Results 1 to 50 of 50
    Reputation: vizsladog's Avatar
    My carbon 650b build.
    I Love this thing. went from a Nickel to this. I was expecting to get beat up but its soooo fast and the carbon soaks up alot of bumps. After i got about 60 miles on it i was dialed. every pedal stroke equals forward excleration
    Weighs 21.9 as it sits
    Frame...Fr-503 from ebay. seller was zgr9 to my door in 8 days
    Wheels..American classic 101 with stans hubs
    Fork..Xfusion velvet 100mm
    Brakes..Magura louise Bat
    Rear der....sram medium cage x9
    Shifter..sram x9
    Bars..truvativ noir t30 600mm
    cranks..sram x9 with wolfstooth xx1 style direct mount 32t
    seatpost..fsa slk carbon
    seat..prologo kappa dea
    stem..origin 8 pro 80mm
    grips..esi racers edge
    Bottle cage..blackburn slick racing
    Dec 2004
    looks great!...curious though on the frame...is there a warranty?
    6 month warranty. It was just over 300.oo to my door. It came with a headset but the top bearing was junk
    Reputation: smmokan's Avatar
    I don't understand... If carbon is supposed to be so much stiffer than alloy, how does it "soak up bumps"?
    It's an honest question.
    Reputation: michael9218's Avatar
    Quote Originally Posted by smmokan View Post
    That's the beauty of carbon. It's all in the design and layup of the carbon. Large main tube, BB area, and chain stays make the bike efficient while thin seat stays give the bike a soft feel on the trails.
    Looks good. The Wolfstooth/XX1/RFNW is also a great mod plus inexpensive. CF when built right can feel very nice on the trail or on the road.
    Reputation: trailbildr's Avatar
    Dec 2004
    Is this the same frame? Looks like a Jamis Nemesis. $300?!?! Damn... You can even get a crappy steel frame for that
    JAMIS BICYCLES
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    Its actually very close to the scott frame.
    SCOTT Scale 700 Premium Bike - SCOTT Sports
    Quote Originally Posted by vizsladog View Post
    Are all those carbon frames basically the same on ebay?
    I saw different numbers, but they look about the same to me.
    BTW- nice ride!
    roccowt.
    rocnbikemeld
    I did read that some have the larger rear axle size...I got some 650b parts...I might get one.I used to be scared of carbon frames since I'm a big guy.(around 230)...but since I can't ride too hard anyway due to an injury,i'm pretty sure I can ride one-no problems.
    roccowt.
    rocnbikemeld
    Mar 2013
    the blanket statement of carbon is stiffer than alloy (technically alloys can be anything including aluminum, steel, titanium) is too broad to give a valid answer.
    Carbon can be stronger than an alu alloy, but allow for flexibility depending on its materials, manufacturing and design....
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    Dec 2004
    It looks like the Scott for sure. The Jamis has that extra fin-like material above the top tube at the seat tube junction.
    I don't know how much in-house engineering Scott does but they may be like Jamis. They don't have any in-house engineering. They, like many companies, ask for certain production specs based off of what the Taiwanese and Chinese OEMs can make. It's called a catalogue bike. You can order volume and sizes based on their design and make changes if you pay for them but all of the engineering, pre-production and manufacturing is done overseas. I know for a fact that Spec'd, for example, has in-house engineering and design staff that will create all of the CAD, fea, etc and then ask somebody to pull it off (Merida).
    I think the Jamis looks better, for whatever that's worth...
    mk
    TrailWerks Cyclery
    There are some different frames on there. The fr503 is the newest. You can get bsa bb or bb30 the 502 is a bit different. Id go with the 503
    Jul 2013
    Nice looking bike!
    FS: Santa Cruz Tallboy Carbon 29er
    Daily: Specialized Rockhopper Comp 29er
    Road Bike: Specialized Diverge Elite DSW
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    tits-swift!
    I don't rattle.
    Thanks!!
    Sep 2013
    how's the tire clearance? would winter mud be a problem?
    DILLIGAF
    Reputation: msimmons's Avatar
    How does it handle the vortex rock gardens?
    Tire clearance is very good.
    And it handles the vortex great. Just needs a better rider on it...
    Aug 2010
    looks good. I just ordered the same frame last week. Should be a nice build when all said and done. Hoping for 20-21 lbs total but we will see.
