required material. So that is how I ordered this WB 130 as well (I can't remember but I might have been able to order it with QR), also taking from the 29er crowd. Again 650b is only a hair larger than 26" so I don't think the added lateral stiffness is necessary like a 29er fork. But I don't think it will hurt anything at all either...
    So, I am extremely pleased to run it. I could sell the fork and buy a Fox easily and it would fit more or less, be more of a "commercial" common fork, but I am 100% excited to run this White Brothers fork, with pride, it is really a no brainer for me...
    Let's ride
    Hey guys, I'll try and keep this thread to just the FORKS that work for 650b. I don't want to fill this thread with a whole bunch of discussion around which fork mfg/style/type/design I like best. All good, but not for this thread.
    Thanks for understanding.
    TNC
    TNC is offline
    noMAD man
    Due to some of the real and perceived issues with past White Bros. forks, it was probably a good move on their part to jump in and embrace an area of application that other more established manufacturers might be hesitant to participate in. If done right, it could highlight their product and company to a degree that could not be achieved in the mainstream fork categories...overall probably a smart move if they can provide quality, durability, and performance.
    I think the weight issue on the WB fork can be matched somewhat by the Manitou Minute series. The Minute 29'er at 120mm weighs the same as the WB, and that with a 20mm axle, so there may be some competition on the weight front. True...the Minute is not a dedicated 650B fork at the moment, but it's apparent that light weight, bigger wheels, and 20mm axles are very achieveable.
    Yeah, it's somewhat of a debate about standard QR vs. 20mm axles on forks in the 4-5 inch category. Personally I'm totally sold on the 20mm axle for anything other than true XC applications, but the old standard QR works fairly well in most cases for most people as long as travel stays at 5" or less. Where and how one rides will affect this issue quite a bit.
    Quote Originally Posted by rensho
    I don't think this particularly makes sense especially if you are editing the first post in the thread to include new info...
    I would suggest, regardless, adding the White Brothers forks as mentioned to the list. Doesn't make sense that they are not on there IMO as they are designed for 650b. I would also create category that says "fits" but some rubbing issues such as the Fox forks. There are photos of the Fox fork rubbing issues in the sticky thread currently...
    Let's ride
    Help me out. Which WB forks do you want me to list? I don't see the point in listing WB 650 forks for obvious reasons.
    I added another category above in the OP.
    Cool. I don't see the reason not to list it because people may not be aware that WB offers 650b specific forks. I think if the list were to be competitive and made into a sticky, people would look at it as a definitive info source so they might overlook WB if it were not listed. So that is my thought. The forks are:
    WB Magic-650b 80
    WB Magic-650b 100
    WB Fluid-650b 100
    WB Fluid-650b 130
    I don't have good firsthand Fox info but that info should come. The WB forks definitely 100% work out of the box possibly making them the only one out of the box with no crown-hitting issues?
    Thanks, Andre
    Let's ride
    edit
    Jul 2003
    Here is a photo of a 650b with Neomoto and a Psylo XC fork for everyone to gander at. Photo courtesy of KHenry. Loads of room from what I can see.
    Let's ride
    Wow, thanks for the photo. That is a lot of tire clearance.
    Jul 2003
    yeah - thanks to Kris Henry - he gave me the permission to post that up.
    I wonder how much room you'd have with a Manitou XVert fork as well? Those were the initial TPC damped Manitous - and they were nice forks in their day.
    horseman
    little tough to follow
    It's great to learn which "official" compatible 650 forks are out there. More importantly, for all of us out there in "retro-fit/make do/runwatchyabrung" folks, info onwhat the results were/are would be even more helpful. Not everyone is ready to go out and get a new fork. For example, the Fox people don't seem ready to embrace the 650 thing, but I bet a lot of folks are going to try. Photos of someone trying a 650 on a Fox 100, or 120, or Rockshox/Sram affair would be just great.
    Additionally, a report on what the rider did to offset handling "side effects", like stem height/angle, shims, etc...
