Results 1 to 61 of 61
    Registered Dietitian
    Reputation: tommyrod74's Avatar
    Jul 2002
    New Superlight 650b conversion!
    Fox float RLC FIT
    XTR rear derailleur, trail brakes, rear shifter
    XTR crankset machined to 1x, brushed and clear Cerakoated
    Wolf Tooth 36t ring
    Syntace 760mm low riser
    Thomson stem and post
    Bontrager saddle
    Crest rims on I9 h torch hubs (pink!) with DT revolutions
    Kendall Karmas
    ESI grips
    23.5 lbs with pedals
    Very excited to ride once the rain finally stops!
    Attached Thumbnails Attached Thumbnails New Superlight 650b conversion!-image.jpg
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Nicely done.
    Reputation: kerryp's Avatar
    Nice. Intend to do similar with mine when my Jeep is paid off in A couple months. Any mods needed for the rear to get clearance under compression?
    NedwannaB
    Reputation: JMac47's Avatar
    That B super nice! It's a new model right??
    Wait whuuut, who did he tell you that!?!?....
    Jul 2002
    I think it's a 2012. It's missing the tapered headtube, that's why the frameset only cost me $550.00
    I put 20+ off-road miles on it Saturday, and 35+ yesterday in the mountains. It's a very fast bike. I've owned 2 Superlights in the past (4-5 years ago was the last) and have only ridden 29ers in the interim.
    I think I can get it to 23 lbs. without much trouble, much lighter than that will require some use of parts I don't think will hold up too well for an XC/endurance racing bike.
    No carbon on the bike minus the handlebar, which, at 760mm wide, isn't overly lightweight (>215 g).
    The biggest difference in this and the 29er hardtails I've been on is the way it steers, both at slow and high speeds. No more planning my turns well in advance to thread the needle and avoid understeer; this thing steers from the hips like a 26er. Consecutive, turns on fast, flowy sections of trail are so easy and fun it's amazing.
    In the air, it's still not a BMX bike but it is so much better than a 29er it's not funny. Very tossable.
    I'm sure at least part of the reason I'm enjoying the downhills more again is the fact that I have rear suspension for the first time in years, but I think the wheelsize is a big part, too.
    Being able to (finally!) get the bars as low as I'd like to weight the front wheel for high-speed cornering (and still use a riser) is tremendous.
    BB height feels spot on at 12.8" or thereabouts. Could even be a little higher and be OK.
    All in all, a very successful experiment so far and one I'm excited to try in a race.
    Oh, and the Wolf Tooth (XX1-type) chainring is every bit as advertised. No drops even when I tried to make it come off. Drivetrain is perfectly silent (eerily so). Amazing advancement; wish it had been around 5 years ago when I first switched to 1x drivetrains.
    Jul 2002
    Quote Originally Posted by kerryp View Post
    None yet, though I think I hit the cable stop slightly at one point yesterday with the rear tire. Intend to file/dremel the stop off ASAP as I will never use a front derailleur again (on any MTB).
    NedwannaB
    Quote Originally Posted by tommyrod74 View Post
    Yeah ment new as in a '12. I don't think the SL 26 would have tapered. Nice that the conversion worked out so well. 23.5#'s is great! I was toying with getting a frame last year and building it up with my 650 wheels from another 26" experiment. Ended up with a Ventana El Bastardo frame but it's a bit more travel then need. Have 650 and 29r ht's too. I'm still fiddling with staying maybe a SL.
    Jul 2002
    Quote Originally Posted by JMac47 View Post
    Actually, the SL26 is tapered HT for 2013. Not a big deal for me either way (certainly at the price I paid).
    nice! the weight is awesome too.
    i just swapped tires to karma's and was really impressed with my first ride yesterday. but i was coming from nevegals. i'd have to say that i like them as much as the RR i had when i was running 26".
    yeti SB5c
    specialized epic comp carbon - 650b
    Wrench
    Reputation: FNFAL's Avatar
    Beautiful bike man. I had a 2004 Superlight that was 650b for the last half of its life. They really do rip. Brings back fond memories!
    NedwannaB
    I sit corrected
    Actually I assumed they wouldn't go to the hassle of switching to tapered, since it is a 26r after all. But while picking up my bike up at the shop today I looked a little closer at the '13 SL26 and there it was! I just never paid much attention to them since I didn't want to get any wild ideas about building one up .....
