Results 1 to 30 of 30
    I quit e-MTBR
    Reputation: OldManBike's Avatar
    Hans Damp snakeskin 2.25 finally out
    Schwalbe Hans Dampf Evo Snake Skin TrailStar 650B x 2,25" TL-Ready foldable
    For folks who've been desperate for a Schwalbe tire small enough to fit their frames/forks with sidewall protection.
    Dec 2012
    I've been waiting and waiting. Wish they had em in Pacestar, but what a killer price! Had to order a pair...
    Feb 2012
    Thank you OldManBike, I ordered a pair. This tire should be a great rear tire option for the North East, a nice complement for the Trail Taker in the front.
    Reputation: SteveF's Avatar
    I'm interested in this tire sort of, but not the trailstar version. I suppose it's only a matter of time 'til other options become available...
    Reputation: reformed roadie's Avatar
    Quote Originally Posted by joe77gw View Post
    If you don't mind me asking, what was freight from Germany?
    I quit e-MTBR
    Quote Originally Posted by reformed roadie View Post
    $26 to US, seems to be same flat rate if you order 1 tire or 4.
    Dec 2012
    Yup, 26.58 for DHL shipping for a pair. At first I balked, then realized the total was far less than what I recently paid for 2 HD 2.35's here in the US. And they were out the door this morning...
    I quit e-MTBR
    My experience with that particular retailer has been fine, but my point wasn't to encourage folks to buy from them, just that those tires are becoming available. I haven't checked around to see who else has them yet.
    Feb 2012
    Anyone managed to get these setup tubeless? I cannot get the bead seated with a blast of air from a tank, the tire is *stiff*. I had it sitting one another wheel with a tube at 50 PSI for more than twelve hours before trying to air it up tubeless.
    Reputation: in the trees's Avatar
    Mar 2005
    Quote Originally Posted by StiHacka View Post
    Do they fit tighter than the 2.35" HDs? (If you've ever used one). I've set up a bunch of Scwalbes with the method described above.
    Can anybody post some dimensions with the tire mounted for everybody wondering whether they'll fit conversion bikes? Or how much clearance you have relative to well known 650b tires like Neo Motos or Nevegals?
    Feb 2012
    Quote Originally Posted by in the trees View Post
    They are very tight but I cannot compare them to 2.35s. I got to try some new tricks.
    Dec 2004
    Maybe the 2.25 Nobby Nic Snakeskins will be next...
    I quit e-MTBR
    Yours came faster, I'm still waiting.
    I quit e-MTBR
    Quote Originally Posted by pinepig View Post
    Not listed on their website, and IIRC the HD SS was on there a while before it became available.
    STS
    STS is offline
    Reputation: STS's Avatar
    A friend has the 650bx2,25 installed in TL28 rims
    Height is exactly the same than pacenti neo motos 2.35
    And wide 54mm (58mm neo motos)
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by STS View Post
    Seeing this comparison doesn't sound like it will lead to being used much on tight clearance conversions tho.....
    Wait whuuut, who did he tell you that!?!?....
    Darn, you had to post those... I ordered a pair too... LoL! I've been waiting on a snakeskin Nobby Nic in 2.25, and just can't wait anymore. Was about to pull the trigger on a Hutchinson Cougar (seems to get good reviews for my type of riding), but this deal was too good to pass up. Anyone running these up front? Comments?
    Aug 2010
    That would be nice. I'm running the non-snakeskin 2.25 Nobby Nics now, but I worry about their durability when I ride rocky terrain. If they end up getting shredded I might have to get some of these new Hans Dampf tires unless they start making the 2.25 Nobby Nic snakeskin.
    I'm also considering squeezing in a set of the 2.35 Nobby Nic snakeskins, but I'm concerned about clearance on my TRc.
    Reputation: mestapho's Avatar
    Quote Originally Posted by jabrabu View Post
    Poked a hole (in the tread area not sidewall) in my 2.25 NN's this weekend. Big enough that I had to put a tube in. First ride in rockyish terrain.
    Not inspiring much confidence in the durability. I ordered a pair of the 2.25 HD snakeskins to replace them.
    I'm also runnning a b'd TRc and would love to know if you can squeeze in a 2.35 NN or HD. Let me know if you try it.
    I quit e-MTBR
    For those who care about this sort of thing, the two I just received weigh 692 and 704g. (That's with the rubber band.) For comparison, the 2.35 SS HDs are ~850g. I never got around to weighing my 2.25 NNs before mounting.
    Dec 2009
    Your weights sound good. I've got a 2.25Hd in the mail .
    I must have got a real good HD 2.35. Came in at 765g. Only 15g heavier than my 26" Hd's.
    I quit e-MTBR
    Quote Originally Posted by gvs_nz View Post
    Actually, looking at what others have posted, I think I got an unusually heavy one. Claimed is 795g, and two others I weighed were 810 and 840. Just geeking out on numbers, none of it means a thing.
    How fast did Bike-Discount ship? Leaving for Moab next Thurs....
    Thanks,
    Sean
    Mar 2005
    I just ordered one direct from Schwalbe N.A. They shipped it out the same day. I picked up this tire to give a little extra rear tire clearance on my Explosif. I'll have a very low mileage PaceStar 2.35" available next week if anyone is in need. PM me.
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I had to use tubes first to get mine to bead, then I removed the tubes. IT took about 5 business days for my order to arrive in Seattle from Germany. Not bad at all. A group of us ordered a total of 8 tires and 3 sets of pedals. It was a flat $26 for shipping.
    14 Aurum, 16 Fuse, 17 T130
    I mounted mine, no problem, on a Crest rim using a compressor and soapy water. The only 'trick' I used was to remove the valve-stem for the initial bead-seating at 40psi, to increase airflow. Another trick to try, if you haven't gotten it mounted by now, is to cinch a tie-down strap around the circumference of the tire to force the beads outwards uniformly. Never tried this myself. Can't remember where I heard it from, but sounds like a good idea.
    Mar 2005
    StiHacka - Did you end up getting the tire to seat tubeless? Got mine today and having trouble on a i23 rim. I have a tube in it for tonight. But this is the first Schwalbe that has given me any trouble.
    EDIT - I realized today that I had a leak in the hose on my compressor and it wasn't building enough psi. After fixing it, the tire aired right up no problems!
    Feb 2012
    I did. Having it mounted with a tube for a while did not help much though . The moment I removed the tube, both beads sprang back to the center of the rim channel. I ended up heating the tire with a hairdryer to get it more pliable and then I hit it with a CO2 cartridge and that worked. It has been trouble free tubeless so far - no leaks, no sidewall issues. The HD2.25 is a great rear tire, rolls OK and sticks to rocks and roots like Velcro.
    Reputation: jazzanova's Avatar
    Re: Hans Damp snakeskin 2.25 finally out
    How is the clearance with the NN on the TRc? I am running a RR and had to shim the shock with 2 1.5mm spacers.
    Sent from my PG86100 using Tapatalk 2
  1. Replies: 7
    Last Post: 11-02-2012, 11:14 AM
  2. Hans Dampf 26x2.35 Snakeskin - $35
    By dietz31684 in forum Where are the Best Deals?
    Last Post: 08-26-2012, 11:05 PM
  3. Replies: 2
    Last Post: 05-21-2012, 11:24 PM
  4. Replies: 11
    Last Post: 10-03-2011, 08:36 AM
  5. Replies: 6
    Last Post: 01-30-2011, 10:15 PM
