Page 10 of 10 FirstFirst ... 678910
Results 901 to 919 of 919
  1. #901
    Giant Reign 27.5 2 LTD
    Reputation: ka81ua's Avatar
    Oct 2014
    You meant whistle I was talking about?
    What tyre width to deal here?..
    OK
  2. #902
    Oct 2014
    DBC
    When I push the rod (upward) there some oil with air coming out from the place I noticed on photo.
    Is it supposed to be so (also when fork assembled)?
    OK
  3. #903
    Feb 2006
    yes
  4. #904
    Oct 2014
    Uhmm.. Isnt it supposed to come out through the little hole on dbc tube??..
    OK
  5. #905
    Reputation: MikeBurnsie's Avatar
    Jan 2011
    Quote Originally Posted by ka81ua View Post
    DBC
    You need to turn the socket head in to a depth of 6mm. When you removed the compression nut it backs out. Just set the depth to 6mm like I said and reassemble.
    https://www.youtube.com/watch?v=Bd5MgKJ0muQ
    2016 Transition Patrol
    2011 Stump Jumper
    2018 NukeProof Scout
  6. #906
    Oct 2014
    I use remote lever to lock out fork. So, when I will assemble the fork should I turn the socket head in to a depth of 6mm before installing compression nut?
    Thank you.
    OK
  7. #907
    Jan 2011
    Thank you.
    Yes, doesn't matter what remote you use.
    2011 Stump Jumper
  8. #908
    Oct 2014
    Thank you very much.
    P.S. what if not downing it 6 mm depth? What will happen?
    OK
  9. #909
    Jan 2011
    Your're experiencing it right now.
    2011 Stump Jumper
  10. #910
    Oct 2014
    uhmm.. didn't get it (maybe my bad english)..
    If I wouln't turne it down 6 mm - anyway it will be turned by compression nut, will it?!..
    OK
  11. #911
    Jan 2011
    It will, but it won't be at the depth it needs to be. 6mm is where it needs to start to achieve the proper depth. That interface is your soft/firm compression setting.
    2011 Stump Jumper
  12. #912
    Oct 2014
    By the way, I pushed few times the rod of DBC and some small amout of oil got out from that place I noticed with red arrows.
    May I turn socket head almost out, so there will be some free space and I will be able to put in a little bit of oil (fork oil 7.5W)? Should I?
    OK
  13. #913
    Jan 2011
    You can put it in the lower fork as it will get pulled into the DBC from the bottom of the DBC.
    2011 Stump Jumper
  14. #914
    Oct 2014
    Thank you very much for all advices! )
    OK
  15. #915
    Sep 2014
    Sorry to revive this old thread, but has anyone had any luck using a different grease than Molykote o-ring grease for the seals on 2016ish forks? And, also, is Fox 7.5 oil okay to use on these forks?
    I got a 320 LCR and before installing I want to check oil levels and since I'm way too nervous for that I took it to the supposedly Fox certified LBS we have here. They said they could service it but they don't have the same grease and they use Fox oil.
  16. #916
    Jan 2011
    I have a 350 ncr and used Slick Honey. When I got it last year I opened it up and changed the oil and grease. On the damper side just oil in the lower to satisfy the DBC cartridge and slick honey between the oil and dust seal. I did the same on the air chamber side seals. I used grease on the spring and spring seal head with a little oil in the lower leg to splash the bushings. I refreshed everything about a month ago. I had no issues with grease migrating from the seals to the DBC oil bath. On the spring side a little oil splashed the lower spring assemble and mixed with the grease with no ill effects whatsoever. I just sourced two quarts of Golden Spectro 7.5 on Amazon, that's the recommended cartridge oil. I don't know anything about Fox's offering in that weight. I use there 10wt red in my Float fork.
    2011 Stump Jumper
  17. #917
    Oct 2014
    Help someone please. I installed remote ( https://www.youtube.com/watch?v=whz7qx0JuWE ) but it FULLY locks fork only when it pusshed little bit more than just ''to click''. I tried adjusting barrel but somehow it doesn't help. So, only when I push remote more the fork is bacaming rigid. Maybe I should play with the depth of low speed compression rod? Maybe more than 6 mm or less? I mean https://youtu.be/Bd5MgKJ0muQ?t=90
    OK
  18. #918
    Oct 2014
    Quote Originally Posted by cobym2 View Post
    Mine came with the remote, but no manual lever. Not that I use the lockout often, but if I did, Id probably like the lever (non-remote) more.
    Can somebody please tell the part number of Manual lock out lever for Marzocchi 350 ncr like in the video or link where to buy it?..
    OK
  19. #919
    Oct 2014
    Maybe it's 8501766/P (replaces 5497001/P)
    KNOB KIT UPGRADE RC TO MANUAL LCR/NCR
    or
    5497001/P (replaced by 8501766/P)
    OK
  1. 2007 Marzocchi 66 Fork VS 2006 Marzocchi 66 Air Adaptor
    By jdiabolik in forum Downhill - Freeride
    Last Post: 02-24-2014, 11:44 AM
  2. Who was late to the party and why? I need help.
    By teamdicky in forum 29er Bikes
    Last Post: 04-25-2012, 03:44 PM
  3. Marzocchi 44 RLO or Marzocchi Marathon LR Suspension
    By aL1 in forum Shocks and Suspension
    Last Post: 07-17-2011, 07:02 PM
  4. Late introduction
    By DavidF in forum Beginner's Corner
    Last Post: 07-16-2011, 05:47 AM
  5. DH race late 90s
    By Loll in forum Washington
    Last Post: 07-14-2011, 11:35 PM
Members who have read this thread: 60