    NedwannaB
    Quote Originally Posted by FNFAL View Post
    I remember it before you got the Blur XCc, I don't recall if you get your SL down to that weight.
    this thread has inspired me to convert my SL to 650B... I have a 150 mm Fox 32 RLC 2010, 15mm TA, will lower it for the SL, what works best for a 650B? 120 mm or 130 mm. Any input will help. Thanks
    Jul 2002
    120-130mm might jack the bottom bracket up a little high... I am at 12.8" with a 100mm.
    NedwannaB
    Quote Originally Posted by saddle pimp View Post
    Agree with tommy although several builds I've seen run 120's. So unless you had the 150 on the SL already, which is way over their travel/HA as it is for design, you'll notice a bigger change with ctr of gravity with the 650's!!
    I know when I converted a KHS XCT 140mm travel frame over to 650 the bb ended up around 13.75" with only a 130 fork on it. That in combination of it being a small frame wheelbase left it very twitchy descending at speed. Good ground clearence for tight tecky up down trails.
    NedwannaB
    And dayam you tommyrod for posting that sweet build pic! Now with that build weight of yours(I have very similar components...) you got me
    rethinking picking up one of those frames and build a short guys XC version of a fs 29r which is really what I was after!
    Jul 2002
    I hate to say it, but it's about to drop another ~3/4 lb or so
    NedwannaB
    We wait with BB (baited breath....)
    Nope it set to 130mm as of the moment still a 26 er, I already got the WTB 650 i23s and spokes to go will lace it on XT hubs. I used to run it with a 120 mm F series RLC, no compliants, my 150 RLC float 15mm TA was a replacement to get the the added stiffness of a thru axle fork, i saw in a post here before of a 650b converted SL on 130 mm travel so i brought it down to 130mm. I will be using Nevegals and would be running a 2x10 set up, how much mm spacers should I put on the rear shocks? where did you get the Karma's? i need one for the rear to keep the rolling resistance down... again thanks, will update you guys once I a chance t swap out the wheels... here's a picture of it at 130mm and still a 26'er... thanks guys!
    NedwannaB
    Kenda | Brand | Discounted Mountain Bikes, Road Bikes and Cycling Gear at PricePoint.com
    Not sure about thickness of shims to get clearance depends on your tires and rr deraillure. But lots of "how to's" in forum. Search "advanced search" while in 650 forum for "Superlight shimming shock" refine by clicking under "posts", not threads, and you should get right to the topic. Have not done it but seems simple enuff, or I know PUSH Ind or other shock mod companies do it for a nominal fee (~$25) with a shock performance overhaul.
    Off record, you'll probably get a better ride on the 650 conversion with fork set at 120 unless you're use to the change in geo handling with a taller bb height.
    You can adjust some of that out by sliding seat forward abit and/or lowering bars by either flip stem (if~5*) or pull out stack spacers under stem if you have them. Again depends on your riding style and terrain.
    I have 2.1 Maxxis CrossMarx and they seem to be a good tight fit need tire as well.
    Feb 2007
    Just finished up my 650b Superlight. Frame looks familiar, but mine weighs a bit more than 23 pounds (thank you wheelset, tires, fork, handlebar, stem, crankset, and seatpost)! By the way, I highly recommend the new Grip Shift to anybody running a 1x9/10/11. Much easier to get to the gear you need!
    NedwannaB
    Nice. What crank/ring/cassette are you running on it?
    Thanks in advance.
    Feb 2007
    Thanks in advance.
    Deore crank/cassette (12-36 10-speed) and RaceFace single ring (32t). I wouldn't mind upgrading the crank and cassette, as I could save a fair amount of weight there.
    thanks JMac47... will check these suggestions out...
    NedwannaB
    Quote Originally Posted by mountainbiker24 View Post
    Got it. I noticed you didn't have a chain guide. Is that a clutch type rr der or are you using a tall tooth front ring?
    Feb 2007
    It's a Type 2 rear derailleur. I thought I'd give it a try without the guide, but I ended up putting on a MRP 1x chainguide after dropping the chain a couple of times on the first ride. It was interesting, because I didn't drop the chain when pedaling or riding over rough terrain. I dropped the chain when I either stopped or started from a standstill.
    NedwannaB
    Subtle backspin probably got it off line just enuff. I'm still running 9spd so no clutch type available. Using a similar upper guide (e13 xcx seat tube mount) and xt shadow der on my ht. Moved the setup over to my fs and added a C-Guide lower chain retainer mounted on chain stays. Quiets things down but not quite dialed as it had to be mounted pretty far back on stay from front ring limiting the wrap up around on the bottom of ring. Perfect fix on all these 1x setups is the XX1 but not in budget at this time.
