Results 1 to 37 of 37
    Reputation: fskywalker's Avatar
    May 2010
    Hub Swap from 20mm to 15mm on American Classic 650BXC Front Wheel
    Hi. SIXFIFTY | 650b Gear - Home has a great deal on some American Classic 650 XBC wheels that are factory take offs from Jamis Dakar B2 bikes. ($350 for the pair) I recently bought that same frame from them, but rather than buy a XFusion or a White Brothers 650b specific fork, bought a 2012 Fox Talas Terralogic 125-150mm fork from Price Point for a great price. My new fork is 15mm thru axle and the front wheel of the American Classic wheel set on sale is 20mm, so it won't fit. I called American Classic and there is not an 20 to 15mm adapter for those wheels, so would have to replace the front hub with a 15mm thru axle compatible unit. My questions are:
    1- Opinions on that wheel set for that price.
    2- I believe I can buy a new hub and re-use the spokes and nipples? Other than being 32 holes and 15mm axle, what other specs I would have to check to re-use the spokes and nipples?
    3- What hubs would be recommended? I have seen American Classic hubs for $100 at Ebay, but also saw a Shimano XTR from hub for the same price (though the Shimano is center lock and my front disc is IS 6 bolts, so would then have to get it replaced)
    4- What would be a reasonable labor cost to de-laced the wheel and re-lace with the new hub?
    Thanks,
    Francisco
    IMG Jamis Sixfifty B2
    Gone, but not forgotten:GT LTS-3, GT Zascar Expert Carbon, Look 986, Giant Anthem Advanced
    i'm pretty surprised there are no 15mm ends, could be about as much hassle to have some 15mm adapters made or modified. pick some for hope dimension or origin8 and see if they fit, and if not what needs to happen to make it work. they are not very complicated.
    May 2010
    I asked American Classic about that (using some third party 20 to 15mm adapters on their wheels) but they did not recommend it. They do have adapters for other wheels, but not on those
    Do you think the wheels for $350, even having to modify the front wheel and perhaps spending around $125-150 to convert it, is a good deal? I look elsewhere and the lowest price, other than theirs, is close to $600.
    of course they are not going to recommend using any other brand or modifying anything...they have a business to run!
    as far as whether they were a good deal is pretty relative, if you can use the rear as-is and either make an adapter work or get a front hub for less than a hundred and do the swap work yourself, probably totally worth it. but if you do not have the skills and have to pay someone else, weelllll, worth it depends on you!
    May 2010
    Thanks. I have never done a de-lace /re-lace before, but would imagine a DIY guide should be available somewhere in the web. I do have a kit that I bought from morning star wheels to eliminate disc springbuck (truing them) that can also be used to do truing of the wheels, so perhaps I could do it myself.
    May 2010
    Will any 100mm hub work or does it has to be an AC for the spokes to be re-used?
    120 is offline
    Kicker of Elves
    Reputation: 120's Avatar
    I'm have a similar plan except I'm rebuilding the front with a Rotaz hub ($50.00 shipped, light weight, looks like an AC, said to be the company who actually manufactures the AC).
    I did the spoke calc and it should swap over without new spokes. We'll see when they get here in the middle of this week.
    Check bikehubstore.com for info on the hub if interested.
    May 2010
    I finally decided to order the American Classic 650 BXC wheels today from SixFifty for $330 plus shipping, along with a pair of Schwalbe Racing Ralph's 2.25 and an American Classic 15 mm front hub (off Ebay) If I decide to run them the wheels on tubes by now, can I buy 29 incher tubes or do I need 650b specific tubes?
    plain 26" tubes.
    May 2010
    That's great! I think I still have a couple of tubes that I bought before converting my first set of wheels to tubeless.
    May 2010
    Just got the new AC 650 BXC wheels yesterday, nice looking! I now have to wait for the arrival if the new front hub to take it to my LBS for the 20mm to 15 mm thru axle conversion.
    NedwannaB
    Reputation: JMac47's Avatar
    To reuse spokes depends
    Quote Originally Posted by fskywalker View Post
    Just got the new AC 650 BXC wheels yesterday, nice looking! I now have to wait to the new from hub to take it to my LBS for the 20mm to 15 mm thru axle conversion.
    They'll have to check specs on ea hub and compare the radius pattern on the holes on flanges. It's not just about spoke count. They may work, if not figure about $1 per spoke and probably 1/2 to an hour labor depending on if they have to unlace your wheel or not.
    Wait whuuut, who did he tell you that!?!?....
    May 2010
    Hi. I bought exactly the same hub from American Classic, but 15mm; they said I can reuse the spokes, so should be a labor only job. I was quoted by 2 LBS $20 and $30 for the labor. I plan to sell the AC 20mm axle so at the end the extra cost should not be that bad.
    NedwannaB
    Bingo!
    You're almost good to go.
    Trail Care Coordinator
    Reputation: Oppy's Avatar
    Nov 2006
    If you have the same hub shell why not just change the axle instead of relacing?
    May 2010
    Good point! Should get the hub today, will try that!!
    NedwannaB
    Confused.....
    I thought you were told by lbs that your 20mm hub wouldn't interchange with the 15 and that's why you bought the new hub??
    May 2010
    What I understand from the suggestion above is that perhaps I can dissasemble the internals of the 20mm and 15mm hubs and swap them; what AC told me was not available is an adapter to fit inside the 20mm cavity to make it 15mm (sleeve)
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    With most convertible hubs
    The only difference btwn a 15mm and a 20mm are the end caps that hold the axle while the hub shells remain the same. You could begin by removing the AC end caps taking some OD measurements and take into account how the end cap is secured in the hub shell. Then survey what manufacturers end caps share, or come close to that same OD and securing. Sure is a lot cheaper.
