    Oct 2015
    Front Suspension for 27.5 Surly Troll suggestions
    Hi Forum.
    I'm after your suggestion for a front suspension to fit a Surly Troll , with a 1 - 1/8 size and 27.5 wheel size.
    Happy to spend up to $700 usd, ride most xc trails and using 30mm wide or so rims.
    It seems.hard to find a front suspension that fits this bike frame.
    Just a question;
    Would it be ok to use a different sized front suspension fork? Say 29er.
    Looking forward to your suggestions.
    Cheers
    Sep 2016
    Hello-
    I am surprised to not see any responses to your question Muzzag. I have a 2012 Troll, and have used 26" wheels and Rockshox suspension forks for a few years, worked great.
    Recently, I purchased a set of 27.5" wheels and am now looking for a new set of suspension forks.
    My concern has been that with the 27.5 wheels and suspension forks (100 or 120 mm travel) it will alter the geometry. Have talked to a couple of LBS' and they believe it would work but I have not been able to find anyone that has actually done this and can confirm it works well.
    Anyone out there to give suggestions?
    I used a 26" Psylo fork on mine. Worked well! Plenty of room for 27.5x2.4's on 35mm rims. U-turn ones like I had could adjust travel from 80-120mm.
    I sold this bike over 2 years ago, but sometimes I miss it!
    Jason
    Disclaimer: www.paramountsports.net
    Aug 2018
    Quote Originally Posted by Zmanpdx View Post
    Hello-
    Hi, just saw this message. I have a '17 Surly Troll (non suspension corrected) and have just installed a suntour raidon hydraulic fork on it. It works great! changes the geometry a little but nothing problematic as far as I can tell. Just one thing is your front disc brake should be at least 180mm to fit properly - I have a 160mm diameter one at the moment and it's only braking on 2/3 of the disc's surface - can be corrected on the surly fork but not with the raidon.
  1. Replies: 12
    Last Post: 02-18-2013, 06:59 PM
  2. Need suggestions re front suspension
    By OCDirt in forum Weight Weenies
    Last Post: 12-09-2012, 01:39 AM
  3. Replies: 4
    Last Post: 11-08-2012, 04:52 PM
  4. Which fork? Surly Instigator VS Surly Troll
    By Bokchoicowboy in forum General Discussion
    Last Post: 09-02-2011, 08:21 PM
  5. Replies: 6
    Last Post: 05-13-2011, 10:24 AM