    Jul 2002
    First race this past Saturday - very rooty terrain - zero chain drops (or even chain noise). 6-7 rides on the Wolf Tooth ring and I am so pissed this didn't come out 5 years ago It would have saved a lot of people a lot of headaches. Best $80 I ever spent on drivetrain parts.
    I rode it with the clutch turned off one ride and same result - quiet and no drops. Fantastic.
    NedwannaB
    Good to know. Cassette wise you're still using conventional, not the XX1 right? I'm pondering the Wolf Tooth but with 9spd and no clutch der probably wouldn't be worth it for me.
    JMac (still here holding onto the ledge running 9spd...)
    Jul 2002
    Correct. With this setup I have zero need for XX1 (as I like the XTR shifting, and don't need a 42t bailout for any reason). Standard XTR 11-36 cassette.
    NedwannaB
    Agreed. I have xtr on 2 bikes aswell. Have the 12/36 LX cassette (heavy...ugh...) on the fs trail bike. I had some big("ger" to me) high altitude climbs both days over the weekend(~12 mi/5K and ~28mi/7k respectfully) and using this bike the 32x36 was a lot of work. If I can get a crank that I can drop to a 30 or 28t ring there'd be no complaints with 36 big cassette cog. Love the 1x. I'm a light rider and just don't wear out parts that much to justify moving to 10spd. Yet.
    NedwannaB
    So where's that weight loss you were bragging about??
    Jul 2002
    More like 1/2 lb, it turns out. Here's a pic:
    SDG Carbon seatpost
    SDG I-Fly I-Beam saddle
    Ritchey WCS stem
    Candy 3 pedals
    In my first race on it 10 days ago, 3rd place in Pro/Elite Men in the Monster Energy Pedal to the People Tour XC race. The bike was perfect.
    And, as it turns out, the 650b experiment was so successful... that I'm going to sell the frame and fork.
    I love the ride and the handling... so much that I am going to buy a Blur XC Carbon to convert as my new race bike. A little lighter weight (and the neon green paintjob). If there was a carbon version of the Superlight, I'd buy that instead.
    Look for a classified ad later this evening, I'll be selling frame and fork for a bit of a loss (3 weeks of riding on both).
    Jul 2002
    NedwannaB
    Saw that
    If I had my way Bxc is frame I'd buy. Too many kids still at home pulling at my wallet tho. I was getting ready to have lbs order up a sale SL frame for me but daughter got in wreck and totaled my truck just before weekend. In the beginning stages of finding out about when replacement, or not, will be. Frame will have to wait.
    Good job on your racing.
    get the m985 xtr double crank set 28/40T buy the 30T from wolf tooth as well and u r sweet to go. Yeah they are expensive but they work soooooooooo well. I had experimental prototype make me a custom 27T 88bcd. for big hills
    NedwannaB
    Quote Originally Posted by conrad View Post
    Sounds like a nice setup. Any pix? Like I said, still on 9spd so limited on getting the big XX1 pie plate cassette. I've heard some have used one to get the 40t granny with a 1x10spd der setup and set limits on not dropping to the 10t small cog.
    NedwannaB
    Missed this earlier. Is this thinking it would be lighter in carbon than the BXc or that it's a single pivot design? I've seen that the alum SL29 is ~1# lighter than an alum TB and just curious if this is your take on what the weight differences would be on the carbon SL to carbon Blur.
    Tommyrod,
    I bought the Nickel and converted to 650b too. Love the bike, way more flickable, but I have one problem with it. I came from riding a 29er for the last 4 seasons. I can't
    seem to be able to keep the front end tracking right. I am all over the place. I turn in too early on corners, but I am getting better at it. I swapped over my old stem and bars so the cockpit is the same. It's 1/2 inch shorter than my old bike...should I lower the bars a touch? get wider bars? I fell off a bridge 4th of July on a trail I ride nearly every week! (I am okay).
    Anyone have suggestions?
    Jul 2002
    Quote Originally Posted by cb76 View Post
    Tommyrod,
    Find a way to get more weight over the front - whether a longer stem, lower front end, moving the saddle forward, etc. Also - it will turn faster than a 29er, which is a good thing. Steer with small weight shifts and with your hips. Less turning of the bars needed than with a 29er.
    Jul 2002
    Same idea you had. With a thru-axle rear and carbon frame, the SL would be a Blur-beater, and a lot simpler.
    Yeah, It's the turning that is really throwing me, literally. would a wider bar help? It would move me forward and my inputs that are 29er calibrated would become slightly muted, no?