    Reputation: 8Trak's Avatar
    Just curious, but I thought the X-Fusion Velvet was good to go out of the box (based on various info I have read). Rensho's post at the top seems to say that spacers/etc. are required. Does the fork crown rub the tire and full compression?
    Let's ride
    8trak, I put all forks in the 'tbd' area until someone confirms that they are good to go without any mods.
    Someone with a xfusion, and any other fork up there needs to let all the air out of their fork while the 650b tire is in there and see if there is fork crown rub.
    For those without a 650b wheel/tire, measure the axel to bottom of crown height and tell us what that number is in mm.
    San Diego County
    Reputation: Duzitall's Avatar
    rensho means measure from the center of the axle to the bottom of the crown please.
    www.derbyrims.com
    The Pike is confirmed with enough clearance. I just put a Rockshox 454 U-turn coil Pike on my bike to get back to a 20mm axle and with PUSH tuning.
    The Neo-Moto clears the Pike's arch by 5mm, and with spring removed the crown bottoms with about 7mm clearance, so besides a potential sticky-cakey mud clearance issue which would be unridable anyway, the Pike is safe.
    I also measured 135mm compression travel, I guess Rockshox count top out spring travel to make the 140mm claimed, unlike my '08 Vanilla RLC that does have 140mm compression travel potential using a very light spring plus a little more top out spring travel. The axle to crown was about 2mm taller on the Pike 520mm vs. 518mm for the Vanilla.
    Aug 2005
    please! lets make a sticky for confirmed forks! also, im real interested, is the quasi going to work with a reba 26?? id really like to have the quasi+reba26 this would be super!! looking at building a xt/blunt, but my current fork (guaranteed to work) is 20mm. the reba states only .1" less clearance than the pike, i do not have one in front of me, but i really like RS's and id see it as the sid of 650b if it worked. =D
    Reputation: MichauxYeti's Avatar
    I seriously doubt even the Quasi-moto will fit in the Reba. A 26" Continental 2.3 tire leaves maybe 8mm of clearance. The Quasi is definitely bigger than that. Too bad, because I'd love to try 650B's on my Yeti Kokopelli with Reba fork.
    Reputation: SuspectDevice's Avatar
    We just recieved a sample X-fusion Velvet R fork today.
    I'm not kidding when I say it's the best manufactured, most elegant suspension fork I've yet to get inside of (and that would be just about everything since the Mag 21).
    The ride is great. Straight out of the box onto the bike the compression damping and progression rate are dialed, and the rebound adjuster has a super usuable range. I got it because it "offically" is OK'd for 650b's, but I am certainly considering another one of these for my 26" slalom bike, and one for my 26" trailbike. If the fork was a lighter (which apparently it will be, considerably for MY 09), and had a 20mm option as well I'd run one on any 26" or 650b bike I own over pretty much anything else outthere...
    Jul 2003
    Mickey - take some pics of the fork on the bike with the 650bs it would be cool to see the clearnce between tire and arch - thanks!
    Quote Originally Posted by MMcG
    I will this afternoon, I'd been waiting on hubs for a week or so now... I'm running the Quasi's on it. And I can't wait to get it dirty!
    Jul 2003
    Quote Originally Posted by SuspectDevice
    Excellent. Looking forward to the pics. Take some clean and some when you get back from the ride!
    Oh Jeez. USPS somehow managed to drop the ball on moving my built wheels between cambridge and western Mass in 3 days. I guess I'll have to beat on the Quai-moto shod wheels all next week in preperation for NEXT weeks race!
    Aug 2005
    you can add a manitou R7 to the list of forks that fit. i have an '06 R7 Super 80mm on my bike with neomoto's and stan's 650b ztr 355's. there's not much clearance and i haven't tested it in anger yet but some back yard tooling around has shown no rubbing. seems like ordering a rigid fork for my 650b testing was a bit premature. pix forthcoming.
