Results 1 to 22 of 22
    Jan 2015
    My First FS BIKE, 2016 GIANT TRANCE 3
    I got a 2016 Giant Trance 3 yesterday for a bargain price. It's my first FS bike so I don't know if there's a configuration that I need to do before riding it.
    Anyway, my question is... can I convert this trance which is a TRAIL bike into enduro type ?
    Apparently, it has 140mm fork and rear sus 140mm as well.
    Reputation: Steel Calf's Avatar
    Feb 2010
    The Trance is plenty capable and was ridden in the EWS 2014 with 160mm forks before the Reign eventually got available the next year, I ride the 2015 Trance SX myself on more gnarly trails where people usually show up with real enduro and DH bikes
    The only three upgrades I'd strongly recommend is a shorter 50mm stem/wider 780mm bar, a bigger 200mm disc front (use the existing 180 disc in the rear) and a 150 or 175mm dropper post depending on what fits with your body / frame size combo since the ability to quickly lower your center of gravity is most essential these days
    On a new bike taking all bearings apart and greasing them is highly recommended, otherwise your chances are good that headset and bottom bracket will be shot within 1-2 years and frame bearings in 2-3 years (people who ride hard and wash their bike a lot even quicker)
    Theoretically to go "more enduro" you would also need to upgrade to wider 30mm wheels and Maxxis 2.5/2.6 tires (since 19mm inner width rims are hardly suited for >2.2 tires), a 160mm fork (which slackens the headache to 66) and a 1x drivetrain (you'll loose the chain a lot on that 2x10)
    I remember in 2014 I considered the red Trance 3 myself but eventually went for the 2015 Trance SX since it already comes with more enduro like components like 160-140 fork and wider bars, the only component I immediately upgraded was bigger 200mm/180mm discs and a longer dropper post (first 150mm and later 175mm once they got available)
    This year I switched to wider wheels to suit 2.6 tires and went from 1x11 to 1x12 since the drivetrain was worn anyway
    btw there's a Giant sub forum here with its own Trance thread and thousands of posts, I don't know why most newbies struggle finding that and instead post in this pointless 27.5 forum
    Jan 2015
    Thanks Steel for detailed information.
    At least now I know that I dont have to buy reign for enduro bike.
    Sent from my SM-G950F using Tapatalk
    Jan 2015
    By the way, if you change the the disc, does it mean you will change hubs or something too?
    Feb 2010
    I see you found the Trance thread but why don't you read some of the 3000 posts in there before posting questions? Scroll back to fall 2013 onwards since that was the first season of the 27.5 Trance, many people posted their "enduro" setups in great detail!
    If you're in a hurry search the thread for "Pike" or "handlebar" since swapping out fork and adjusting the cockpit is the first things done
    Bikesexual
    Reputation: jcd46's Avatar
    You can search even faster on google, just add mtbr with your search and BOOM! you will find threads on what you need.
    Jan 2015
    Reputation: asinchaos's Avatar
    Apr 2014
    Quote Originally Posted by gat3keeper View Post
    I see you keep mentioning the word 'Enduro'. How do you exactly define 'enduro'?
    Sent from my E6533 using Tapatalk
    Apr 2014
    Quote Originally Posted by Steel Calf View Post
    Nice looking Trance you got there. What size rear tire is it?
    Feb 2010
    2.6
    Jan 2015
    2.6
    Did you change your hubs as well when upgrading to 2.6 tires?
    Jan 2015
    Quote Originally Posted by asinchaos View Post
    There are various bike category
    XC, Trail, all mountain, enduro, downhill...
    Trance is a natural TRAIL bike... So going enduro like bike need some changes on bike components here and there. From 140mm fork to 160mm for example.
    Feb 2010
    ah goddamn it...
    wheels = the combination of hubs, rims, spockes. "New wheels" implies new hubs, "new rims" usually implies they were just laced on existing hub
    "switched to wider wheels" = I removed the old wheels from the bike and installed a new wheelset which is wider
    2.6 tires = tires which are 2.6" wide
    what tires, what rims exactly??
    It's all written in great detail in the official Trance thread...
    Jan 2015
    Steel Calf, what is the avg psi for rear sus and fork. Im approximately 75 to 80 kilos
    Feb 2010
    100psi fork, 200psi shock, 78kg naked. However these values are of no use for you since I ride a different fork and shock.
    Feb 2006
    Option A:
    start with a beefier fork with 34mm stanchions + (35/36mm is ideal)
    -fox 34/36
    -Marzocchi 350NCR/CR
    -RS lyrik/yari/pike/New Revalation "RC",
    -Manitou Mattoc
    -Suntour Auron RC
    -DVO Diamond
    -ETC
    shorter stem 40-60mm
    wider bars 750mm +
    build a strong wheelset using:
    -dt swiss ex511/xm481 ,
    -wtb i29/i35 (frequency / asym)
    -stan flows mk3
    -any rim that has a i29mm+ internal width
    -ETC
    i highly suggest using a hub that can be converted to XD such as Hope pro 4 / DT Swiss 350 etc
    last but not least
    swap your brake pads for Shimano E01S (sintered pads)
    you'll need new rotors too, shimano RT66 is a good budget choice
    Option B:
    ride your bike and find you limit (stock trance is a pretty capable bike)
    Dec 2014
    and shoes
    dont forget to tell him about the shoes
    oops I wasn't clipped in
    Since this is your first FS bike, I say just ride it as is. The regular trance is still a capable bike, and if you're coming from a HT will be incredible with the amount of speed and traction a properly dialed in rear shock offers.
    Unless you're racing, I don't think there's a big necessity to spend a bunch of money right away on new fork, wheels, etc. It's a good bike, ride it and have fun.
    Feb 2010
    Quote Originally Posted by Fluidworks View Post
    I fully agree. Why buy a new bike just to swap everything out right away, gain some riding experience first before making any hasty decisions
    Jan 2015
    Thanks. I will use this bike like there's no tomorrow. hehe
    That's what I need to learn. To tune my bike here and there.
    Jan 2015
    Thank you Steel Calf... I appreciate your response to my queries.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    This^
    Something tells me you are not going to out ride this bike any time soon.
    As we use to say, before the advent of multiple mtb disciplines...
    "Run what ya brung." Ride it with pride.
  1. Should I get a Giant Trance 3 2016 or a Giant Trance 3 2017?
    By harell286 in forum Beginner's Corner
    Last Post: 01-04-2017, 09:25 PM
  2. Replies: 9
    Last Post: 12-08-2016, 12:16 PM
  3. 2016 Giant Reign Advance 1 vs 2016 Giant Trance Advance 1
    By Corporate in forum Bike and Frame discussion
    Last Post: 12-07-2016, 08:01 AM
  4. Replies: 3
    Last Post: 04-30-2016, 07:06 AM
  5. 2016 Giant Trance 1 vs 2016 Giant Trance Advanced 1 - Input Needed
    By guitarman2011 in forum Bike and Frame discussion
    Last Post: 03-27-2016, 02:26 PM
Members who have read this thread: 4