    Jul 2002
    I run a 760mm bar for XC. Works for me
    New question here. building a 2013 Super light 650b
    Hello Guys. I am new to the Forum. I got a 2013 Super light frame (tapered Head Tube ) I am trying to do the conversion into 650b. The frame is brand new so it has not been built at all. I've been reading some of the forums but I have some questions and since all of you have already gone through this hassle, I am hoping you can share some of your knowledge.
    1. Shock Shimming. Is it absolutely necessary to shim the shock? I am a heavy guy (200lbs) I currently ride a 29er with 2.2 tires. I am thinking on keep a 2.2 tire in this build.
    2. Shock. Since I only have the frame, I need to buy a shock. I have found a couple of preowned FOX shocks in really good condition. First option is a 2014 130mm travel 650b fork. This is already a 650b fork that shouldn't have the clearance problem. My concern is that this might raise the bike BB height.
    Second option is a 26" Fox RL fork with 130mm travel.
    3. Front derailur clamp. I do need the front derailer. I am not that strong If I set up the bike as 650b, will I have to remove the clamp?
    Your input is really valuable and much appreciated.
    Reputation: smmokan's Avatar
    1. Some people think you have to shim the shock "just in case", but I've run mine with no shims and have had no problem with clearance.
    2. Get a Fox front fork, they clear most any 650b front tire. Some Rockshox forks do not, so I wouldn't take a chance. 130mm may be pushing it with the SL, take a look around and see if you can get a 120mm instead.
    3. Front derailleurs work the same regardless of tire size... install it like you would any other bike.
    Steve.
    thanks so much on your quick reply. I will see if I can get a 120mm, or maybe go safe with a 100mm.
    I am definitely getting a Fox fork. I personally do not like Rockshox.
    So would you recommend getting a 650b specific fork or just get a regular 26" Fox fork that will have enough clearance with the tire.
    Are you running 120mm or 100mm in your SL?
    Reputation: weasy's Avatar
    Y'all have me curious now. I read earlier in the thread some converted a 2004 SL. I have a 2003 that I passed down to my wife and rarely ever gets ridden. I do have 2007ish RS Reba 100 on the front. I am wondering if I could convert this with relative ease?
    I also have a 2010 BLT Al with a Float 140. If I could convert either of these I would be stoked.
    NedwannaB
    Quote Originally Posted by weasy View Post
    Pretty sure the Reba won't work. I've seen someone with a 650 on a SID but IIRC was a small tire and tight crown clearance in picture. Either frame and the FOX fork will work. As ssmokan posted above, shock mod's needed by some, on some year frames, not all. Depends on rider weight and tyre size too. **Which btw does come into play with some front der types. Some have a longer cage which can have clearance issues with some knobbier tyres.
    Aburgson- I've only run 26" forks so I can't comment... and I don't know how a 27.5"-specific fork would affect the geo on a SL. It may make the front end too tall.
    Weasy- I have a converted 2012 Blur LT aluminum with the Fox 150mm front fork, and I absolutely love it. No clearance issues and it rides amazing. You'll be blown away by how awesome it is.
    I have just about convinced myself that I will convert my BLT2. Will most likely order up some BWW wheels. I have ridden Fire XC Pro tires forever and have had my eye on the Pacentis. I wonder when the official Panaracer version will hit the market.
    yes pic coming
    Attached Thumbnails Attached Thumbnails New Superlight 650b conversion!-img_1044-small-.jpg
    Oct 2013
    I just purchased a 2013 superlight and am in the process of starting a conversion. This thread has helped a lot but I still need to pick your brains before I start laying down some cash. Here are some of the concerns I have. I will be using stans crest and possibly and x fusion velvet 650 fork. Probably run in between 100-120. I wish to use a 2x 10 drivetrain.
    1. Derailleur stop or derailleur rub against the tire. I'm not sure where the derailleur stops are located in the pre 13 models, but mine has them on the sides of the seat tubes. is that location prone to rub at full compression?
    2. Will a clamp-on shimano derailleur , xt or slx rub against the tire? Would it be advisable to go direct mount and use the adapter to minimize the bulkiness of the clamp on derailleur?
    3. Of course size of tires matters.. racing ralph 2.25, pacenti neomoto, and maxxis crossmark tires are what im leaning towards too.
    I weigh 163 lbs , 5'6" and will pretty much use it on fireroads 75% of the time. I would like to avoid shimming the shock or filing down a derailleur stop. So basically, im trying to eliminate anything that would rub against the tire without messing around with the shocks. Thanks folks, your suggestions will be eagerly anticipated.