    Let's ride
    Quote Originally Posted by lanceh
    Thanks for the update. Also, if you had a chance, let all the air out and see if the tire clears the bottom of the crown. Sweet!
    pedal pusher
    Reputation: f3rg's Avatar
    I have a question about clearance for a rigid fork. You say minimum clearance is 356mm (+5mm), but then say that "any Rigid fork with a AC longer than 420mm" should work.
    Why must the AC be 420? Is AC measured to the top or bottom of the crown? If it's measured to the bottom, then wouldn't an AC of, say, 390mm, work just fine?
    Aug 2005
    yes, with all air out of the shock the tire does clear the crown. although if you're running a disc up front you'll want to make sure the cable is not routed under the crown, as mine currently is, or the tire will rub on the cable.
    also, after two rides in anger i must report that there is some rubbing on the bottom of the arch. my first ride showed no evidence of rubbing but my second ride did. it is very slight and only happened occasionally but it did happen. it only occurs on the outer edge of the disc side of the arch.
    the tire pressures probably dropped a little bit between rides and the terrain i rode was much different from my first ride. next time i hear some rubbing i'll try to pay attention to exactly what i was doing at the time i.e. changing direction, jumping a log, etc.
    no air in shock
    complete bike
    clearance (blurry)
    rub
    2006 sswc RockStar
    maybe swapping my Reba World cups for a 2007 fox f 80rl off a giant anthem, will it work with 650b wheels or is it just 2008 models? im running quasi-moto's as well
    Let's ride
    Quote Originally Posted by RockStarRacing
    Seems like all the Fox forks clear the arch. I need to see proof of all the crowns clearing, but that is a lesser issue, and can easily be mitigated.
    Let's ride
    Quote Originally Posted by f3rg
    Yes, you're correct. Any AC longer than ~360 would work just fine. When I typed the original statement, I was just going by the typical off the shelf rigid fork lengths I know of.
    Let's ride
    Lanceh, great pics. Thanks for taking the time. That was a fork I was interested in making up a 650b to try.
    I just tried some 650b wheels with neo motos on two forks, an 06 Marzocchi mx comp, and an 0? manitou black. Both clear the arches with about 3/16" (except that idiotic M casting in the arch of the zoke. but since both have springs, It wasnt so easy to check the crown clearance, at least I dont know how to get the springs out. If it's not hard and someone can step me through it I'll give it a try.
    San Diego County
    James Lee, you should be able to just unscrew the top caps.The caps and springs will stay on the rods but the entire assembly will rise out of the tubes while the fork collapses.
    Keep the forks straight upright or you might get a little oil drips coming off the springs.
    Use care screwing the caps back in place. The cross thread easily. I hope that all makes sense.
    Quote Originally Posted by turnerbikes View Post
    Of course the easiest way to fix this is to go for a hike.
    DT
    Reputation: shatbirdbicycle's Avatar
    I have a older Fox Vanilla 125 RLC fork, will this work in a 650b set-up?
    Let's ride
    Quote Originally Posted by shatbirdbicycle
    Yeah, that will for sure work. Those have lots of arch clearance. With a spring fork, you'll like never see the FULL travel of the fork, hence, crown clearance should be a non issue.
    a.k.a. BicycleKicks
    Reputation: 40hills's Avatar
    What fork for a Superlight conversion?
    If I was to try to make a SuperBlight out of my large 2007 Superlight, what fork should I get? I have a Reba now, so a new fork would be required for sure.
    I guess there are a bunch of options listed in this thread, but considering the geometry of my frame etc... would one be a better choice than the others?
    I currently have the Reba set at 115mm travel, so I'm thinking maybe the Fox F100 RLC or the WB 650B 100mm fork. Is the potential tire/crown contact of the Fox a real issue to worry about? Does the WB fork feel better/worse than the Fox? How about the fork offset issue?
    FWIW, I like a fork with some sort of platform, that's why I didn't list the Velvet, I don't think it has a platform. I ride this SL everywhere I can, but east coast style XC/mountains with roots and rocks out the yingyang, so high speed downhill sections can really whack the wheel/fork good. No jumping or tricks though... and I'm a lightweight.