    Very clean looking bike!
    Rear disc accepts 140mm or 160mm?
    Nice build.
    Aug 2010
    rear accepts 160mm rotor
    And BB type is BB30 with bearings directly inserted or BB30 with pressfit?
    Mar 2013
    Quote Originally Posted by patrul View Post
    what?
    Quote Originally Posted by SandSpur View Post
    what?
    This one
    Or this one
    Mar 2013
    The top one is BB30 the bottom one is PF30...
    from the photos it looks like he is using GXP...
    Yes, I know each one
    Yes, he is using GPX
    I have asked the seller regarding the BB type for 30mm. I will let you know
    Hi,
    I have a problem with the upper bearing of the headset. The bottom fits perfect but the upper bearing is smaller than the cup, and this cup seems not having enough depth. The size of the upper bearing is standard IS42: 41.8mm 45 45 8mm height... But, look these pics
    Hi,
    No answer? Any idea is welcome
    Mar 2013
    try posting your own thread for your question. This topic was started by Vizla to show off his build...
    Thanks and apologies
    Ok. I had problems with the headset that came with it. Junk it.....as in the case with the chiness carbon 29er thread the neco headsets are hit or miss. Got a cane creek and issues were solved
    Mar 2013
    what were the problems?
    Reputation: sandyeggo's Avatar
    Mar 2011
    Which cane creek model headset did you get?
    2015 Trek Stache 7 SS
    2015 Cannondale Bad Habit
    2015 Niner RLT
    My lbs put the headset in so im not sure which one, but i think he said it was a 110. The headset would not tighten all the way. It popped and cracked and creaked. My buddy who is a pro mechanic for 25 years was tired of messing with it so he replaced everything even the star nut. No more problems.
    Oct 2012
    I have the exactly same problem with my Neco Headset could not get it to stop creaking, so I bought FSA headset and hopefully it will solve my problem.
    It should fix it. Just replace everything. They are junk. I havent heard of anyone having problems after they replaced thier headsets
    Same frame.... Very very happy!!!
    The Neco headset is definitely junk. Mine fit fine and didn't creak, but was showing rust after only a few rides (got wet on one of the rides). My FM 136 used the FSA .042 ACB headset fitment. I replaced it and all has been fine since. I would just decline their $15 headset and buy the FSA separately (costs about $40).
    Nice bike patrul
    Jan 2014
    Hi, this is my first build & just received this frame. I am a little confused by this headset issue. What was the one you guys used that worked? Looking at the 29er thread (I think same headset for that frame) the cane creek IS42 top & IS52 bottom is what is best.
    1 more thing, the travel on the fork? Any idea what this frame was designed for like 100 or maybe 120?
    Thank you & happy new year!
    Which is "this frame"? Did you buy the FM136? If so, the headset you need to buy is the FSA Orbit C 40 (No.042 ACB).
    FSA Orbit C 40 Tapered for 42mm 52mm ID Headtube 1 1 8" to 1 5" Steerer | eBay
    The FM 136 is designed for a 100mm fork.
    I solved with this upper bearing
    Jan 2014
    What is that though, could you say what the brand & model is.
    The frame I got is the fr503, the one that the op has I think. Not sure if the fm136 has the same design.
    Quote Originally Posted by loptur View Post
    I bought on eBay...
    bit.ly/1l1ALb6
    May 2012
    Can you tell me how much it has cost for the total build? Trying to gauge if I want to do something similar. Thanks!
    I have the same question. Could one of you post an approximate cost for your build? I'm very interested in building a hard tail 650b and wondering if I can come-up with the funds to build one. Until now, with the high priced frames I was looking at, I wasn't sure I could but this frame looks good and the cost is very reasonable! Thanks.
    2,5k€ more less, I had some components on stock, so my real cost was a little bit behind. The bike is 8,5kg
    Thanks Patrul, that helps a lot. It looks great, and I bet at the weight it's also a lot of fun to ride.
  1. Replies: 2
    Last Post: 10-09-2014, 07:27 AM
  2. Replies: 1
    Last Post: 05-21-2013, 02:36 PM
  3. New 650b Build! What do you think?
    By chrismit in forum 27.5
    Last Post: 04-18-2013, 08:44 PM
  4. Replies: 10
    Last Post: 03-16-2011, 04:15 PM