    NedwannaB
    Got it
    What I understand from the suggestion above is thst perhaps I can dissasemble the internals of the 20mm and 15mm hubs and swap them; what AC told me was not abailable is an adapter to fit inside the 20mm cavity to make it 15mm (sleeve)
    The 20mm t/a Havens I got a "great deal" on weren't adaptable to 15, or 9mm qr either. So I ended up getting some 20mm lowers thrown in the deal to make it worth while.
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    Quote Originally Posted by jrm View Post
    Not going to work. Thought flanges are the same, the hub shell is not. Their 15TA does use the same hub shell as their standard QR hub. just a different axle setup. the 20mm is a totally different hub. only the flanges are the same. making the 2 hubs have the same flanges sizes gave American Classic the ability to stock less spokes when building wheels. The 15mm/QR hub pretty much had a maxed-out flange width for building strong wheels.
    trust me on this. I worked there.
    jrm
    jrm is offline
    And thats why i began the
    Quote Originally Posted by Cracked Headtube View Post
    post with "most convertible hubs". Thanks for the inside scope.
    May 2010
    The new QR15 hub got misplaced by USPS mail, I should FINALLY get it delivered today. I installed yesterday a 2.25 inch Racing Ralph on the rear one with the American Classic tubeless kit and Stans fluid and the wheels does look good!
    New American Classic 650BXC wheel on the left, Mavic Crossmax SLR 26er wheel on the right:
    May 2010
    I took today the wheel and new hub to my LBS, it should be ready by Friday!
    May 2010
    Swap is done! The new QR15 American Classic hub is A LOT lighter than the QR 20, next step is to make the wheel tubeless like already done to the rear wheel!
    May 2010
    New front wheel is ready, full bike is almost ready! Just need to cut the excess tube from the fork and get a new FD since need a high mount unit and mine is a low mount.
    Jan 2009
    How do You feel with this wheels ? Are they good for a trail bike or they Are a bit too fat weight ? I'm looking for switching to 650 on a prophet but i m not sure how much it Will be more hard to climb..
    May 2010
    Hi, haven't field tested the bike yet, but their weight seems to be reasonably light, specially with the new front 15mm hub, which weights quite less that the former 20mm hub.
    Dave
    Reputation: liteandfast's Avatar
    Nov 2007
    Do you have secret pedals there??? why the bags over the pedals? I lloked at the AC wheelset but I thought it sounded a little heavy. I"m going with a Blunt SL and no-name hubs that are 28 hole and the two hubs weigh around 400 grams.
    I have AC 15mm on ly 29er and the bare hub weighed only 118 grams, really lite.
    I need to ride more and work less.
    May 2010
    Secret pedals? not really .... the pedal bags are to protect the house walls and doors, car carpet and seats, car paint, etc. from impacts of my Shimano XTR trail pedals. American Classic 650BXC's rims are 32 holes (the ones you mentioned are 28 holes) and if you go to the SixFifty: Home website the rims are 484 grams, which is slightly less than the Stans ZTR Flow (489 grams) rims but heavier than the Stans ZTR Crest rims (350 grams), which are lighter but perhaps not as strong. I went for the 650BXC's mostly due to the good sale price I got from them, for $330 the deal is hard to beat; even if you had to replace the from hub as I did the price is around $400, still been very reasonable. Hope this helps
    May 2005
    Quote Originally Posted by liteandfast View Post
    Be aware that many have complained about the softness of the Blunt SL's and bending. You have a Prophet (as I do) and you might want to reconsider that choice. Maybe have a look at the new Pacenti rims which have gotten great reviews so far. I have Stans Flows on my Prophet but I live in rocks and need a stout rim. They also have the lighter Crest but those Pacenti rims look real nice to me and a decent weight.
    2013 Banshee Spitfire V2 650b
    Dave
    Nov 2007
    I got no Prophet
    Quote Originally Posted by skidad View Post
    I don't have a Prophet. Never have.
    I am building a bike for my wife. It's a Soma B-side (Orange) SS and she is light so I hope the Blunt's will be fine for her. Yes I have read that too about them being soft.
    How about the 20mm to 9mm QR?
    Anyone know if changing the 20 mm hub to a 9mm QR is an alternative?
    I want to get these wheels, too.
    Thanks,
    Miggy
    May 2010
    Yes it is also possible, just buy a 9mm hub, I have seen it in Ebay by American Classic (Check New! American Classic Front Bicycle Hub 6 Bolt Disc 32 Hole 100mm Spacing 9mm QR | eBay) for $75 plus $7 shipping; you buy an American Classic hub, you can re-use everything like I did) or from other manufacturers, but at risk to need new spokes if the spokes length is not the same.
    Hope this helps!
    Francisco
    May 2010
    Final product
    This is the update picture for my Jamis, 28 pounds 7 ounces as pictured
    Reviving very old thread. How did you like the wheels? I'll PM you too if that's ok...
    I see the American Classic BXC wheels still for sale on sixfifty dot com. Like you, I don't have a 110 mm width axle fork. My fork is 9 mm axle with 100 mm wide axle. I am thinking of doing the same thing you did, but with a 15 / 9 mm convertible hub (so I can use the wheels with 15 mm forks) ...or just get a 9 mm hub (which I think you can adapt up to 15 mm or whatever...anyways...
    So how did you like the wheels? From what I understand, they are a decent weight for the price. I wonder how they are strength wise. 24 mm rim width is interesting too. Most rims seem to be 26 or 28 mm (apart from the wide 35's some people run).
    I would like to know a bit more about these rims, like what their internal width is.
    thanks in advance for any feedback
    Wheels are no longer available but I'd still like to know how you liked your wheels, and the bike too