    I don't have experience with a wide variety of forks etc, so I don't know if I can make the best choice myself. Is there a clear choice here or what?? Thanks.
    I read that on the internet.
    Jul 2003
    Quote Originally Posted by 40hills
    If you can afford it - get the White Bros.
    If not, consider finding a used Rockshox Psylo with UTurn, or perhaps a Manitou XVert at 105mm of travel. Both should offer plenty of tire/fork crown clearance (probably even better than a fox) although the Fox might outperform both in terms of feel and stiffness. Although those TPC X-Verts were nice forks IMO.
    MMcG, think Pedal Platform. In the case of the Platform, check out the Fox line up. WB forks have some sorta platform, but I don't really understand it, and haven't been able to experience it to the fullest, just yet. Fox makes a great fork, but WB does too. I have a WB 29 fork, and a Fox en route.
    Jul 2003
    Ohhhhhhhhhhhhh **** - missed that in his post. Whoops. Platform in forks kinda sucks anyway IMO. Just lock em out or run em plush.
    The White Brothers Magic 650b, 100mm fork is on sale at Bikelugs.
    Enter to Win a Vassago Frame and support the fight against childhood cancer
    MTB Path, Southeastern mountain bikers
    how about a fox float 130 xtt?
    anyone tried any 130? there aren't many folks with xtt's, I know, but 130 floats?
    I'm intending to run a 130xtt with ztr 355 650b with a neo moto on an ibis mojo sl. most people running mojo's use 140's (or more) up front...I figure if the wheel / tire works with the fork, the net change to head tube angle with this setup vs. 140mm fork / 26" wheel will be negligible.
    Reputation: drewactual's Avatar
    the marz 66 ATA? too short?
    Let's ride
    Quote Originally Posted by riderup
    I haven't seen any Fox fork be an issue. This is going back to 2004 Forks.
    I wish RS would put just a tiny bit more room in their arch so that they can run 650b.
    www.derbyrims.com
    140 forks: Nixon, Pike, Vanilla
    2007 Nixon Elite coil forks measure 13mm clearance at the arch over a Neo-Moto and 15mm clearace at the crown when spring removed and bottoned on the bumper. I have two RWDT models, a 2007 160/130 mm (really 155/125 measured) and a 2005 145/115 mm (really 140/115 measured). This is the most clearance I've measured of any fork for 650b use, and is at least as much Neo-Moto clearance as the Wight Bros fork designed with more offset specific to 650b steering.
    My 2008 Pike 454 U-turn coil 140 - 95 mm (really 136 - 95 measured) has 7mm clearance at the arch and 10mm at the crown with spring removed and bottomed on the bumper.
    My 2008 Vanilla RLC 140 (140 measured with spring removed) has 10mm clearance at the arch and no (0 mm) clearance at the crown when spring is removed and compressed to the bottom bumper. Fox forks air and coil are all over-sprung unless modified or damaged internally to gain full travel. I'm 200 lbs using the softest Black coil spring (Fox recommends for riders under 115 lbs) and I have never bottomed the fork while riding and jumping up to 4 foot drops. Nearly all riders including my riding exeriance on numerous Fox air forks confirm the Fox 140 air forks normally never utilize the deepest 1 inch of travel without modification or damage. So Fox forks are practically safe in clearance unless damaged.
    Wow, Derby, thanks for that info. Great stuff.
    Cool, do you suppose that a Nixon Super Intrinsic (quick release dropouts) would have similar clearance?
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    I've mentioned it before but the Rockshox Psylo's do fit the Neo-Motos perfectly and here are some pics of that...
    <img src="http://yoda.densan.ca/kmr/bikes/psylo650a.jpg">
    <img src="http://yoda.densan.ca/kmr/bikes/psylo650b.jpg">
    <img src="http://yoda.densan.ca/kmr/bikes/psylo650c.jpg">
    From the top knob to bottom of fork crown is 135mm and the fork travel is only 125mm so... it fits in the crown clearance department and obviously with a half inch of room around the tire in the fork brace, it works just fine there too.
