• 09-13-2012
    JChasse
    An Intense Tracer 275 build
    I thought I’d post this in case anyone else is thinking about a Tracer 275 as a (relatively) lightweight trail bike build. Or just for other bike geeks...
    Seems like all of our local rides, from in-town stuff to big high country rides, follow the same recipe – starting from the trailhead, climb. Then climb some more. When you become hypoxic and are about to forsake mountain biking, you reverse course, and descend.
    We’ve got absolutely great riding, but you want a bike that can go uphill and down.
    So anyway, I’m replacing this (note the custom chainstay protector - a beer can label destined for a Silverton Ice Pick Ale, with a piece of thick 3M protectant carefully slapped over it. It actually works great. :smilewinkgrin:):
  • 09-13-2012
    JChasse
    I rode and loved a Ventana for 11 yrs, and finally updated to a 2010 Turner 5.Spot. It’s a great bike. But for whatever reason, I never connected with it (or something). When I got the 5.Spot, I also really thought a lot about the 650b Ventana El Bastardo, but wanted to try a more “modern” suspension, so went for the DW Link Spot.
    Like I said, for whatever reason, the Turner's never really clicked for me. I rode a 26 inch Carbine, and liked it more than the Turner, so I’m working with a great local shop (Pedal the Peaks) to build up a Tracer 275. (I would have done a 27.5 Carbine, but really want to try a bike that's been designed from the ground up for 650b...)
    The frame was ordered a few weeks ago, and parts are starting to trickle in. I’m pretty psyched about it…here’s what we’ve got so far.
  • 09-13-2012
    JChasse
    I’m a little obsessed with bike stuff (hard to beleive around here!), so I’m weighing parts just for the hell of it. My hope is that I can build the Tracer to come in at or under the weight of the 5.Spot (26.85lbs as pictured, with cage, pedals etc), but without any stupid lite parts. I doubt it’ll be possible (the fork's kind of a heifer, but I like having travel adjust)...wish me luck.
    Here’s the build spec so far:
    Enve 650b XC wheels, laced to DT Swiss 240 hubs with DT Aerolite bladed spokes (Not sure bladed spokes are necessary on a mountain bike, particularly as slow as I'm going. I had to go with these hubs – you’ll understand why later). Weights with Gorilla tape “rim strips” and tubeless valves (no skewers, brake hardware etc):
    Front – 690g
    Rear – 770g
    Fox 34 Talas 650b fork (uncut steerer) - 4.64 lbs
    Thomson 100mm stem: 160g
    Tune QR seatpost collar: too light to register on my bike scale…seriously.
    Stay tuned - more to come.
  • 09-13-2012
    carverboy
    Wow, should be nice can't wait to see where you end up. My 650b is around 30 pounds and after 3 years It does not seem heavy at all. I think people get to hung up on weight sometimes. Then again if my bike was 27 pounds I would be a very happy camper!:D
  • 09-13-2012
    lixxfe
    Originally Posted by jchasse View Post
    enve 650b xc wheels, with dt swiss 240 hubs (i had to go with these hubs – you’ll understand why later).
    sram xx1?
  • 09-13-2012
    Morpheous
    You must be good with the ladies...or...your wife/girlfriend/SO must really like your slow buildup.......;)
  • 09-13-2012
    JChasse
    Originally Posted by lixxfe View Post
    sram xx1?
    Ed Zachary.
  • 09-13-2012
    JChasse
    I may have posted (:D) prematurely, but they aren't even shipping the rest of the stuff yet.
  • 09-13-2012
    Morpheous
    LOL JK, this should be a great build...:thumbsup:
  • 09-14-2012
    cbrossman
    Nice start,
    but you are really putting the pressure on the husbands of other Spot owners ... me.
    It would make my life much easier if you traded in your Spot for a $1000 hard tail SS, then convinced the Mrs. to do the same. I've just saved money and have less maintenance to do before each ride.
  • 09-14-2012
    JChasse
    Just don't let her read this thread. I'm telling my Spot-owner wife it's only about the wheel size. (and 26 inch wheels are perfect for girls their size, right?)
