Results 1 to 14 of 14
    Nov 2017
    Help with 1x9 gearing
    Hello, I have been trying to bring my bike to a 1x9 gear setup. I have tried multiple times but am very confused. Does anyone have any part combos that will work at a cheap price. The reason I am not going 1x10/11 is because it is too expensive.
    Mar 2017
    I found that a good quality narrow wide chainring is the only key component. I converted my 3x9 to a 1x9 just replacing the orginal chain rings to a raceface narrow wide. All was good and never had a problem with the chain falling off shifting.
    RAKC Industries
    Jan 2017
    1x9 is not an upgrade so why are you changing it? Your going to loose half your gear range. Are you only riding on one of your chainrings up front all of the time?
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    US partner for Ravemen:
    www.rakclighting.com
    Nov 2017
    I was going to upgrade it because I do only use one gear upfront and have a lot of problems with the chain coming off.
    Nov 2017
    Also right now I am running a 3x7 gear ratio so I would think it is only better than that
    RAKC Industries
    Jan 2017
    Chain coming off is a set up issue.
    1x9 still isnt going to he an upgrade and isnt much if any cheaper than 10 speeds for quality parts these days.
    Quote Originally Posted by roadkill401 View Post
    Ditto, I ran a 1x9 for quite a while with just a race face narrow wide chain ring. I never had the chain jump off once.
    Dec 2017
    Quote Originally Posted by Brenan2003 View Post
    Parts for 1x10 are relatively cheap right now, so I'd consider going that way rather than 1x9. If you were coming from 3x9, 1x9 would be a cheap way to go, but I don't expect much difference in price to go to 1x10 or 1x9 from 3x7.
    ultra grumpy
    Reputation: noapathy's Avatar
    If you're having problems setting up a front derailleur, there's plenty of help these days. 9spd vs 10spd - 10spd wins all day long and twice on Sunday. Sometimes I even find quality 9spd stuff costs more as RAKC mentioned. Going 1x from 3x7? If it's in ok shape, you can use your current crankset with a narrow wide chainring to save money. What exactly is "a cheap price"?
    Nov 2017
    A cheap price for me is mostly in the 200-300$ range and my crankset is good but does the fact that it is rivited on change anurhing
    Reputation: grubetown's Avatar
    Sep 2013
    Yes, you will need a whole new crankset if the chainrings are riveted on.
    Sep 2013
    Budget 1x10 With Old Shimano Tech - BIKEPACKING.com
    Read through the comments for good tips also
    Jun 2013
    If you have a riveted crank, I can pretty much guarantee you can't put a 9 speed cassette on your rear wheel. It might not even have a cassette, probably a freewheel.
    ultra grumpy
    Quote Originally Posted by MudSnow View Post
    Good point - seems we all missed.
    OP, looks like if you get to figure out how to deal with your front derailleur or go 1x7.
  1. Racing 29er 1x9 gearing
    By Dictatorsaurus in forum XC Racing and Training
    Last Post: 12-15-2011, 06:40 AM
  2. Recommended gearing for 1x10 or 1x9
    By Pauldotcom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-25-2011, 06:31 PM
  3. 1x9 commuter gearing
    By SSSasky in forum Commuting
    Last Post: 05-19-2011, 03:13 PM
  4. 1x9 setup (Qs on BB length and 30T x 12-36 gearing)
    By hilljack in forum 29er Bikes
    Last Post: 01-12-2011, 12:42 PM
  5. Wildcard gearing 1x9
    By schlockinz in forum Banshee Bikes
    Last Post: 01-03-2011, 04:29 PM
Members who have read this thread: 39