    I don't post to generate business for myself or make like I'm better than sliced bread
    Mr.650b - Mr.27-5
    Reputation: Kirk Pacenti's Avatar
    Quote Originally Posted by DeeEight
    This fork is made for 650B, wow! It really looks ideal.
    I can see Psylo prices going up on ebay!
    Have you posted pics of the complete bike elsewhere? I'd like to see the whole thing...
    If you like my products and services tell everyone. If you don't, tell me - kirk(at)pacenticycledesign.com
    Jul 2003
    They already have gone up Kirk!
    Nope, because i've only just built the wheels and mounted tires... and found that the only frames which give clearance enough to spin the wheels without the tire hitting someplace are my Eclipse Kinetic full suspension frame (and then its VERY VERY CLOSE) and to do it on that one requires changing my disc brakes, brake levers and the fork, and on my Litech magnesium frame (which has a good quarter inch of mud room to spare all around the tire) which unfortunetly does not have disc mounts on it. The former requires work i'm not willing to commit to yet, and the later would need an entirely different wheelset using rims with brake tracks (Velocity Synnergy, Sun CR18, etc).
    Haven't fully tested this set up yet, but I threw a Neo Moto in an old Rock Shox Duke. It fit with plenty of clearance.
    - AR
  67. #67
    white brothers 650 feedback
    how's the reports on the WB 650B Fluid fork, 100mm travel so far. i am thinking about buying this fork and need some real use feedback
    thanks mg
  68. #68
    Mr.650b - Mr.27-5
    Quote Originally Posted by elrancho66
    thanks mg
    I haven't tried the 100, but my Fluid 130 rocks!
  69. #69
    Hey, Does anyone have first hand experiance that the 27.5'er will clear a '08 32 talas when bottoming out? I've checked my zip tie and at times it seams to get pushed right up to the crown when riding a downhill section of our local single track.
    Thanks for any feedback.
    David
  70. #70
    Fox RLC
    Any body try using a Fox Talas 32 RLC with the 650b set up? Is it possible?
    David
  71. #71
    I can't comment on the newer Talas forks, but I've been running 650B with a older '05 Talas... as reported, it clears the arch with enough room to ride in anything but sticky mud. *But* I took all the air out of the fork, and it does hit the crown under full compression, just barely.
    After seeking some advice, I basically got the answer 'don't worry about it'... I rode it up in Tahoe this past weekend and I let some air out to get a bit more cush on the fork, and on a couple of the bigger ledges, I did bottom out and sure enough, heard a nice little buzz from the front, but that's it.
    So my advice... if you're eager to try 650B, just go for it and get a wheel (it's a great upgrade for my 5 Spot). If you run into issues like I did, either decide to live with it, go back to the 26er, or start thinking about a fork upgrade
  72. #72
    Mr.650b - Mr.27-5
    Quote Originally Posted by 8Trak
    8Trak,
    I'd love to see a pic of your 5Spot. If i am not mistaken a 650B wheel will fit in the rear end of that bike too. I'd also be interested to here more about how this "upgrade" has worked for you from a performance pov.
    Cheers,
    KP
  73. #73
    Quote Originally Posted by Kirk Pacenti
    8Trak,
    Okay, a couple of things:
    I'll take a good profile pick of the bike soon, but it's very much a FrankenSpot at the moment (especially with the 650B). It was a replacement front triangle for a Burner, so I'm still running the Burner rear. So while there's plenty of clearance for a 26er, I haven't even thought about putting a 650B in there.
    As to the upgrade... I ride XL bikes (I'm 6'2", but fit bikes like your average 6'3" guy). So I'm on a big Turner and also ride an XL 29er singlespeed. Even though it's a hard-tail, I love how the big wheels roll over things, and how it's much more endo-proof for big guys like me. I've been wanting to upgrade to a 29er full suspension, but I'm waiting for more travel and room in my budget for going that route.