    Finished converting mine over yesterday. Unfortunately it was raining all day so no trail test yet, but otherwise it felt fine around the yard. Next project is a 1X10 conversion with a oneup 42t (and 16) ring.
    Update:
    Took it out for a quick 5 mile jaunt after work last night before the storms moved in.
    I was pretty impressed with how it felt. I honestly didn't think I would feel that much of a difference, but the 27.5 seems to hold momentum a little better and feels good. Once it starts moving it is easier to keep speed up and with less effort, but part of that is probably the better and lighter wheels.
    I do feel a little higher, but it is not as bad as 29ers feel to me. On them I just feel too high and awkward.
    The X-Fusion 100mm fork seemed to work pretty well. I need to figure out how to tune it in better, but it handled well. Keep in mind, I am a slow XC rider. I am not too fast or dropping ledges, so it might not feel the same to you Gnar'ers.
    The wheels feel stiffer than my stock wheels, I can feel the weight difference in the rolling mass (my 26" tires had thorn proof tubes and slime so they weighed a bit more than these tubeless, lol). I hope the tubeless hold up around all the mesquites I deal with around here because I like them so far.
    The Mavic Crossroc tires seem to handle really well and have good grip. I like having the wider tire (running 2.2 front and rear). They seemed to float over the loose sand just a little better and the aggressive outer knobs gripped well around corners. I was able to make it up a short hill I usually have problems spinning out on. The tire tried to spin once but dug in and I was able to make it up, which I usually don't
    I really didn't notice the 1" higher BB, but once again, I am just a slow XC rider and that might be more evident to others.
    I have a OneUp 42t and 16t ordered and as soon as those come in, I will be doing the conversion to 1X10 with the Raceface 32t narrow wide I have.
    Rocks belong
    Did you shim the shock?
    Any problems with rubbing on the rear d housing stop?
    Rocks belong
    The wheels feel stiffer than my stock wheels...
    I see you're running Flow EX's (which are pretty darn wide). Any problems with the 2.2 tires on a 29mm (25mm internal) rubbing the seat stays?
    I haven't shimmed the shock yet, but I am also running it stiff and locked out right now, so very little movement until I get the front der removed. I don't run a lot of cush in my shock so I don't expect it to rub.
    In response to the other question on tire width, I have clearance on both sides and no rubbing of the tires.
    @CigarsNJeeps
    Attached Thumbnails Attached Thumbnails New Superlight 650b conversion!-imageuploadedbytapatalkhd1397872415.965611.jpg
    Rocks belong
    Thank you for taking the time to respond to an old thread and taking/posting a picture!
    With you as inspiration, I did a test fit tonight and my Sun Ringle Chargers (similar to Stans Flow EX's) with a Kenda Honey Badger 2.2 fit no problems. Closest I came to rubbing was the front derailluer cage (which I can't work on that). The Kenda HB is a high volume tire, but did not lead to tire width problems on the seat stays.
    The frame is a 2013 Santa Cruz Juli 3.3 (tapered head tube)... Which I believe is now the Juliana Origin. I'm planning to run a 100mm Fox F29 (tapered, 15QR) up front. Test fit shows my HA is right around 68.2*... Which is slack for a 4" bike, but perfect for Colorado trails.
    Rocks belong
    BTW: @CigarsNJeeps?
    I'm not sure what that means, but sounds right up my alley. I have a '98 TJ (lifted, locked and loaded) that I play with when I'm not mountain biking.
    Re: New Superlight 650b conversion!
    No problem. Was easy enough to respond. Glad I could help. That is my twitter acct. I have an affection for cigars and jeeps. New Superlight 650b conversion!-uploadfromtaptalk1397907435211.jpg
    Quote Originally Posted by smmokan View Post
    So a year later with no shim and still going fine? What year do you have? I'm looking at a 2013.
    Jun 2014
    If anyone is looking to get a white frame back country has them for 399. Use active junky and get 13% back.
    Last I checked they have m-xl. No small
  1. Santa Cruz Superlight conversion
    By FNFAL in forum 27.5
    Last Post: 01-24-2015, 08:10 PM
  2. Replies: 3
    Last Post: 12-13-2012, 01:21 PM
  3. Superlight 650b Review
    By Woodnwheels in forum 27.5
    Last Post: 10-30-2012, 04:29 PM
  4. 650B 2010 Superlight
    By Waterat Pat in forum 27.5
    Last Post: 09-08-2012, 09:42 AM
  5. 650B Superlight
    Last Post: 03-01-2012, 12:23 PM
Members who have read this thread: 9
