    Reputation: madsedan's Avatar
    Aug 2010
    lightweight 130mm fork suggestions
    Looking for a 130mm fork that is 3.5# or less, suggestions?
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    Meeeeeeeep
    Reputation: Dooms101's Avatar
    Mar 2011
    The x-fusion velvet is an awesome fork and pretty light. I think the tapered 15mm axle version with a cut steerer is about 3.8lbs. You probably have to find something more exotic with a carbon steerer and crown to reach the weight you want. I am pretty sure cannondale made a 140mm 26er lefty fork that I would assume is pretty damn light, you could probably add a travel reducer like you can with the other leftys and run it at 130mm if you have clearance for a 27.5 wheel.
    Aug 2010
    Yep, I have the velvet tapered with 15mm now and with the steer tube trimmed its just under 4#. I guess I should be happy with what I have, if someone knows of anything at 3.5# or less I'll give you 10,000 internet rep points lol.
    my 2013 Velvet qr15 w/ cut 1 1/8 steerer and no star nut was 50g heavier than my Revelation with 20mm Maxle, longer steerer w star nut, and xloc remote. I was really surprised to see that. I don't recall the exact weight now, but the Velvet was definitely closer to 4 lb than to 3.5.
    Oh yeah, the rev is also 150mm vs 140 for the Xfusion, but the rev is a 26" fork and won't take the big 650b rubber of the Velvet.
    Point is, I don't think you're going to get there with currently available forks, and will probably take a noodly open dropout 32 platform to get close.
  1. Lightweight fork upgrade need suggestions!
    By A-Ray in forum 29er Components
    Last Post: 05-16-2013, 10:14 AM
  2. Lightweight 50mm stem suggestions?
    By rusty904 in forum All Mountain
    Last Post: 05-15-2012, 07:15 AM
  3. So Cal Riders: Lightweight 29er Tire Suggestions
    By SCR818 in forum Weight Weenies
    Last Post: 12-31-2011, 09:51 PM
  4. Lightweight Rigid mtb fork suggestions?
    By Hardtailforever in forum Weight Weenies
    Last Post: 06-16-2011, 08:54 AM
  5. Replies: 6
    Last Post: 02-16-2011, 07:40 PM