    So the 650B front upgrade sounded like a no brainer to me, especially after getting my new 5-spot front triangle.
    In terms of feel, I of course like how the front wheel rolls over things better than a 26er and how the front axle is raised a bit more. Also, I'm only running a 130mm fork right now (a holdover from the Burner), so the extra height actually makes the geometry just right.
    I'm planning to stick with this setup for a good while now, except that I'm going to upgrade the fork to one with a) a 20mm axle, b) coil spring, and c) more travel.
    Right now I'm thinking about the coil Pike, as people seem to be having good results with it and it's a solid, no nonsense fork (with nice features like adjustable travel).
    -Dave
  74. #74
    Magura THOR
    Anyone know if a Magura THOR will work?
    On another note, some one at interbike should be running around with front and back wheels, and jamming them in everything they can get their hands on. just an idea
  75. #75
    Just confirming that a R7 rubs ('06 version). It is tight to begin with, but under hard braking, it rubs on the disc side. I wouldn't recommend it.
  76. #76
    Let's ride
    I've been trying to force fit a Reba Uturn with the Neomoto. It will not clear the arch. It rubs bad enough that the wheel almost won't bolt in.
    I'm hoping to find a quasi and see if that is any better. Also, I'll be grinding on the arch a touch to help clearance.
  77. #77
    I did buzz the crown a couple of times on the older TALAS, and I felt it was time for an fork change anyway. So I picked up last year's Pike Coil with U-Turn. I have to say this fork is great... it weighs a bit more, but since I'm not a small guy (I changed the spring out to xtra-firm), that's not an issue.
    But the feel of the spring and the stiffness of the thru-axle is just a huge improvement over the older Talas (which was Pushed, by the way).
    All that said and done, the neomoto clears the arch just fine, with just a little room to spare (I think the exact clearance was posted by someone a while back). And I can use the U-Turn to make adjustments to the travel/ride height of the bike!
  78. #78
    Reputation: Mickey650b's Avatar
    thanks mg
    I've got a White Bros Magic 650b 100mm fork. I haven't had it long and it's still in it's break in period, but I'm real pleased with it so far and would definitely consider getting another White Bro fork if it continues to perform as well as it has so far.
    Not sure this is helpful considering you're asking about the "Fluid 100mm"
    But there it is.
    I've been posting up some thoughts on the White Brothers Magic 650b 100mm fork and some of Kirk's stuff if you want to keep track of it. I'll be updating this information as I get in more rides and eventually I'll be posting up a full blown review on all the 650b parts I've recently purchased. Here's the blog if you're interested.
  79. #79
    How bout 100mm forks? 1 person says the R7 rubs, in the first post says it may clear. Also how bout the Sid? What travel was the velvet tested at?
    www.mtbiker.ca
    My Rides:
    FSR XC -R7 Platinum - SRAM X7 (26.5lbs)
    Cervelo SLC - SRAM Rival - Reynolds DV46T (16.25 lbs)
  80. #80
    BBgobie- I've use the Velvet at full travel and 110mm. It has to be internally converted, and haven't needed to tune any lower yet.
  81. #81
    Reputation: bikesinmud's Avatar
    Dec 2005
    When you guys say that the Neo fits 'all fox forks' does this also include the 36's?
  82. #82
    Jul 2003
    Quote Originally Posted by bikesinmud
    I'd wager that the 36 would be the best Fox fork to use with the 650b compared to their other offerings. Just my two cents.
  83. #83
    Does anyone have any input on Marzocchi? I have a 09' 44ata. Sould this work with a Velocity Blunt & Neo-moto Combo?
  84. #84
    Reputation: reformed roadie's Avatar
    '09 forks
    Has anyone had the opportunity to check some of the '09 forks coming out?
    Many have new lowers (ie arches) that may fit... New Sid, Reba, Zoke 44, etc...