  • 09-14-2012
    skidad
    When do the Tracer frames start shipping?
    It'll be interesting to see how close you get to the goal weight. I think 2 Carbines have been built now on the Forum with one at 28 and change and the other at 30. The one at 30 even had the Enve rims.
    What didn't gel for you on the Spot? How was the climbing in real techie stuff?
  • 09-14-2012
    JChasse
    They're saying around Oct 1.
    I honestly doubt I'll get to the Turner's built weight. The build kit will be lighter on the new bike, but I assume the frame may be a bit heavier than the Turner (6.8 lbs for the medium Turner frame with shock - not sure what the Tracer will weigh), and the fork is considerably heavier (~ 3/4 of a lb). Not a big deal, but it would be great if it's not noticeably heaver than what I'm riding now.
    Aside from subjectively just not being excited by the Turner, I've noticed 2 things I don't like, particularly after spending a little time on the Carbine 26inch VPP bike for comparison. First, the Turner suspension is a LOT stiffer / less compliant than the Intense. So while it seems to climb a litle better, the suspension seems a lot less effective at absorbing the small stuff - it makes for a really jarring ride IMHO. And I've played with the suspension settings a bunch...it's just a stiff platform. I've heard rumors about some Turners with bad/sticky pivot bushings, so I suspect I may be part of my issue.
    The second thing is more about the geometry (I think)...Even on the first ride, the Intense was more confidence inspiring than my Turner (even though i had been on the intense for 3 hrs vs 2 seasons on the Turner). That was an eye opener. I've been professionally fitted twice, and am pretty particular about position on the bike and contact points etc, so I don't think that was a contributor.
  • 09-14-2012
    savechief
    What color frame did you decide to go with?
  • 09-14-2012
    eurospek
    Subscribed. :D
  • 09-14-2012
    JChasse
    Black Chrome. Keeping it low key in a gray/silver/black kinda way. Well, as low key as it can be with the carbon Enve stuff hanging on it.
  • 10-01-2012
    JChasse
    Still waiting for stuff...
    My frame is scheduled to be in the first batch shipped. Hoping to see it in the next 2-3 weeks.
    SRAM XX1 stuff was pre-ordered, so I should have that as soon as it starts shipping, too. Heard today that they are now saying late October.
    Bars, grips, and some other small parts should be trickling in soon.
  • 10-01-2012
    Salespunk
    If it is anything like the Tracer 2/26 it is going to be significantly heavier than the Turner. If I am not mistaken the Tracer is around 8.5-9 lbs for the frame only. With the amount of money you are dropping on this build you may want to check out the Carbine again. BB is about .4" higher, but not a huge difference and you already like the 26" version. Everyone riding the 27.5 Carbine is raving about it. Either way it is going to be a fun bike.
  • 10-01-2012
    skyak
    I am stoked for the XX1. My plan is an Altitude 790 frame with XX1. Not sure yet on which wheels I'm gonna go with.
  • 10-02-2012
    Dirthugger
    I await your Build sir!
    What is the max wheel size can the rear accommodate on the 27.5? I don't want to be limited to a 2.35.
    I guess one of the reason why I am not even considering the Carbine is because since it is wasn't intentionally designed for 650b it will limit the tire size. As for the weight 30lbs is nothing, light enough for me. Just get rid of the unnecessary load on your backpack. My current rig is 30lbs + 15lbs pack. Have fun on your build.
  • 10-02-2012
    Ridnw/bear
    I'm running 2.35 Kenda nevagals unfortunately on my carbine 275. There is still plenty of room for a larger tire.
  • 10-02-2012
    MTB Pilot
    4 Attachment(s)
    Is this a fact or are you just verbalizing your assumptions? :skep: The 27.5 drop-outs make the Carbine a true 27.5 bike.
    Here is my new carbine frame that I held up to the Specialized Butcher 2.5 DH(true to size) on the front of my Session. Plenty of room to run a 2.7.
