Results 1 to 17 of 17
    Looking for a Substitute for Specialized Tires!
    So I recently completed a Norco Sight build and I currently have a 2.4" Vee Rubber Trail Raker on the front and a used Kenda Nevegal 2.35" on the back my LBS was kind enough to give me. The Vee Rubber is huge but the compound is very plasticy and it does not grip like its chunky looks suggest. The Nevegal feels like a boat anchor in the back, weight is fine but the rolling resistance is kind of unbearable to me.
    On my Yelli Screamy 29er I run a 2.3" Purgatory in the front and a 2.3" Ground Control in the back. I like the combo quite a bit. They aren't the lightest but they roll fast and the GC slips just before the purgatory in a very controllable manner. Since Specialized does not like 650b, I'm SOL and need a replacement.
    I prefer both tires to be reasonably light (sub 800g), high volume, roll fairly quickly (especially out back). I don't mind a slightly slidey back end as long as it breaks loose in a predictable manner. Front should be pretty sticky. I corner very aggressively but I do have to earn my turns on 10+ mile climbs so I need a balance.
    Was considering these combos but I'm totally open to suggestions.
    Conti MK2.4 Front, Xking 2.4 Rear
    Bontrager XR4 2.35 Front, XR3 2.35 Rear
    Schwalbe NN or HD 2.35 Front, NN 2.25 R
    Anything else I'm missing? Tires make or break a bike so I need some wisdom!
    Reputation: mestapho's Avatar
    I like my Ardent 2.25 as a rear. 712 grams. I love my HR2 on the front but it is heavier than what you want. Both are wearing very well. The Schwalbes just wear out too fast, ESP the Trailstar versions.
    I had Ardents on a 26" bike and they were pretty good tires. I wouldn't mind trying one out in the back with a DHF in the front but I'm not sure I can wait long enough for that to become available.
    Quote Originally Posted by rusty904 View Post
    If you're willing to go with a tank like the DHF then I'd say give the HR2 a try. My 2.3 is less than 900 grams.
    Never much cared for the HR1, I kinda figured the HR2 would be pretty similar. Maxxis says the Minion 2.3 650b with 3c and exo is supposed to be 825g so over what I want but not terrible.
    At this point I'm kind of leaning towards the 2.4MK and 2.4Xking combo, they look the most like the purgatory/GC.
    Reputation: Mallet21's Avatar
    Sep 2013
    Selfishly the ONLY reason I want Spesh to get into the 27.5 game is for their rubber.
    Quote Originally Posted by Mallet21 View Post
    Agreed, my purgatory/GC combo has been damn near perfect. Easy to set up tubeless, roll fast, grip well, decent weight, wear hard, and typically cheaper than other brands. Can't ask for more.
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    I am on my second set of Neo Moto 2.3's. Couldn't be happier.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    Quote Originally Posted by Prophet Julio View Post
    got tired of the constant sealant leakage.
    Just a flesh wound
    I read here that Panaracer is making them tubeless ready with 90 tpi.
    This ^^. Would love some Purgartory and Butchers in 27.5. Light, durable, roll well, decent price.
    Feb 2012
    My current setup is Vee Rubber Fluid 2.4 front / Kenda Honey Badger 2.2 rear, both on wide Derby rims. The Fluid grips better than the Trail Taker and I like it a lot, and the Honey Badger is a superb tire that just bites into stuff, much better than a Hans Dampf 2.25 that becomes useless after 200 miles. When I wear the Fluid down, I am tempted to go Honey Badger front/rear.
    Just a flesh wound
    StiHacka, how do you like the Derby rims?
    With regards to the Neo Moto leaking issue, I have found that a shot of Stan's every 5 or 6 weeks keeps things good. That means just one scoop. I squirt it into the removable valve core. It must take at least 4 minutes to do both. I am willing to do this only because I like them so much for the way they handle everything. A one tire quiver.
    Maxxis ikon 2.35 rear / ardent 2.4 front would be a nice fast and durable tire similar to the purg/ground control.
    Feb 2012
    I love them! I am sure you would like them a lot, too. They give a nice profile and improve traction for smaller tires like the Neo Motos. We should plan a ride in your neck of the woods when temperatures drop and trails get firm.
    Reputation: reformed roadie's Avatar
    Here's a reason not to buy Specialized tires, or anything from them for that
    matter
    War vet forced to change bike shop?s name after threat from Specialized | Calgary Herald
    I got the bontrager XR4s 2.35 front and 2.25 back about 3 months ago and I love them. I was in velociraptors before and the bontragers are noticeably better at corning. They are very predictable, and are a big improvement over bontragers previous attempts at tires
    What goes up must come down.
    2015 YT Capra AL2
    2014 Chromag Aperture
    2008 Pinarello FP2
  1. I think I'm about done with Specialized tires
    By skyno in forum California - Norcal
    Last Post: 06-23-2013, 07:36 AM
  2. Specialized Tires
    By Fred Smedley in forum Idaho, Montana, Wyoming
    Last Post: 12-27-2012, 01:28 AM
  3. Specialized Tires
    By vinnyl26 in forum Specialized
    Last Post: 07-23-2012, 05:05 PM
  4. New Specialized Tires?
    By chas_martel in forum Wheels and Tires
    Last Post: 10-23-2011, 06:22 PM
  5. Specialized Tires...
    By Possum in forum Specialized
    Last Post: 08-19-2011, 09:14 PM