    I need a new fork, but have held on to my older fox since it fits the 650b.
  85. #85
    Let's ride
    Quote Originally Posted by reformed roadie
    Sid and Reba won't clear the arches.
    Edit: There's a recent pic in the sworks thread showing a SID clearing a Quasimoto tire
  86. #86
    Jul 2003
    I rode a Velvet yesterday in Providence. Duly impressed with the fork. Well done XFusion guys!
  87. #87
    Mr.650b - Mr.27-5
    Yeah, the forks work really, really well. Particularly when one considers the performance to $$$ ratio (value) of the X-Fusion as compared to the bigger brands... they could arguably be one of the best forks made for the money.
    Cheers,
    KP
  88. #88
    any word if the dart 26" forks clear? i know the 29er one would.. but i'm curious about the 26
  89. #89
    Reviewer/Tester
    Reputation: Rainman's Avatar
    Does the Manitou Nixon Elite TPC '08 have the same clearance on a 650B front wheel as a Manitou Nixon Comp?
    Anyone know?
    R.
    It is inevitable ...
  90. #90
    Mr.650b - Mr.27-5
    Quote Originally Posted by Rainman
    Anyone know?
    R.
    Rainman,
    I can't say with certainty that the 08 has clearance. I can say that 100% confidence that the 2005 model does. I have been rocking this fork for a few months now and it, well er, ROCKS!
    My assumtion would be that the casting for the 05 is the same as the 08. I will ask the boys at Manitou if this is in fact true.
    Good luck,
    KP
  91. #91
    Reviewer/Tester
    Thanks Kirk.
    I think that it will be the same, but wanted to be sure first. If you can find out for me and let me know ... much appreciated.
    R.
    Rainman,
    Good luck,
    KP
  92. #92
    www.derbyrims.com
    The '07 Nixon Elite easily fits, the same as '05 Nixons. It appears in pictures the lowers and crown are the same castings in '08. The Nixons have a couple or three mm more clearance than the White Bros 650b specific fork.
  93. #93
    TNC
    TNC is offline
    noMAD man
    Absolutely correct
    All these Nixons have the same 650B clearance. My Nomad has run one for nearly a year now with excellent results and no problems. The Van 36 on my Bullit works perfectly also with 650B...plenty of room. Both these bikes get some jumps and air time too. No problems.
  94. #94
    Reviewer/Tester
    Thank you all, great info...and i'll go buy one ...
    R.
  95. #95
    Mr.650b - Mr.27-5
    DT too...
    Rainman,
    I assume you're interested in testing this fork for an article? You might try rustling up one of the DT AM 130 or 150mm forks too.
    Kent Eriksen has been riding this fork for some time on his personal 650B dually and says it has 12-15mm of clearance with a Neo-Moto installed.
    Fwiw, reverse arch designs like this and the Nixon have a clearance advantage because of where the wheel sits relative to the arch. For any given distance from the axle, the reverse arch would give you a few more mm of room.
    Cheers,
    KP
  96. #96
    Reviewer/Tester
    Correct... i'm going to run this fork on the Ibis Mojo for a while to see how it goes. I was going to go with a WB 650B fork, but I wanted a bit longer travel than 130.
    While we are on this 'testing' subject... the Quasi Moto tire... was a different compound used in making this tire than the Neo Moto?
    R.
    Rainman,
    Cheers,
    KP
  97. #97
    Mr.650b - Mr.27-5
    R.
    The Quasi and Neo share the same casing and same rubber compound... but obviously completely different treads for completely different applications.
    Cheers,
    KP
  98. #98
    Reviewer/Tester
    Ok, thanks Kirk.
    R.
    Cheers,
    KP
  99. #99
    Manitou Minutes?
    I've found posts for Nixons and R7s...what about the minute line? Specifically an '08 100mm minute elite.
  100. #100
    I see a thread here with pictures showing clearance on a RS Lyrik
Members who have read this thread: 26
