Results 1 to 6 of 6
    Nov 2006
    indy fab 650b set up thread
    ok, i got a indy fab frame with 425mm CS and 25" ETT (i am 6.2"), reba u-turn 29er fork to play around with a-c or maverick duc32 set up for 650b. i am mostly riding technical singletrails.
    i will need to decide what set up i want to use on it. i can run a smaller 29er tire in the rear (racing ralphs 2.25 clear but barely, a conti race king 2.2 fits well). i have a 650b wheelset with blunts and neo motos 2.35 or various 29er options.
    i will try out the different set ups during the next weeks and share the impressions.
    to get started, here some pics of the 650b set up. and no, i will not clean the bike before making pics - not worth it considering my iphone level photographic skills anyhow .
    Attached Thumbnails Attached Thumbnails indy fab 650b frame. how shall i run it 650b f&r vs. 29er f&r vs. 29er f & 650b?-indy-fab-0-.jpg
    indy fab 650b frame. how shall i run it 650b f&r vs. 29er f&r vs. 29er f & 650b?-picture-004.jpg
    indy fab 650b frame. how shall i run it 650b f&r vs. 29er f&r vs. 29er f & 650b?-indy-650b-2.jpg
    indy fab 650b frame. how shall i run it 650b f&r vs. 29er f&r vs. 29er f & 650b?-indy-650b-1.jpg
    Reputation: MMcG's Avatar
    Jul 2003
    Looks great with dual 650bs!
    wouldn't a 29er combo raise the bottom bracket height to uncomfortable heights?
    Nov 2006
    good point.
    the geometry is been set for a 520mm A-C fork with 130mm travel and fairly high bottom bracket drop (BB height is actually similar to my a9c with carbon fork). i guess this is more of an AM hardtail ...
    i should be perfectly fine with 29er front or even 29er f&r, but will see in a couple of days.
    No B9'r results?
    Reputation: Davidcopperfield's Avatar
    It's a HT and bigger wheel will take an edge off obstacles. It it can be made into a 29er, just do it.
    just some guy
    Reputation: talabardio's Avatar
    It would be neat if you could go back and forth between the two wheel sizes, and compare.
  1. 650b velocity blunt-650b sun eq 650b 27-wtb comparison
    By AMCAT in forum Wheels and Tires
    Last Post: 05-13-2010, 06:52 AM
  2. Replies: 0
    Last Post: 04-28-2010, 07:43 AM
  3. FS 29er frame for 650b?
    By ro7939 in forum 27.5
    Last Post: 06-10-2009, 08:44 AM
  4. 650b in 29er frame
    By bogmonster in forum 27.5
    Last Post: 01-27-2009, 04:25 PM
  5. Replies: 25
    Last Post: 09-29-2007, 02:07 PM