  • 10-03-2012
    JChasse
    You may be right. Although, the actual weights I've seen for the Tracer 2 frames are ~ 7.6lbs (with shock, dropouts) for a medium. My Turner's actual weight is 6.8lbs. So I'm really not sure. I think it may be close when fully built...
  • 10-03-2012
    Dirthugger
    I made that assumption based on the description they have on their site describing the Carbine 275 "When we decided to venture forth into 650B territory, Steber quickly figured out that a simple dropout change could morph the incredibly popular Carbine into a carbon fiber 650B (or 27.5) frame.This is possible because of the” G1″ replaceable dropout system on all our frames , offers future compatibility and different axle choices."
    Thanks for posting your images which answers my concern regarding the Carbine 275. How much was your frameset OTD if you don't mind me asking?
  • 10-03-2012
    MTB Pilot
    PM sent:thumbsup:
  • 11-24-2012
    JChasse
    3 Attachment(s)
    This seems to be taking forever.
    I’ve got everything…except the frame and drivetrain. :rolleyes:
    The frame was pre-ordered as soon as Intense was taking orders, and was supposed to be among the first batch shipped. But apparently, the first frames ended up going toward the complete bike orders (presumably to help Intense get the build kits out of the shop). So I had to wait for a later batch. Then, the batch of Black Chrome frames mine was in got screwed up somehow, and they all have to be stripped and re-finished…ugh. So it’ll probably be late next week before the frame ships.
    The drivetrain parts (SRAM XX1) were shipped late last week.
    I think the only other outstanding part is the Enve Riser Bar - that should be here next week too.
    In the meantime, here is what I’ve got so far, and actual weights for everything:
    Fox 34 Talas fork (120-160mm) w/ 15 QR axle = 4.64lbs (2,105g)
    Enve XC wheels w/ DT240 hubs and CX-Ray spokes . (with rim tape – no valves, skewers or rotors):
    Front =690g
    Rear = 770g
    Wheels with mounted Nobby Nics (w/ valves, sealant – still no skewers or rotors)
    Front = 1,520g
    Rear = 1,610g
    Eriksen Ti Seatpost w/ hardware = 235g
    King Headset w/ crown race, star nut = 188g
    Tune Seat Collar = 31g
    King Ti Cage = 28g
    XTR Trail brakes – levers, calipers, hoses – no rotors = 530g
    Thomson Stem – 100mm/0-degree = 166g
    ODI Lock-on grips = 108g
    Time ATAC carbon pedals (from old bike) = 340g
    WTB SST saddle (from old bike) = 225g
    <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:DoNotPromoteQF/> <w:LidThemeOther>EN-US</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> <w:SplitPgBreakAndParaMark/> <w:EnableOpenTypeKerning/> <w:DontFlipMirrorIndents/> <w:OverrideTableStyleHps/> </w:Compatibility> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="&#45;-"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemiHidden="true" DefQFormat="false" DefPriority="99" LatentStyleCount="267"> <w:LsdException Locked="false" Priority="0" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Normal"/> <w:LsdException Locked="false" Priority="9" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/> <w:LsdException Locked="false" Priority="10" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Title"/> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> <w:LsdException Locked="false" Priority="11" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/> <w:LsdException Locked="false" Priority="22" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Strong"/> <w:LsdException Locked="false" Priority="20" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> <w:LsdException Locked="false" Priority="59" SemiHidden="false" UnhideWhenUsed="false" Name="Table Grid"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/> <w:LsdException Locked="false" Priority="1" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 1"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 1"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 1"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/> <w:LsdException Locked="false" Priority="34" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> <w:LsdException Locked="false" Priority="29" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Quote"/> <w:LsdException Locked="false" Priority="30" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 1"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 1"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 2"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 2"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 2"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 2"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 2"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 3"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 3"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 3"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 3"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 3"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 4"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 4"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 4"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 4"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 4"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 5"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 5"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 5"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 5"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 5"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 6"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 6"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 6"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 6"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 6"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> <w:LsdException Locked="false" Priority="19" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> <w:LsdException Locked="false" Priority="21" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> <w:LsdException Locked="false" Priority="31" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> <w:LsdException Locked="false" Priority="32" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> <w:LsdException Locked="false" Priority="33" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Book Title"/> <w:LsdException Locked="false" Priority="37" Name="Bibliography"/> <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} </style> <![endif]-->
  • 11-25-2012
    hrdude
    I bet that Intense will be faster than the Spot.
