Results 1 to 10 of 10
    Apr 2016
    Is this normal? New bike check
    I just got back from riding 12.8 mil of Sandy singletrack on my timberjack. It looks like the fork and drivetrain are pretty messy, is this normal after riding in dusty conditions? The the chain looks like it was Lubed with grease, should I clean that off and use some dry lube instead? Should I just wipe that dirt off the front fork and keep on riding or is something amiss?
    Sent from my SM-G920P using Tapatalk
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    normal on a new bike normal on a used bike
    a new bike gets grubbier because there is more ooze and grease since
    it has never been fully wiped down since assembly
    new chains have factory grease, just use oil, wipe off excess, roll
    same with fork, wipe that dirt off, go ride again
    your fork seals do not look too tight, check if there is a service manual
    for your particular front fork and if it needs any seal maintenance or stanchion
    maintenance beyond mere dirt wiping
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Reputation: Mr Pig's Avatar
    Yes, if you ride in dirt you collect dirt.
    Last weekend my son and I spent a few hours on a local free-ride run. It was very dry and dusty and the amount the bikes collected was amazing. What you are showing here is nothing!
    Forks leak a bit of oil up onto the stanchions, that's normal, and of course dirt will stick to it. Wipe them clean and carry on.
    Yes, a drier chain lube is good in dusty conditions. I seal like Squirt chain lube. It's a pig to work into the chain but wipe the excess off and it keeps the chain noticeably cleaner.
    Mountain biking is not a clean sport ;0)
    Reputation: nauc's Avatar
    just wipe if off and ride. new chains are always covered in grease. id wipe as much as you can off. doesnt do any good on the outside of the chain but collect dirt
    when the chain starts to sound noisy, add lube
    i use this. just dont get it on your cassette or gears, it will just collect dirt too. or your brakes, or they wont work worth a crap Is this normal? New bike check-5140-dumondetechoriginalchainlube.jpg
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    That pasty grease that you "just wipe off" is pretty easy work with a rag, paint brush and some kerosene. There are plenty of solvents and degreasers out there but one I've read as universally safe on all chains, roller assembly/internal parts is kerosene. Not pricy either.
    I've used a paint brush and rag to work it in / wipe it off while still on the bike working on the the upper and lower stretch between the pedals and cassette, then moving it along to other non-treated areas. Wipe it good, drip dry in the sun for a bit, go ride a short ways then use the appropriate lube for your area or conditions... ride again for a bit to work that in.
    In the Middle Ages, the biggest mistake was not putting on your armor because you were 'just going down to the corner.'
    Baby wipes work well to get most of that stuff off.
    Quote Originally Posted by party_wagon View Post
    Yeah, but it's very hard to train the baby to do it.
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Quote Originally Posted by Mr Pig View Post
    Just a little patience, really. Getting the baby clean later's the real challenge...that, and getting the hose away from him. Way worse than washing the dog.
    Apr 2018
    I would clean and relube the chain and clean the sprocket. There should not be that much grit on your chainring.
    DFL
    Reputation: askibum02's Avatar
    This right here. I switched over to Squirt recently, and after cleaning all the lube off the chain, and applying two layers of Squirt, the chain was in good shape, but there was a plethora of waxy type lube built up on my chainring, jocky wheels, and cassette. I cleaned all that off, and it has been good to go since. Only an occasional reapplication needed.
    I wouldn't **** you, you're my favorite turd.
  1. Replies: 7
    Last Post: 02-09-2015, 01:18 AM
  2. New bike already breaking - is this really normal?
    By Ann of BC in forum Women's Lounge
    Last Post: 08-12-2013, 08:07 AM
  3. Top-normal or Low-normal: which is better?
    By jasmills in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-16-2012, 03:46 PM
  4. Houndstooth Sportcoat - check; tie - check
    By mtbxplorer in forum Commuting
    Last Post: 04-22-2012, 08:16 PM
  5. Check out my cassette? Normal?
    By mastacox in forum Beginner's Corner
    Last Post: 05-19-2011, 10:46 PM
Members who have read this thread: 159
