Results 1 to 23 of 23
    New question here. How wide is your bar?
    Hey fellas, regardless if your on a rigid/front suspension/full suspension ride; 2 questions.
    1. How wide are the handlebars your using?
    2. Riser or flat?
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    1. 685 mm
    2. riser
    (Ragley Carnegie's)
    ...on a 650B rigid conversion that was SS for 5 years until being converted to 1x10 last May.
    I wish I had an Answer Enduro 20/20, but just can't afford it right now.
    Better to have and not need it, than to need it and not have it.
    Re: How wide is your bar?
    685mm Ragley Carnegie riser bar (inverted) on a steel 29er with steel rigid fork.
    690mm Crank Brothers Cobalt flat bar on Ti 29er with carbon rigid fork.
    Sent from my GT-N8000 using Tapatalk 2
    Reputation: SManZ's Avatar
    Jun 2013
    I'm 5'6" on small frames.
    The StumpJumper is on the factory 720mm Specialized bar, 10mm rise, 45mm stem.
    The Bronson is on a 750mm Easton Havoc bar, 20mm rise, 60mm stem.
    I prefer the 750mm and after I install the Easton Havoc Carbon this weekend on the Bronson the alloy one is going on the SJ
    I have a black belt in MS Paint.
    2013 Santa Cruz Bronson Carbon
    2013 StumpJumper FSR Comp Carbon 29er
    Reputation: Settertude's Avatar
    Jun 2013
    XC bike sports 24" bars
    All Mountain 27".
    Both have rises.
    I'm afraid of heights so a 26'r fits me to a T.
    Reputation: nuffink's Avatar
    Feb 2010
    No idea, except that it's not as wide as when I bought it.
    Strangely, I seem to be one of he few on here who makes the bar accommodate them rather than vice versa.
    Reputation: jmallory's Avatar
    Renthal Fatbars cut down to 760mm with 10mm rise on my Bronson.
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    690mm, Flat, 29er hardtail with 100mm suspension fork.
    Jun 2012
    Easton Havoc carbon 750mm long, 20mm rise.
    Apr 2013
    I find that larger than 720mm is a problem at tight singletracks, because you start hitting bushes and trees.
    I would love a larger one, but the local trails doesn't allow for it
    _________________________________
    AllMountainStyle Frame Guards
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    flat is 715 and riser is 710. Any wider and id be clipping more trees...
    May 2005
    Quote Originally Posted by Carles Carrera View Post
    X2 pretty much....Answer Pro Taper Carbon and Spank Subrosa both @ 720mm with 1" rise
    For my shoulder width and terrain I've found 720mm to be the sweet spot. Tried them wider (Spank was 750 when new) but they felt uncomfortable and I was clipping trees to often here in New England.
    My dirt bikes I use 30" bars (762mm) and they feel fine and we thread through stuff just as narrow as mtn. bikes. Go figure.
    Reputation: laffeaux's Avatar
    Apparently I'm the "narrow bar guy" ... I prefer a 23" (580mm) flat bar.
    I ride with bar ends and with wider bars the positioning with bar ends is awkward. I do run a wider bar on my singlespeed (without bar ends) and it's fine, but for general riding a like 580mm.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Feb 2012
    Quote Originally Posted by verrocchio100 View Post
    2. Riser or flat?
    27.5"
    Give or take a few inches.
    i'm also a narrow bar guy with a 580mm carbon flat bar with bar ends
    yeti SB5c
    specialized epic comp carbon - 650b
    just some guy
    Reputation: talabardio's Avatar
    680, flat, bar ends
    blog hogs
    Feb 2010
    23",flat,bar ends.
    Ignore them till they go away.It's corporate policy.
    Kiwi that Flew
    Reputation: deanopatoni's Avatar
    800mm very low rise on 50mm stem on 140mm FS bike (with 160mm fork)
    711mm very low rise on on 70mm stem on 100mm FS bike (with 120mm fork)
    Reputation: Clicker1's Avatar
    May 2012
    670mm / 15mm rise
    Reputation: johnny thunder's Avatar
    ENVE riser 740mm (29") wide, 23mm rise, 9 degree sweep. With 70mm ENVE stem on Bronson.
    Reputation: carverboy's Avatar
    26 1/2 riser with stubby bar ends.
    UGG boots will germinate Paris Hilton like intellect in your soles!
    I just got a new bar today for my old '98 ProFlex. I went from a 580mm flat EC70 to a flat 620mm carbon and supposed 9 degree bend. I too run bar ends. I'm 6'2" and shortened my stem 10mm a few years back and was looking to calm the handling down a bit and give myself a bit more room. I like it so far.
    Reputation: mint355's Avatar
    Mar 2012
    Truvativ blackbox 750mm 25mm riser on my Bronson
    Bontrager 700mm flat bars on my Trek 29 SS
  1. Handlebar Width! 660mm/26 inches! How wide is too wide?
    By TritonBill in forum General Discussion
    Last Post: 12-13-2015, 01:33 PM
  2. Handlebars - how wide is too wide?
    By chucko58 in forum All Mountain
    Last Post: 02-09-2013, 05:48 AM
  3. I need new Wide Shoes, Opinions of Giro HV or Bontrager Wide?
    By paulrb02 in forum Clydesdales/Tall Riders
    Last Post: 11-18-2012, 10:28 AM
  4. How wide is everyone going on the HD?
    By recleaver in forum Ibis
    Last Post: 06-21-2012, 08:14 AM
  5. How wide is too wide of a handlebar for SS?
    By Kaizer in forum Singlespeed
    Last Post: 05-19-2011, 10:46 PM