  • 11-27-2012
    JChasse
    I hope so, I need all the help I can get in the fast department.
  • 11-27-2012
    JChasse
    More goodies arrived today.
    Some more actual weights for the geeks:
    XX1 Crank w 32t ring = 564g (no BB)
    XX1 Rear der. = 241g
    XX1 Cassette = 267g
    XX1 Chain (uncut, w/ quick conect link) = 251g
    XX1 Shifter w/ cable and clamp (no housing) = 122g
    Spare 30t chainring = 38g
    we're gettin' close now...just need the Enve handlebar...and a frame!
  • 11-27-2012
    JChasse
    This cassette is a work of machined art. I'm a little worried about durability of that big aluminum cog, but it's a pretty cool piece of hardware.
  • 11-27-2012
    textbookonewk
    Exciting stuff!
    I can't wait for my XX1 kit to show up already. Of course mine will be going on a frame that is almost 5 years old, so not quite as exciting as your pile-o-brand spanking new parts.
  • 11-27-2012
    skyak
    JChasse...what crankset and BB are you going with? 170/175, 156/168, GXP/BB30
  • 11-27-2012
    JChasse
    175mm cranks with standard threaded BB (GXP).
  • 11-27-2012
    skyak
    Q factor of 168?
  • 11-27-2012
    JChasse
    Q factor of 168?
    Actually, I didn't think to specify. I just checked and my shop got me a 156.
  • 11-27-2012
    skyak
    Cool, I wanted the 156 but ended up ordering a 168 because I was worried about fitment with the 12x142 rear axle. Interested to hear how the 156 fits!
  • 11-27-2012
    JChasse
    Not sure I follow. Are you concerned about chainline? Does the wider q-factor crank actually move the c-ring out, or just the crankarm? (I would have thought the c-ring is in the same place, regardless of q-factor, but I'm guessing here)
  • 11-27-2012
    skyak
    I don't think it affects chain line (not sure though). I was mainly thinking about the crank arm and the chainstay (on a new Rocky Altitude 650B).
  • 11-27-2012
    KRob
    Nice.
    Those boxes look expensive.
    That's going to be a sweet build. Can't wait to see it complete and hear your impressions after you get a few rides under your belt.
  • 11-27-2012
    slowrider
    Nice
    I tested a T 275 and it was so much more fun than my tracer 29, I think you'll have a blast.
  • 12-12-2012
    JChasse
    Finally got it nearly finished. Still playing with position, and waiting for the Enve Riser bar, but otherwise good to go.
    27.96 lbs as pictured...
  • 12-12-2012
    JMac47
    RRrrrrrr! Nice and stealthy.
  • 12-12-2012
    13pumps
    WOW very impressive, can't wait to read your first ride report.
  • 12-12-2012
    Duncan1104
    That is beautiful! I wish my wheels would come in so I could finish building my 275!
  • 12-22-2012
    mbikerguy
    Beautiful bike and very nice build!
  • 12-22-2012
    Tjay
    I thought it'd be at 25 lbs with the dropper post. Nonetheless its a very nice looking bike. How much does the frame weigh?
  • 12-23-2012
    JChasse
    The frame (medium) was 8.0 lbs with the shock, and the fork is 4.6lbs. So this is as light as it's likely to get without resorting to stupid light parts.
    I got a whole hour ride on it at lunch the day before we got a foot+ of snow. Too short a ride to say much. Wait, no it wasn't...I loved it. And the XX1 is just ridiculously quiet.
  • 12-23-2012
    vizsladog
    verrrrrry nice.
    man i love that xx1..
  • 12-23-2012
    casey
    Nice looking ride. Just curious as to the final price tag. Care to share?
  • 12-23-2012
    sportsmed
    Nice, can those Enve XC wheels hold up to the abuse a long travel bike will likely see?
